no-preinstall: Ready to merge
Mon Mar 12 06:23:38 UTC 2018
Hello Amaan,
On 11/03/18 13:27, Amaan Cheval wrote:
> The docs haven't been updated to reflect the new "bootstrap -H"
> option, even on master[1], by the way. It seems like "./bootstrap -p"
> has been replaced with "./bootstrap -g" followed by "./bootstrap -H".
> Is that right?
The "./boostrap -p"  was more or less replaced by "./bootstrap -H". This
sub-command is for RTEMS developers not users.
I think the standard way to bootstrap the sources is now via
$RSB/source-builder/sb-bootstrap.
> I can look into updating the docs if there aren't already any patches
> out there and what I said above sounds correct. The bootstrap script's
> "-h" help message doesn't mention "-g" or "-r" either, so I'll
> probably update that as well, if that wasn't intentional.
> P.S. - Brilliant work here! Seems like a behemoth of a task! :D
> [1]
> https://git.rtems.org/rtems-docs/tree/user/installation/developer.rst#n483
> (and a few other references similarly)
> On Thu, Jan 25, 2018 at 2:49 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello,
>     I checked in the no-preinstall patch:
>     https://git.rtems.org/rtems/commit/?id=2afb22b7e1ebcbe40373ff7e0efae7d207c655a9
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
