patch regarding 'RTEMS not booting with Qemu PREP larger than 256Mb'
Éric Tremblay
e.tremblay at axis-canada.com
Mon Mar 5 20:31:33 UTC 2018
Hi,
I posted a question last week about a strange behavior I was getting using
RTEMS with qemu-system-ppc. Anytime I was specifying more than 256Mb of
memory using the -m option the RTEMS kernel was not booting. Here is an
example of command line I was using:
qemu-system-ppc -M prep -kernel ./hello.ralf -bios
/home/qemu_fakerom/qemu_fakerom.bin -cpu 750cxe -nographic -no-reboot -m 384
Model:
Serial:
Processor/Bus frequencies (Hz): 300000000/100000000
Time Base Divisor: 1000
Memory Size: 18000000
Residual: 102afd4 (length 27148)
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
Kernel at 0x00000000, size=0x495b0
Initrd at 0x00000000, size=0x0
Residual data at 0x0004a000
Command line at 0x00051000
done
*Now booting... <<<<<<<<<<<<<<<< execution
stuck here*
I have spent quite some time debugging this issue and I traced it back to
two issues for which I am submitting a patch. Please understand this is my
first time using RTEMS and debugging a bootloader so my patch might not be
accurate but it does fix the behavior I mentioned above. With this patch I
can successfully launch a "Hello World" and specify more memory (-m 512 for
example).
My patch is quite simple since it simply allows the system to access
section of memory. Please let me know if this is a suitable correction, if
this is totally wrong I would like to know how this could be fixed since
our application will use around 512Mb of memory and the current state of
things won't work.
Thank you for your cooperation,
Eric
PS: I am using RTEMS release 4.11.3.
I am using Qemu v 2.5.0
I am running in a Linux Ubuntu VM (intel 64 bits)
c/src/lib/libbsp/powerpc/shared/start/start.S | 18 ++++++++++++++++++
c/src/lib/libbsp/powerpc/shared/startup/bspstart.c | 18 ++++++++++++++++++
2 files changed, 36 insertions(+)
diff --git a/c/src/lib/libbsp/powerpc/shared/start/start.S
b/c/src/lib/libbsp/powerpc/shared/start/start.S
index 729c89c40b..532c1f9ee4 100644
--- a/c/src/lib/libbsp/powerpc/shared/start/start.S
+++ b/c/src/lib/libbsp/powerpc/shared/start/start.S
@@ -93,6 +93,24 @@ __rtems_entry_point:
mtspr IBAT0L,r8
mtspr IBAT0U,r11
isync
+/* Map section where residual is located if outside
+ * the first 256Mb of RAM. This is to support cases
+ * where the user supplies the -m option with Qemu
+ * in order to have more memory available to the system.
+ mr r9, r1 /* Get where residual was mapped */
+ lis r12,0xf0000000 at h
+ and r9,r9,r12
+ cmpi 0,1,r9, 0
+ beq skip_BAT1_config
+ isync
+ ori r11,r9,0x1ffe
+ mtspr DBAT1L,r8 /* N.B. 6xx (not 601) have valid */
+ mtspr DBAT1U,r11 /* bit in upper BAT register */
+ mtspr IBAT1L,r8
+ mtspr IBAT1U,r11
+ isync
+skip_BAT1_config:
* we now have the 1st 256M of ram mapped with the bats. We are still
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
index 5a97cc8531..f80835b117 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
@@ -300,6 +300,24 @@ void bsp_start( void )
_BSP_clear_hostbridge_errors(0 /* enableMCP */, 0/*quiet*/);
+ if (BSP_mem_size > 0x10000000)
+ /* Support cases with qemu supplied -m option and mem size larger than
256Mb.
+ * We use BAT3 in order to obtain access to the top section of the RAM.
+ * We also need to do this just before setting up the page table because
+ * this is where the page table will be located.
+ const unsigned int mem256Count = (BSP_mem_size / 0x10000000);
+ const unsigned int BAT3Addr = ((BSP_mem_size % 0x10000000) ?
+ (mem256Count * 0x10000000) :
+ ((mem256Count-1) * 0x10000000));
+ setdbat(3, BAT3Addr, BAT3Addr, 0x10000000, IO_PAGE);
+#ifdef SHOW_MORE_INIT_SETTINGS
+ printk("Setting up BAT3 for large memory support. (BAT3 -->
0x%x)\n", BAT3Addr);
+#endif
/* Allocate and set up the page table mappings
* This is only available on >604 CPUs.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180305/a2141afd/attachment-0001.html>
