[PATCH 1/2] config: Simplify clustered scheduler configuration
Thu Mar 8 07:06:34 UTC 2018
Do not use names derived from scheduler implementation details.  Instead
use names derived from the scheduler configuration or documentation.
Provide defines for backward compatibility.
Update #3325.
 cpukit/include/rtems/confdefs.h  | 151 +++++++++++++++++++++------------------
 cpukit/include/rtems/scheduler.h | 108 +++++++++++++++++++++++-----
 2 files changed, 173 insertions(+), 86 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 04b9708aca..bbcfb612ff 100755
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -709,11 +709,26 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * An application can define its own scheduling policy by defining
  * CONFIGURE_SCHEDULER_USER and the following:
- *    - CONFIGURE_SCHEDULER_CONTEXT
- *    - CONFIGURE_SCHEDULER_CONTROLS
+ *    - CONFIGURE_SCHEDULER
+ *    - CONFIGURE_SCHEDULER_TABLE_ENTRIES
  *    - CONFIGURE_SCHEDULER_USER_PER_THREAD
+#ifdef CONFIGURE_SCHEDULER_CONTEXT
+  #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
+#endif
+#ifdef CONFIGURE_SCHEDULER_CONTROLS
+  #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
+#endif
+#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+  #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+#endif
 #if !defined(CONFIGURE_SCHEDULER_USER) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
@@ -750,16 +765,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'D', ' ')
   #endif
-  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
+  #if !defined(CONFIGURE_SCHEDULER_TABLE_ENTRIES)
     /** Configure the context needed by the scheduler instance */
-    #define CONFIGURE_SCHEDULER_CONTEXT \
+    #define CONFIGURE_SCHEDULER \
       RTEMS_SCHEDULER_CONTEXT_PRIORITY( \
         dflt, \
         CONFIGURE_MAXIMUM_PRIORITY + 1 \
     /** Configure the controls for this scheduler instance */
-    #define CONFIGURE_SCHEDULER_CONTROLS \
+    #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
       RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -774,16 +789,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'D', ' ')
   #endif
       RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( \
         dflt, \
       RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -798,16 +813,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'A', ' ')
   #endif
       RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( \
         dflt, \
       RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( \
         dflt, \
         CONFIGURE_SCHEDULER_NAME \
@@ -825,16 +840,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'A', 'P', 'A')
   #endif
       RTEMS_SCHEDULER_CONTEXT_STRONG_APA( \
         dflt, \
       RTEMS_SCHEDULER_CONTROL_STRONG_APA(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -848,12 +863,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'S', ' ')
   #endif
-    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt)
+    #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt)
       RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -867,13 +882,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'S', ' ')
   #endif
       RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(dflt)
       RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -887,12 +902,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'E', 'D', 'F')
   #endif
-    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF(dflt)
+    #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CONTEXT_EDF(dflt)
       RTEMS_SCHEDULER_CONTROL_EDF(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -906,13 +921,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'E', 'D', 'F')
   #endif
       RTEMS_SCHEDULER_CONTEXT_EDF_SMP(dflt, CONFIGURE_MAXIMUM_PROCESSORS)
       RTEMS_SCHEDULER_CONTROL_EDF_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
 #endif
@@ -926,12 +941,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'C', 'B', 'S')
   #endif
-    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_CBS(dflt)
+    #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CONTEXT_CBS(dflt)
       RTEMS_SCHEDULER_CONTROL_CBS(dflt, CONFIGURE_SCHEDULER_NAME)
   #endif
@@ -953,12 +968,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * this code to know which scheduler is configured by the user.
 #ifdef CONFIGURE_INIT
-  #if defined(CONFIGURE_SCHEDULER_CONTEXT)
-    CONFIGURE_SCHEDULER_CONTEXT;
+  #if defined(CONFIGURE_SCHEDULER)
+    CONFIGURE_SCHEDULER;
   #endif
   const Scheduler_Control _Scheduler_Table[] = {
+    CONFIGURE_SCHEDULER_TABLE_ENTRIES
   #define CONFIGURE_SCHEDULER_COUNT RTEMS_ARRAY_SIZE( _Scheduler_Table )
@@ -967,109 +982,109 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     const size_t _Scheduler_Count = CONFIGURE_SCHEDULER_COUNT;
     const Scheduler_Assignment _Scheduler_Initial_assignments[] = {
-      #if defined(CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS)
-        CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+      #if defined(CONFIGURE_SCHEDULER_ASSIGNMENTS)
+        CONFIGURE_SCHEDULER_ASSIGNMENTS
       #else
-        #define _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT \
+        #define _CONFIGURE_SCHEDULER_ASSIGN \
           RTEMS_SCHEDULER_ASSIGN( \
             0, \
             RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
-        _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+        _CONFIGURE_SCHEDULER_ASSIGN
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 2
-          , _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+          , _CONFIGURE_SCHEDULER_ASSIGN
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 3
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 4
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 5
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 6
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 7
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 8
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 9
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 10
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 11
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 12
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 13
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 14
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 15
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 16
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 17
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 18
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 19
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 20
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 21
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 22
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 23
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 24
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 25
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 26
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 27
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 28
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 29
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 30
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 31
         #endif
         #if CONFIGURE_MAXIMUM_PROCESSORS >= 32
         #endif
-        #undef _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+        #undef _CONFIGURE_SCHEDULER_ASSIGN
