[GSOC - Tracing] Status Update
Vidushi Vashishth reachvidu at gmail.com
Thu Jun 28 17:41:41 UTC 2018
>Could you please create a self-contained repository which contains
>* a README
>* a simple RTEMS application which runs on a simulator BSP
>* the stuff that makes it possible to view the trace output (it is not a
problem if it doesn't work, but all pieces should be included)
>The repository should not be a clone of some larger project. It may
contain external references as submodules.
Okay. Got it. I will update you when its done.
>Did you modify babeltrace?
No I did not.
>Why do you need a very recent babeltrace for your work?
I haven't tested the code with other versions of babeltrace. I cant say why
it does not work with others. I ll try to test the code with other versions
and identify what's wrong.
> Is visualization with Trace Compass a goal of this project?
No it isn't. Trace generation in CTF is a goal.
On Thu, Jun 28, 2018 at 11:43 AM, Sebastian Huber <
> On 28/06/18 07:42, Vidushi Vashishth wrote:
>> >which use case does this address? What is the connection to an RTEMS
>> application?
>> This converts the trace buffering of the fileio sample testcase output to
>> CTF. This pertains to the function tracing testcase. The CTF stream
>> generated records the entry and exit of the calloc, malloc, realloc and
>> free functions and also the values of the arguments and return values.
> * a README
>> >Why do I need sudo to run the commands?
>> The command needs permission to create a directory for the traces. The
>> command did not work without this.
> It worked without sudo in my clone. Using sudo for this kind of stuff
> would be a very severe usability issue from my point of view.
>> >Why do I need your babeltrace? Not being able to use a tool from a
>> standard distribution makes it harder to do RTEMS tracing.
>> I wanted to work on integrating barectf with RTEMS trace linker instead.
>> I documented the approach in: https://vidushivashishth.githu
>> b.io/sixthpost/.
> Could you please also post your stuff on the devel at rtems.org mailing
> list. I don't have time to look for blog posts actively.
> I was stuck on deciding the yaml configuration input for the process and
>> sent out an email for this discussion on the mailing list as well. I have
>> however finally created one. I can continue work on the barectf approach if
>> that is okay with you? I will start a new thread on this with the
>> configuration file I have chosen?
> I need a demo projects which puts all the pieces together. This is all to
> abstract to me.
>> >What can I do with a metadata stream and the CTF trace stream?
>> These can be transported to the host and then viewed using Trace Compass.
>> I lost some time trying to figure things out on my own. I will be more
>> frequent in communicating places where I am stuck. Apologies for the same.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180628/4020e28c/attachment-0002.html>
