error while building from RSB
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jun 15 17:09:22 UTC 2018
On Fri, 15 Jun 2018, 22:35 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> On Fri, 15 Jun 2018 at 17:49, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hello,
>> While trying to freshly build RTEMS from RSB with the following command
>> `../source-builder/sb-set-builder \
>> --prefix=/home/lunatic/development/rtems/5 5/rtems-sparc"
>> I'm getting the following error :
>> error: downloading https://gaisler.org/gdb/gdb-8.0.1-sis-leon2-leon3.diff:
>> all paths have failed, giving up
>> Build FAILED
> Yeah gailser.org does seem to be down. You could grep for that patch in
> rsb and comment it out and just build without it. You're using qemu to run
> it so I don't think the gdb patch is necessary.
Will do it. Thanks. :)
>> The url doesn't seem to work when I open from browser.
>> -- vijay
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180615/c18d7774/attachment-0002.html>
