[PATCH v3 09/22] rtemstoolkit/elf, files: Catch exceptions in destructors.
Chris Johns
chrisj at rtems.org
Mon Jun 18 02:29:07 UTC 2018
Catch exceptions in destructures and print a message to avoid
an unhandled exception happening in an exception stack unwind.
rtemstoolkit/rld-elf.cpp | 57 ++++++++++++++++++++++--------------
rtemstoolkit/rld-files.cpp | 72 ++++++++++++++++++++++++++++++++++++++++++----
2 files changed, 101 insertions(+), 28 deletions(-)
diff --git a/rtemstoolkit/rld-elf.cpp b/rtemstoolkit/rld-elf.cpp
index 60ba484..ace3967 100644
--- a/rtemstoolkit/rld-elf.cpp
+++ b/rtemstoolkit/rld-elf.cpp
@@ -435,7 +435,21 @@ namespace rld
file::~file ()
- end ();
+ try
+ end ();
+ catch (rld::error re)
+ std::cerr << "error: rld::elf::file::~file: "
+ << re.where << ": " << re.what
+ << std::endl;
+ catch (...)
+ std::cerr << "error: rld::elf::file::~file: unhandled exception"
+ << std::endl;
void
@@ -447,7 +461,8 @@ namespace rld
void
file::reference_release ()
- --refs;
+ if (refs > 0)
+ --refs;
void
@@ -525,16 +540,14 @@ namespace rld
if (archive_ && (ek != ELF_K_ELF))
throw rld::error ("File format in archive not ELF",
"elf:file:begin: " + name__);
+ if (ek == ELF_K_AR)
+ archive = true;
+ else if (ek == ELF_K_ELF)
+ archive = false;
else
- if (ek == ELF_K_AR)
- archive = true;
- else if (ek == ELF_K_ELF)
- archive = false;
- else
- throw rld::error ("File format not ELF or archive",
- "elf:file:begin: " + name__);
+ throw rld::error ("File format not ELF or archive",
+ "elf:file:begin: " + name__);
if (!writable_)
@@ -545,7 +558,7 @@ namespace rld
oclass = ::gelf_getclass (elf__);
- ident_str = elf_getident (elf__, &ident_size);
+ ident_str = ::elf_getident (elf__, &ident_size);
@@ -567,15 +580,6 @@ namespace rld
if (refs > 0)
throw rld::error ("References still held", "elf:file:end: " + name_);
- if (elf_)
- if (rld::verbose () >= RLD_VERBOSE_FULL_DEBUG)
- std::cout << "libelf::end: " << elf_
- << ' ' << name_ << std::endl;
- ::elf_end (elf_);
- elf_ = 0;
if (fd_ >= 0)
if (!writable)
@@ -595,12 +599,21 @@ namespace rld
fd_ = -1;
name_.clear ();
archive = false;
- elf_ = 0;
oclass = 0;
ident_str = 0;
ident_size = 0;
writable = false;
secs.clear ();
+ if (elf_)
+ if (rld::verbose () >= RLD_VERBOSE_FULL_DEBUG)
+ std::cout << "libelf::end: " << elf_
+ << ' ' << name_ << std::endl;
+ ::elf_end (elf_);
+ elf_ = 0;
diff --git a/rtemstoolkit/rld-files.cpp b/rtemstoolkit/rld-files.cpp
index fdf12a6..f26aeec 100644
--- a/rtemstoolkit/rld-files.cpp
+++ b/rtemstoolkit/rld-files.cpp
@@ -256,10 +256,12 @@ namespace rld
image::~image ()
if (references_)
- std::cerr << "rtl:file:image: references when destructing";
+ std::cerr << "rtl:file:image: references when destructing" << std::endl;
if (fd_ >= 0)
::close (fd_);
+ fd_= -1;
if (writable && remove)
if (rld::verbose () >= RLD_VERBOSE_INFO)
@@ -268,6 +270,22 @@ namespace rld
::unlink (name_.path ().c_str ());
+ try
+ elf_.end ();
+ std::cerr << "error: rld::files::image:::~image: "
+ << std::endl;
+ catch (...)
+ std::cerr << "error: rld::files::image:::~image: unhandled exception"
+ << std::endl;
void
@@ -537,8 +555,22 @@ namespace rld
archive::~archive ()
- end ();
- close ();
+ try
+ end ();
+ close ();
+ std::cerr << "error: rld::files::archive::~archive: "
+ << std::endl;
+ catch (...)
+ std::cerr << "error: rld::files::archive::~archive: unhandled exception"
+ << std::endl;
void
@@ -960,8 +992,22 @@ namespace rld
object::~object ()
- end ();
- close ();
+ try
+ end ();
+ close ();
+ std::cerr << "error: rld::files::object::~object: "
+ << std::endl;
+ catch (...)
+ std::cerr << "error: rld::files::object::~object: unhandled exception"
+ << std::endl;
void
@@ -1318,7 +1364,21 @@ namespace rld
cache::~cache ()
- close ();
+ try
+ close ();
+ std::cerr << "error: rld::files:cache::~cache: "
+ << std::endl;
+ catch (...)
+ std::cerr << "error: rld::files::cache::~cache: unhandled exception"
+ << std::endl;
void
2.15.1
