[PATCH] libfs/jffs2: Force the inode size to a non-zero value if a directory.
Tue Mar 13 06:47:01 UTC 2018
On 13/03/2018 17:18, Sebastian Huber wrote:
> On 13/03/18 00:49, Chris Johns wrote:
>> Set the inode size to 256 to work around a newlib scandir check where a
>> directory has to have a non-zero size to work. Set the size to greater than
>> 24 bytes, a small dirent size so the allocator in scandir works.
>> The newlib scandir code should be updated to a more recent scandir from
>> FreeBSD where these checks have been removed. This change is a work
>> around to avoid new tools on the release branch.
>> With this change scandir works on IMFS, RFS and JFFS2.
> I cannot find a scandir() test in the fstests for all file systems.
>> Closes #3332
>>   cpukit/libfs/src/jffs2/src/fs-rtems.c | 3 +++
>>   1 file changed, 3 insertions(+)
>> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>> b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>> index ce84d44470..790929d856 100644
>> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>> @@ -1512,6 +1512,9 @@ static int jffs2_read_inode (struct _inode *inode)
>>       inode->i_mtime = je32_to_cpu(latest_node.mtime);
>>       inode->i_ctime = je32_to_cpu(latest_node.ctime);
>>   +    if (S_ISDIR(inode->i_mode))
>> +        inode->i_size = 256;
>>       inode->i_nlink = f->inocache->pino_nlink;
>>       mutex_unlock(&f->sem);
> This code is from the original JFFS2 support for eCos. Which side-effects has
> this i_size change for directories? Why can't you place this hack in
> rtems_jffs2_fstat()? This would reduce the impact area of this change.
I did not know the history of the RTEMS wrapper. I just assumed all code in that
file is specific to RTEMS. The change I have makes things consistent. I still
think it is OK?
