[PATCH 03/19] i386/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:19:51 UTC 2018
Updates #3327.
 cpukit/score/cpu/i386/cpu.c                       |  1 -
 cpukit/score/cpu/i386/headers.am                  |  1 -
 cpukit/score/cpu/i386/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/i386/include/rtems/score/types.h | 46 -----------------------
 4 files changed, 4 insertions(+), 49 deletions(-)
 delete mode 100644 cpukit/score/cpu/i386/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
index c9434f7..b591b76 100644
--- a/cpukit/score/cpu/i386/cpu.c
+++ b/cpukit/score/cpu/i386/cpu.c
@@ -21,7 +21,6 @@
-#include <rtems/score/types.h>
 #include <rtems/score/isr.h>
 #include <rtems/score/idtr.h>
 #include <rtems/score/tls.h>
diff --git a/cpukit/score/cpu/i386/headers.am b/cpukit/score/cpu/i386/headers.am
index ea07edc..ab47f9a 100644
--- a/cpukit/score/cpu/i386/headers.am
+++ b/cpukit/score/cpu/i386/headers.am
@@ -17,4 +17,3 @@ include_rtems_score_HEADERS += include/rtems/score/i386.h
 include_rtems_score_HEADERS += include/rtems/score/idtr.h
 include_rtems_score_HEADERS += include/rtems/score/interrupts.h
 include_rtems_score_HEADERS += include/rtems/score/registers.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index f78149c..058d254 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -27,7 +27,7 @@
 extern "C" {
 #endif
+#include <rtems/score/basedefs.h>
 #include <rtems/score/i386.h>
 /* conditional compilation parameters */
@@ -691,6 +691,9 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/i386/include/rtems/score/types.h b/cpukit/score/cpu/i386/include/rtems/score/types.h
deleted file mode 100644
index 00555d4..0000000
--- a/cpukit/score/cpu/i386/include/rtems/score/types.h
+++ /dev/null
@@ -1,46 +0,0 @@
- * @file
- * @brief Intel I386 CPU Type Definitions
- * This include file contains type definitions pertaining to the Intel
- * i386 processor family.
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-typedef void i386_isr;
-typedef i386_isr ( *i386_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
