RFC: Remove score/cpu/.../types.h
Joel Sherrill
joel at rtems.org
Wed Mar 7 19:06:50 UTC 2018
Hi
The discussion over adding paravirt.h and tinkering at that level
made me realize that the score/cpu/.../types.h files are very small.
They only have the CPU_Uint32ptr type plus sometimes some
odd things like blackfin_isr_entry (unused).
If CPU_Uint32ptr is moved to cpu.h, then the other contents have
to be evaluated on a per file basis. But on first review, most of the
files would be easy to eliminate. In some cases, another typedef
would move to cpu.h.
Thoughts/comments?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180307/5d754ae0/attachment.html>
