[PATCH] cpukit/mttpd: Add a callback to generate a per file HTTP etag.
Chris Johns
chrisj at rtems.org
Thu Mar 8 04:13:36 UTC 2018
Closes #3323
cpukit/mghttpd/mongoose.c | 19 +++++++++++++------
cpukit/mghttpd/mongoose.h | 13 +++++++++++++
2 files changed, 26 insertions(+), 6 deletions(-)
diff --git a/cpukit/mghttpd/mongoose.c b/cpukit/mghttpd/mongoose.c
index dd243d3320..911ca64767 100644
--- a/cpukit/mghttpd/mongoose.c
+++ b/cpukit/mghttpd/mongoose.c
@@ -2989,10 +2989,16 @@ static void gmt_time_string(char *buf, size_t buf_len, time_t *t) {
strftime(buf, buf_len, "%a, %d %b %Y %H:%M:%S GMT", gmtime(t));
-static void construct_etag(char *buf, size_t buf_len,
+static void construct_etag(const struct mg_connection *conn, const char *path,
+ char *buf, size_t buf_len,
const struct file *filep) {
- snprintf(buf, buf_len, "\"%lx.%" INT64_FMT "\"",
- (unsigned long) filep->modification_time, filep->size);
+ if (conn->ctx->callbacks.http_etag != NULL &&
+ conn->ctx->callbacks.http_etag(conn, path, buf, buf_len)) {
+ else {
+ snprintf(buf, buf_len, "\"%lx.%" INT64_FMT "\"",
+ (unsigned long) filep->modification_time, filep->size);
static void fclose_on_exec(struct file *filep) {
@@ -3061,7 +3067,7 @@ static void handle_file_request(struct mg_connection *conn, const char *path,
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec3.html#sec3.3
gmt_time_string(date, sizeof(date), &curtime);
gmt_time_string(lm, sizeof(lm), &filep->modification_time);
- construct_etag(etag, sizeof(etag), filep);
+ construct_etag(conn, path, etag, sizeof(etag), filep);
(void) mg_printf(conn,
"HTTP/1.1 %d %s\r\n"
@@ -3221,11 +3227,12 @@ static int substitute_index_file(struct mg_connection *conn, char *path,
// Return True if we should reply 304 Not Modified.
static int is_not_modified(const struct mg_connection *conn,
+ const char *path,
char etag[64];
const char *ims = mg_get_header(conn, "If-Modified-Since");
const char *inm = mg_get_header(conn, "If-None-Match");
return (inm != NULL && !mg_strcasecmp(etag, inm)) ||
(ims != NULL && filep->modification_time <= parse_date_string(ims));
@@ -4591,7 +4598,7 @@ static void handle_request(struct mg_connection *conn) {
strlen(conn->ctx->config[SSI_EXTENSIONS]),
path) > 0) {
handle_ssi_file_request(conn, path);
- } else if (is_not_modified(conn, &file)) {
+ } else if (is_not_modified(conn, path, &file)) {
send_http_error(conn, 304, "Not Modified", "%s", "");
} else {
handle_file_request(conn, path, &file);
diff --git a/cpukit/mghttpd/mongoose.h b/cpukit/mghttpd/mongoose.h
index ad7c40f2dd..787922a983 100644
--- a/cpukit/mghttpd/mongoose.h
+++ b/cpukit/mghttpd/mongoose.h
@@ -124,6 +124,19 @@ struct mg_callbacks {
// Parameters:
// status: HTTP error status code.
int (*http_error)(struct mg_connection *, int status);
+ // Called when mongoose needs to generate an HTTP etag.
+ // Implementing this callback allows a custom etag to be generated. If
+ // not implemented the standard etag generator is used which is the
+ // modification time as a hex value and the file size.
+ // Use this callback if the modification time cannot be controlled.
+ // Parameters:
+ // path: path to the file being requested
+ // etag: buffer to write the etag into
+ // etag_len: the length of the etag buffer
+ // Return value:
+ int (*http_etag)(const struct mg_connection *,
+ const char *path, char *etag, size_t etag_len);
// Start web server.
2.14.1
