[PATCH] Added Getentropy() support to beagle BSP
Christian Mauderer list at c-mauderer.de
Tue Mar 13 20:41:15 UTC 2018
Am 13.03.2018 um 15:59 schrieb Udit agarwal:
> Hi,
> I have updated the patch, following were the changes:
> *Removed trialling white spaces and added new line at the end of each file
> *am335x_rng_enable() is now being called only once during initialization.
> *changed  directory to /arm/beagle/dev/bbb_getentropy.c
> *Renamed TRNG register structure as: am335x_trng_register
> I have tested the patch after making above changes and it worked as before.
> I need some suggestion regarding the solution to the problem raised
> during parallel execution of getentropy(),
> In that case, Two processes can actually fetch same random number. I was
> thinking to implement some sort of
> flag set/reset variable in shared memory, which can be used to implement
> a lock for TRNG register access something
> like a binary semaphore.
Hello Udit,
seems to be a small trick question from Sebastian: The processor family
only has single cores. But the problem can occur there too: If a high
prio task interrupts a lower prio task while it is waiting for the flag,
the two tasks might get the same value.
If you protect the critical section with a mutex, that should fix it.
One of the self contained mutexes should be usable here:
https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#mutual-exclusion
By the way: That bug exists on the ATSAM too.
Best regards
Christian Mauderer
> From b10e55c7f5cc8ca95b0d9b6a8cc7b8e37330544b Mon Sep 17 00:00:00 2001
> From: Udit agarwal <dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>
> Date: Tue, 13 Mar 2018 15:50:43 +0530
> Subject: [PATCH] Added getentropy support to Beagle BSP
>  bsps/arm/include/libcpu/am335x.h                 |  33 +++++++
>  c/src/lib/libbsp/arm/beagle/Makefile.am          |   4 +-
>  c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c | 117
>  3 files changed, 153 insertions(+), 1 deletion(-)
>  create mode 100644 c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
> diff --git a/bsps/arm/include/libcpu/am335x.h
> b/bsps/arm/include/libcpu/am335x.h
> index 367e97c..6170ef3 100644
> --- a/bsps/arm/include/libcpu/am335x.h
> +++ b/bsps/arm/include/libcpu/am335x.h
> @@ -14,11 +14,17 @@
>   * Modified by Ben Gras <beng at shrike-systems.com
> <mailto:beng at shrike-systems.com>> to add lots
>   * of beagleboard/beaglebone definitions, delete lpc32xx specific
>   * ones, and merge with some other header files.
> + * Modified by Udit agarwal <dev.madaari at gmail.com
> <mailto:dev.madaari at gmail.com>> to add random
> + * number generating module definitions and TRNG register structure.
>  #if !defined(_AM335X_H_)
>  #define _AM335X_H_
> +/* For TRNG register definition */
> +#include <stdint.h>
>  /* Interrupt controller memory map */
>  #define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
> @@ -701,4 +707,31 @@
>  #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
> (0x00000020u)
>  #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
> +/* TRNG Register */
> +/* RNG base address */
> +#define RNG_BASE 0x48310000
> +/* RNG clock control */
> +#define CM_PER_RNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
> +/* rng module clock status bits */
> +#define AM335X_CLK_RNG_BIT_MASK (0x30000)
> +/* Offset from RNG base for output ready flag */
> +#define RNG_STATUS_RDY (1u <<  0)
> +/* Offset from RNG base for FRO related error */
> +#define RNG_STATUS_ERR (1u <<  1)
> +/* Offset from RNG base for clock status */
> +#define RNG_STATUS_CLK (1u << 31)
> +/* enable module */
> +#define AM335X_RNG_ENABLE (1 << 10)
> +/* TRNG register structure */
> +typedef struct {
> +  uint64_t output;     /* 00 */
> +  uint32_t status;     /* 08 */
> +  uint32_t irq_en;     /* 0c */
> +  uint32_t status_clr; /* 10 */
> +  uint32_t control;    /* 14 */
> +  uint32_t config;     /* 18 */
> +} am335x_trng_register;
>  #endif
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
> b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 8251660..c483dc4 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -40,7 +40,6 @@ libbsp_a_LIBADD =
>  # Shared
>  libbsp_a_SOURCES += ../../shared/bootcard.c
> -libbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
>  libbsp_a_SOURCES += ../../shared/src/bsp-fdt.c
>  libbsp_a_SOURCES += ../../shared/bspclean.c
>  libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
> @@ -88,6 +87,9 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
>  #pwm
>  libbsp_a_SOURCES += pwm/pwm.c
> +#getentropy
> +libbsp_a_SOURCES += dev/bbb_getentropy.c
>  #RTC
>  libbsp_a_SOURCES += rtc.c
>  libbsp_a_SOURCES += ../../shared/tod.c
> diff --git a/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
> b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
> new file mode 100644
> index 0000000..b2aea71
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
> @@ -0,0 +1,117 @@
> +* @file
> +* @ingroup arm_beagle
> +* @brief Getentropy implementation on BeagleBone Black BSP
> +* Copyright (c) 2018 Udit agarwal <dev.madaari at gmail.com
> <http://gmail.com>>
> +* All rights reserved.
> +* Redistribution and use in source and binary forms, with or without
> +* modification, are permitted provided that the following conditions
> +* are met:
> +* 1. Redistributions of source code must retain the above copyright
> +*    notice, this list of conditions and the following disclaimer.
> +* 2. Redistributions in binary form must reproduce the above copyright
> +*    notice, this list of conditions and the following disclaimer in the
> +*    documentation and/or other materials provided with the distribution.
> +* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> +* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +* ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> +* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> +* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> +* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> +* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> +* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> +* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> +* SUCH DAMAGE.
