[PATCH] libfs/jffs2: Force the inode size to a non-zero value if a directory.
Tue Mar 13 06:52:16 UTC 2018
On 13/03/18 07:50, Sebastian Huber wrote:
> On 13/03/18 07:47, Chris Johns wrote:
>> On 13/03/2018 17:18, Sebastian Huber wrote:
>>> On 13/03/18 00:49, Chris Johns wrote:
>>>> Set the inode size to 256 to work around a newlib scandir check
>>>> where a
>>>> directory has to have a non-zero size to work. Set the size to
>>>> greater than
>>>> 24 bytes, a small dirent size so the allocator in scandir works.
>>>> The newlib scandir code should be updated to a more recent scandir
>>>> from
>>>> FreeBSD where these checks have been removed. This change is a work
>>>> around to avoid new tools on the release branch.
>>>> With this change scandir works on IMFS, RFS and JFFS2.
>>> I cannot find a scandir() test in the fstests for all file systems.
>>>> Closes #3332
>>>>    cpukit/libfs/src/jffs2/src/fs-rtems.c | 3 +++
>>>>    1 file changed, 3 insertions(+)
>>>> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>>> b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>>> index ce84d44470..790929d856 100644
>>>> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>>> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>>> @@ -1512,6 +1512,9 @@ static int jffs2_read_inode (struct _inode
>>>> *inode)
>>>>        inode->i_mtime = je32_to_cpu(latest_node.mtime);
>>>>        inode->i_ctime = je32_to_cpu(latest_node.ctime);
>>>>    +    if (S_ISDIR(inode->i_mode))
>>>> +        inode->i_size = 256;
>>>>        inode->i_nlink = f->inocache->pino_nlink;
>>>>        mutex_unlock(&f->sem);
>>> This code is from the original JFFS2 support for eCos. Which
>>> side-effects has
>>> this i_size change for directories? Why can't you place this hack in
>>> rtems_jffs2_fstat()? This would reduce the impact area of this change.
>> I did not know the history of the RTEMS wrapper. I just assumed all
>> code in that
>> file is specific to RTEMS. The change I have makes things consistent.
>> I still
>> think it is OK?
> What do you mean with consistent? I thought this is a hack to make the
> Newlib scandir() happy? This i_size is used in several places. How do
> you know that you didn't accidentally broke something?
We have also this comment:
struct _inode {
     cyg_uint32        i_ino;
     int            i_count;
     mode_t            i_mode;
     nlink_t            i_nlink; // Could we dispense with this?
     uid_t            i_uid;
     gid_t            i_gid;
     time_t            i_atime;
     time_t            i_mtime;
     time_t            i_ctime;
//    union {
         unsigned short    i_rdev; // For devices only
         struct _inode *    i_parent; // For directories only
         off_t        i_size; // For files only
     struct super_block *    i_sb;
     struct jffs2_full_dirent * i_fd;
     struct jffs2_inode_info    jffs2_i;
         struct _inode *        i_cache_prev; // We need doubly-linked?
         struct _inode *        i_cache_next;
Which is no longer valid with this change.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
