potential deadlock in _once
Tue Mar 6 10:18:49 UTC 2018
On 04/03/18 22:09, Passas, Stavros wrote:
> Hi,
> We have faced RTEMS threads getting locked up when using certain c++
> functionality.
> Issue happens for example when std::future is combined with std::async.
> Investigating deeper, seems like this happens if std::async executes
> before std::future gets scheduled to run. Both of these create a
> pthread_once instance. _once uses a common semaphore for all calls,
> thus the first function (async.get usually) gets the lock, calls its
> “init” function (which blocks until the second function has completed,
> while std::future also uses pthread_once to create a new thread, but
> because the lock is already taken, it blocks, casing a deadlock
> between these two functions.
> Is this a known issue?
No.
> If not, should I create a ticket about it?
Yes, please open a ticket and provide a test case for the RTEMS test
suite. Maybe we have to use dedicated mutexes for each pthread_once_t
object. This is what Linux and FreeBSD do. This would require a Newlib
update.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