> +#include <libcpu/am335x.h>
> +#include <unistd.h>
> +#include <string.h>
> +#include <rtems/sysinit.h>
> +/* max refill 34 * 256 cycles */
> +#define AM335X_RNG_MAX_REFILL (34 << 16)
> +/* min refill 33 * 64 cycles */
> +#define AM335X_RNG_MIN_REFILL (33 << 0)
> +/* startup 33 * 256 cycles */
> +#define AM335X_RNG_STARTUP_CYCLES (33 << 16)
> +/* maximun and minimum refill cycle sets the number of samples to be taken
> +   from FRO to generate random number */
> +static void am335x_rng_enable(volatile am335x_trng_register *rng)
> +    rng->control = rng->config = 0;
> +    rng->config |= AM335X_RNG_MIN_REFILL | AM335X_RNG_MAX_REFILL ;
> +    rng->control |= AM335X_RNG_STARTUP_CYCLES | AM335X_RNG_ENABLE ;
> +static void am335x_rng_clock_enable(void)
> +    volatile am335x_trng_register  *rng = (am335x_trng_register*) RNG_BASE;
> +    *(volatile uint8_t *) CM_PER_RNG_CLKCTRL = 2;
> +    while(
> +      *(volatile uint32_t *) CM_PER_RNG_CLKCTRL &
> +      AM335X_CLK_RNG_BIT_MASK
> +        /* wait */
> +    am335x_rng_enable(rng);
> +static uint64_t trng_getranddata(volatile am335x_trng_register *rng)
> +    uint64_t output = rng->output;
> +    return output;
> +int getentropy(void *ptr, size_t n)
> +    while (n > 0)
> +        uint64_t random;
> +        size_t copy;
> +        /* wait untill RNG becomes ready with next set of random data */
> +        while( ( rng->status & RNG_STATUS_RDY ) == 0 )
> +            /* wait */
> +        random = trng_getranddata(rng);
> +        /* Checking for error by masking all bits other then error bit in
> +           status register */
> +        if( ((rng->status & RNG_STATUS_ERR)>>1) == 1)
> +            /* clear the status flag after reading to generate new random
> +               value */
> +            rng->status_clr = RNG_STATUS_RDY;
> +            copy = sizeof(random);
> +            if ( n < copy )
> +                copy = n;
> +            memcpy(ptr, &random, copy);
> +            n -= copy;
> +            ptr = (char*)ptr + copy;
> +    return 0;
> +RTEMS_SYSINIT_ITEM(
> +    am335x_rng_clock_enable,
> +    RTEMS_SYSINIT_DEVICE_DRIVERS,
> +    RTEMS_SYSINIT_ORDER_LAST
> 1.9.1
> Regards,
> Udit
> On Tue, Mar 13, 2018 at 12:01 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 12/03/18 20:02, Udit agarwal wrote:
>         So, It looks like here's the final patch, do let me know if its
>         ready to be pushed. Also, it would be really helpful if someone
>         else also tests this patch before pushing(Although i have done
>         that once).
>         Thanks,
>         Udit agarwal
>         From 454a8ff3e0ea3393818859874705a54b098c6081 Mon Sep 17
>         00:00:00 2001
>         <mailto:dev.madaari at gmail.com> <mailto:dev.madaari at gmail.com
>         <mailto:dev.madaari at gmail.com>>>
>         Date: Tue, 13 Mar 2018 00:20:28 +0530
>         Subject: [PATCH] Added Getentropy() support to beagle BSP
>          bsps/arm/include/libcpu/am335x.h                   |  37 ++++++-
>         <http://akefile.am>            |   4 +-
>          .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 116
>          3 files changed, 155 insertions(+), 2 deletions(-)
>          create mode 100644
>         c/src/lib/libbsp/arm/beagle/getentropy/bbb_getentropy.c
>         index 367e97c..cedd637 100644
>         @@ -14,11 +14,17 @@
>         <mailto:beng at shrike-systems.com> <mailto:beng at shrike-systems.com
>         <mailto:beng at shrike-systems.com>>> to add lots
>         <mailto:dev.madaari at gmail.com>>> to add random
>         structure.
>          #define _AM335X_H_
>         address */
>         @@ -701,4 +707,33 @@
>          #define
>         (0x00000020u)
>         -#endif
>         +struct bbb_trng_register
>         +typedef struct bbb_trng_register bbb_trng_register;
>     The bbb (Beagle Bone Black) is a particular board and the AM335X is
>     a SoC family. This should be something like this
>     typedef struct {
>     } am335x_trng;
>         +#endif
>         \ No newline at end of file
>     Git thinks that files should have a newline at the end of the file.
>         index 8251660..5d5ade3 100644
>          # Shared
>          #pwm
>         +#getentropy
>         +libbsp_a_SOURCES += getentropy/bbb_getentropy.c
>     With the new BSP source structure
>     https://devel.rtems.org/ticket/3285
>     <https://devel.rtems.org/ticket/3285>
>     this new file could be also placed at
>     bsps/arm/beagle/dev/getentropy.c
>         +    volatile bbb_trng_register  *rng = (bbb_trng_register*)
>         RNG_BASE;
>         +    while (n > 0)
>         +        uint64_t random;
>         +        size_t copy;
>         random data */
>         +            /* wait */
>     What happens if you call this function in parallel on different
>     processors?
>         error bit in
>         new random
>         +               value */
>         +            if ( n < copy )
>         +                copy = n;
>         +            n -= copy;
>         +    return 0;
>         1.9.1
>         _______________________________________________
>         devel mailing list
>         devel at rtems.org <mailto:devel at rtems.org>
>         http://lists.rtems.org/mailman/listinfo/devel
>         <http://lists.rtems.org/mailman/listinfo/devel>
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>     Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