       #endif
diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
index b8ad83ee92..336ca71fe6 100644
--- a/cpukit/include/rtems/scheduler.h
+++ b/cpukit/include/rtems/scheduler.h
@@ -63,16 +63,24 @@
   #define SCHEDULER_CBS_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( CBS_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_CBS( name ) \
+  #define RTEMS_SCHEDULER_CBS( name ) \
     static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_CBS( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_CBS( name, obj_name ) \
       &SCHEDULER_CBS_CONTEXT_NAME( name ).Base, \
       SCHEDULER_CBS_ENTRY_POINTS, \
       SCHEDULER_CBS_MAXIMUM_PRIORITY, \
       ( obj_name ) \
+  /* Provided for backward compatibility */
+  #define RTEMS_SCHEDULER_CONTEXT_CBS( name ) \
+    RTEMS_SCHEDULER_CBS( name )
+  #define RTEMS_SCHEDULER_CONTROL_CBS( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_CBS( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_EDF
@@ -81,16 +89,24 @@
   #define SCHEDULER_EDF_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( EDF_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_EDF( name ) \
+  #define RTEMS_SCHEDULER_EDF( name ) \
     static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_EDF( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_EDF( name, obj_name ) \
       &SCHEDULER_EDF_CONTEXT_NAME( name ).Base, \
       SCHEDULER_EDF_ENTRY_POINTS, \
       SCHEDULER_EDF_MAXIMUM_PRIORITY, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_EDF( name ) \
+    RTEMS_SCHEDULER_EDF( name )
+  #define RTEMS_SCHEDULER_CONTROL_EDF( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_EDF( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_EDF_SMP
@@ -99,19 +115,27 @@
   #define SCHEDULER_EDF_SMP_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name, max_cpu_count ) \
+  #define RTEMS_SCHEDULER_EDF_SMP( name, max_cpu_count ) \
     static struct { \
       Scheduler_EDF_SMP_Context Base; \
       Scheduler_EDF_SMP_Ready_queue Ready[ ( max_cpu_count ) + 1 ]; \
     } SCHEDULER_EDF_SMP_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_EDF_SMP( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name ) \
       &SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
       SCHEDULER_EDF_SMP_ENTRY_POINTS, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name, max_cpu_count ) \
+    RTEMS_SCHEDULER_EDF_SMP( name, max_cpu_count )
+  #define RTEMS_SCHEDULER_CONTROL_EDF_SMP( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_PRIORITY
@@ -120,13 +144,13 @@
   #define SCHEDULER_PRIORITY_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( priority_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY( name, prio_count ) \
+  #define RTEMS_SCHEDULER_PRIORITY( name, prio_count ) \
     static struct { \
       Scheduler_priority_Context Base; \
       Chain_Control              Ready[ ( prio_count ) ]; \
     } SCHEDULER_PRIORITY_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_PRIORITY( name, obj_name ) \
       &SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Base.Base, \
       SCHEDULER_PRIORITY_ENTRY_POINTS, \
@@ -135,6 +159,14 @@
       ) - 1, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY( name, prio_count ) \
+    RTEMS_SCHEDULER_PRIORITY( name, prio_count )
+  #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_PRIORITY( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
@@ -143,13 +175,13 @@
   #define SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( priority_affinity_SMP_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( name, prio_count ) \
+  #define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( name, prio_count ) \
     static struct { \
       Scheduler_priority_SMP_Context Base; \
     } SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( name, obj_name ) \
       &SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
       SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
@@ -158,6 +190,14 @@
       ) - 1, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( name, prio_count ) \
+    RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( name, prio_count )
+  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
@@ -166,13 +206,13 @@
   #define SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( priority_SMP_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( name, prio_count ) \
+  #define RTEMS_SCHEDULER_PRIORITY_SMP( name, prio_count ) \
     static struct { \
     } SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( name, obj_name ) \
       &SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
       SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
@@ -181,6 +221,14 @@
       ) - 1, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( name, prio_count ) \
+    RTEMS_SCHEDULER_PRIORITY_SMP( name, prio_count )
+  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_STRONG_APA
@@ -189,13 +237,13 @@
   #define SCHEDULER_STRONG_APA_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_STRONG_APA( name, prio_count ) \
+  #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
     static struct { \
       Scheduler_strong_APA_Context Base; \
     } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
-  #define RTEMS_SCHEDULER_CONTROL_STRONG_APA( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
       &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
       SCHEDULER_STRONG_APA_ENTRY_POINTS, \
@@ -204,6 +252,14 @@
       ) - 1, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_STRONG_APA( name, prio_count ) \
+    RTEMS_SCHEDULER_STRONG_APA( name, prio_count )
+  #define RTEMS_SCHEDULER_CONTROL_STRONG_APA( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_SIMPLE
@@ -212,17 +268,25 @@
   #define SCHEDULER_SIMPLE_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( simple_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_SIMPLE( name ) \
+  #define RTEMS_SCHEDULER_SIMPLE( name ) \
     static Scheduler_simple_Context \
-  #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_SIMPLE( name, obj_name ) \
       &SCHEDULER_SIMPLE_CONTEXT_NAME( name ).Base, \
       SCHEDULER_SIMPLE_ENTRY_POINTS, \
       SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_SIMPLE( name ) \
+    RTEMS_SCHEDULER_SIMPLE( name )
+  #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_SIMPLE( name, obj_name )
 #endif
 #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
@@ -231,17 +295,25 @@
   #define SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ) \
     SCHEDULER_CONTEXT_NAME( simple_SMP_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( name ) \
+  #define RTEMS_SCHEDULER_SIMPLE_SMP( name ) \
     static Scheduler_simple_SMP_Context \
-  #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name, obj_name ) \
+  #define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( name, obj_name ) \
       &SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ).Base.Base, \
       SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
       SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
       ( obj_name ) \
+  #define RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( name ) \
+    RTEMS_SCHEDULER_SIMPLE_SMP( name )
+  #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name, obj_name ) \
+    RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( name, obj_name )
 #endif
 #endif /* _RTEMS_SAPI_SCHEDULER_H */
2.12.3
