[PATCH] CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER
Sebastian Huber
Tue Mar 6 07:08:31 UTC 2018
Update #3320.
c-user/configuring_a_system.rst | 97 +++++++++++++++++++++++++++++++++++------
1 file changed, 84 insertions(+), 13 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 52d667a..6b7f487 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -3854,15 +3854,22 @@ DESCRIPTION:
application wishes to include the Console Device Driver.
NOTES:
- This device driver is responsible for providing standard input and output
- using */dev/console*.
+ This device driver is responsible for providing the :file:`/dev/console`
+ device file. This device is used to initialize the standard input, output,
+ and error file descriptors.
BSPs should be constructed in a manner that allows ``printk()`` to work
properly without the need for the console driver to be configured.
- The ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option is
- mutually exclusive with the
- ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration option.
+ The
+ * ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``,
+ * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``, and
+ * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
+ configuration options are mutually exclusive.
.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
@@ -3888,16 +3895,80 @@ DESCRIPTION:
application wishes to include the Simple Console Device Driver.
NOTES:
+ This device driver reads via ``getchark()``.
+ This device driver writes via ``rtems_putc()``.
+ The Termios framework is not used. There is no support to change device
+ settings, e.g. baud, stop bits, parity, etc.
+ The
+.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+CONSTANT:
+ ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER`` is defined if
+ the application wishes to include the Simple Task Console Device Driver.
+NOTES:
+ This device driver writes into a write buffer. The count of characters
+ written into the write buffer is returned. It might be less than the
+ requested count, in case the write buffer is full. The write is
+ non-blocking and may be called from interrupt context. A dedicated task
+ reads from the write buffer and outputs the characters via
+ ``rtems_putc()``. This task runs with the least important priority. The
+ write buffer size is 2047 characters and it is not configurable.
+ Use ``fsync(STDOUT_FILENO)`` or ``fdatasync(STDOUT_FILENO)`` to drain the
+ write buffer.
+ The
- This device driver writes via ``rtems_putc()`` and reads via
- ``getchark()``. The Termios framework is not used. There is no support to
- change device settings, e.g. baud, stop bits, parity, etc.
- The ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration
- option is mutually exclusive with the
- ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option.
.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
2.12.3
