[PATCH 1/7] bsps: Remove unused memcpy() implementations
Sebastian Huber
Mon Mar 12 10:25:19 UTC 2018
Update #3285.
c/src/lib/libcpu/lm32/Makefile.am | 18 ---------------
c/src/lib/libcpu/lm32/configure.ac | 35 -----------------------------
c/src/lib/libcpu/lm32/shared/misc/memcpy.c | 21 -----------------
c/src/lib/libcpu/nios2/Makefile.am | 18 ---------------
c/src/lib/libcpu/nios2/configure.ac | 35 -----------------------------
c/src/lib/libcpu/nios2/shared/misc/memcpy.c | 21 -----------------
6 files changed, 148 deletions(-)
delete mode 100644 c/src/lib/libcpu/lm32/Makefile.am
delete mode 100644 c/src/lib/libcpu/lm32/configure.ac
delete mode 100644 c/src/lib/libcpu/lm32/shared/misc/memcpy.c
delete mode 100644 c/src/lib/libcpu/nios2/Makefile.am
delete mode 100644 c/src/lib/libcpu/nios2/configure.ac
delete mode 100644 c/src/lib/libcpu/nios2/shared/misc/memcpy.c
diff --git a/c/src/lib/libcpu/lm32/Makefile.am b/c/src/lib/libcpu/lm32/Makefile.am
deleted file mode 100644
index 7c1ce064d5..0000000000
--- a/c/src/lib/libcpu/lm32/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-include $(top_srcdir)/../../../automake/compile.am
-CLEANFILES =
-DISTCLEANFILES =
-noinst_PROGRAMS =
-if shared
-## shared/misc
-noinst_PROGRAMS += shared/misc.rel
-shared_misc_rel_SOURCES = shared/misc/memcpy.c
-shared_misc_rel_CPPFLAGS = $(AM_CPPFLAGS) $(LM32_CPPFLAGS)
-shared_misc_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
-include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libcpu/lm32/configure.ac b/c/src/lib/libcpu/lm32/configure.ac
index 295ae91ee2..0000000000
--- a/c/src/lib/libcpu/lm32/configure.ac
+++ /dev/null
@@ -1,35 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libcpu-lm32],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-RTEMS_TOP([../../../../..],[../../..])
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-RTEMS_PROJECT_ROOT
-RTEMS_PROG_CC_FOR_TARGET
-AM_PROG_CC_C_O
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-# At this time all models should use the shared directory so do this
-AM_CONDITIONAL(shared, true)
-AC_PATH_PROG([AMPOLISH3],[ampolish3],[])
-AM_CONDITIONAL([AMPOLISH3],[test x"$USE_MAINTAINER_MODE" = x"yes" \
- && test -n "$AMPOLISH3"])
-RTEMS_AMPOLISH3
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile
-AC_OUTPUT
diff --git a/c/src/lib/libcpu/lm32/shared/misc/memcpy.c b/c/src/lib/libcpu/lm32/shared/misc/memcpy.c
index 5c5762d8cc..0000000000
--- a/c/src/lib/libcpu/lm32/shared/misc/memcpy.c
+++ /dev/null
@@ -1,21 +0,0 @@
- * C library memcpy routine
- * This routine shall get code to optimize performance on NIOS II
- * The routine is placed in this source directory to ensure that it
- * is picked up by all applications.
-#include <string.h>
-void *
-memcpy(void *s1, const void *s2, size_t n)
- char *p1 = s1;
- const char *p2 = s2;
- size_t left = n;
- while(left > 0) *(p1++) = *(p2++);
- return s1;
diff --git a/c/src/lib/libcpu/nios2/Makefile.am b/c/src/lib/libcpu/nios2/Makefile.am
index d5bfc578c3..0000000000
--- a/c/src/lib/libcpu/nios2/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-CLEANFILES =
-DISTCLEANFILES =
-noinst_PROGRAMS =
-if shared
-## shared/misc
-shared_misc_rel_CPPFLAGS = $(AM_CPPFLAGS) $(NIOS2_CPPFLAGS)
-endif
diff --git a/c/src/lib/libcpu/nios2/configure.ac b/c/src/lib/libcpu/nios2/configure.ac
index ce7fe1b4e9..0000000000
--- a/c/src/lib/libcpu/nios2/configure.ac
+++ /dev/null
@@ -1,35 +0,0 @@
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libcpu-nios2],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-RTEMS_PROJECT_ROOT
-AM_PROG_CC_C_O
-RTEMS_PROG_CCAS
-RTEMS_AMPOLISH3
-AC_OUTPUT
diff --git a/c/src/lib/libcpu/nios2/shared/misc/memcpy.c b/c/src/lib/libcpu/nios2/shared/misc/memcpy.c
index ceae3c6548..0000000000
--- a/c/src/lib/libcpu/nios2/shared/misc/memcpy.c
+++ /dev/null
@@ -1,21 +0,0 @@
-void *
- char *p1 = s1;
- size_t left = n;
- return s1;
2.12.3
