error while building from RSB
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jun 15 20:37:13 UTC 2018
On 16 June 2018 at 01:50, Gedare Bloom <gedare at rtems.org> wrote:
> Hello there,
> someone on IRC mentions that www.gaisler.com works still. Maybe try
> changing the URL to that one?
> https://www.gaisler.com/gdb/gdb-8.0.1-sis-leon2-leon3.diff
returns 404
> On Fri, Jun 15, 2018 at 1:09 PM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > On Fri, 15 Jun 2018, 22:35 Cillian O'Donnell, <cpodonnell8 at gmail.com>
> wrote:
> >> On Fri, 15 Jun 2018 at 17:49, Vijay Kumar Banerjee
> >>> Hello,
> >>> While trying to freshly build RTEMS from RSB with the following command
> >>> `../source-builder/sb-set-builder \
> >>> --prefix=/home/lunatic/development/rtems/5 5/rtems-sparc"
> >>> I'm getting the following error :
> >>> error: downloading
> >>> https://gaisler.org/gdb/gdb-8.0.1-sis-leon2-leon3.diff: all paths have
> >>> failed, giving up
> >>> Build FAILED
> >> Yeah gailser.org does seem to be down. You could grep for that patch in
> >> rsb and comment it out and just build without it. You're using qemu to
> run
> >> it so I don't think the gdb patch is necessary.
> > Will do it. Thanks. :)
> >>> The url doesn't seem to work when I open from browser.
> >>> -- vijay
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180616/9e599b24/attachment-0002.html>
