[PATCH] openssl: Provide deprecated functions.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Mar 13 14:02:55 UTC 2018
Some applications (like the civetweb web server) still use functions
that are deprecated by openssl. If OPENSSL_NO_DEPRECATED is defined,
openssl will not provide these functions. This patch removes the define
so that the functions are available.
 libbsd.py     | 3 +--
 libbsd_waf.py | 2 +-
 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/libbsd.py b/libbsd.py
index f70b4ead..233c06cd 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -3614,8 +3614,7 @@ def crypto_openssl(mm):
             'crypto/openssl/crypto/cversion.c',
             'crypto/openssl/crypto/o_str.c',
-        mm.generator['source'](['-DOPENSSL_NO_DEPRECATED=1',
-                                '-DOPENSSL_NO_EC_NISTP_64_GCC_128=1',
+        mm.generator['source'](['-DOPENSSL_NO_EC_NISTP_64_GCC_128=1',
                                 '-DOPENSSL_NO_GMP=1',
                                 '-DOPENSSL_NO_JPAKE=1',
                                 '-DOPENSSL_NO_LIBUNBOUND=1',
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 7782bccb..745512bf 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1317,7 +1317,7 @@ def build(bld):
                 features = "c",
                 cflags = cflags,
                 includes = ['freebsd/crypto', 'freebsd/crypto/openssl', 'freebsd/crypto/openssl/crypto', 'freebsd/crypto/openssl/crypto/asn1', 'freebsd/crypto/openssl/crypto/evp', 'freebsd/crypto/openssl/crypto/modes'] + includes,
-                defines = defines + ['NO_WINDOWS_BRAINDEATH=1', 'OPENSSL_DISABLE_OLD_DES_SUPPORT=1', 'OPENSSL_NO_DEPRECATED=1', 'OPENSSL_NO_EC_NISTP_64_GCC_128=1', 'OPENSSL_NO_GMP=1', 'OPENSSL_NO_JPAKE=1', 'OPENSSL_NO_LIBUNBOUND=1', 'OPENSSL_NO_MD2=1', 'OPENSSL_NO_RC5=1', 'OPENSSL_NO_RFC3779=1', 'OPENSSL_NO_SCTP=1', 'OPENSSL_NO_SSL2=1', 'OPENSSL_NO_SSL_TRACE=1', 'OPENSSL_NO_STORE=1', 'OPENSSL_NO_UNIT_TEST=1', 'OPENSSL_NO_WEAK_SSL_CIPHERS=1'],
+                defines = defines + ['NO_WINDOWS_BRAINDEATH=1', 'OPENSSL_DISABLE_OLD_DES_SUPPORT=1', 'OPENSSL_NO_EC_NISTP_64_GCC_128=1', 'OPENSSL_NO_GMP=1', 'OPENSSL_NO_JPAKE=1', 'OPENSSL_NO_LIBUNBOUND=1', 'OPENSSL_NO_MD2=1', 'OPENSSL_NO_RC5=1', 'OPENSSL_NO_RFC3779=1', 'OPENSSL_NO_SCTP=1', 'OPENSSL_NO_SSL2=1', 'OPENSSL_NO_SSL_TRACE=1', 'OPENSSL_NO_STORE=1', 'OPENSSL_NO_UNIT_TEST=1', 'OPENSSL_NO_WEAK_SSL_CIPHERS=1'],
                 source = objs04_source)
     libbsd_use += ["objs04"]
2.13.6
