[PATCH] cpu-supplement: Add ARM BSPs chapter
Sebastian Huber
Fri Mar 9 08:55:07 UTC 2018
On 06/11/17 10:03, Sebastian Huber wrote:
> On 26/10/17 08:22, Sebastian Huber wrote:
>> Please review this patch carefully. It adds a new chapter "ARM Board
>> Support Packages" following the "ARM Specific Information" chapter.
>> It adds a template structure for other BSPs.
>> Where should we place common BSP configuration options like
>> BSP_PRESS_KEY_FOR_RESET? We probably don't want to add a copy and
>> paste version to every BSP section.
> Any comments with respect to the BSP documentation? It makes little
> sense to start with this work if the general direction is unclear.
The insufficient and user unfriendly BSP documentation is still a big
issue from my point of view. I think it is one of be biggest obstacles
to get started with RTEMS. The BSP documentation should be part of a
sphinx based rtems-docs manual.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
