[PATCH 5/5] bsp/ss555: Move libcpu content to bsps
Wed Mar 14 07:21:16 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 .../clock => bsps/powerpc/ss555/dev}/clock.c       |  0
 .../powerpc/ss555/dev}/console-generic.c           |  0
 .../timer => bsps/powerpc/ss555/dev}/timer.c       |  0
 .../mpc5xx/irq => bsps/powerpc/ss555/start}/irq.c  |  0
 .../irq => bsps/powerpc/ss555/start}/irq_asm.S     |  0
 .../irq => bsps/powerpc/ss555/start}/irq_init.c    |  0
 .../powerpc/ss555/start}/raw_exception.c           |  0
 c/src/lib/libbsp/powerpc/ss555/Makefile.am         | 14 ++--
 c/src/lib/libbsp/powerpc/ss555/README              | 24 +++++++
 c/src/lib/libcpu/powerpc/Makefile.am               | 35 ----------
 c/src/lib/libcpu/powerpc/mpc5xx/README             | 23 -------
 c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c      | 68 --------------------
 c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h      | 75 ----------------------
 13 files changed, 31 insertions(+), 208 deletions(-)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/clock => bsps/powerpc/ss555/dev}/clock.c (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/console-generic => bsps/powerpc/ss555/dev}/console-generic.c (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/timer => bsps/powerpc/ss555/dev}/timer.c (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/irq => bsps/powerpc/ss555/start}/irq.c (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/irq => bsps/powerpc/ss555/start}/irq_asm.S (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/irq => bsps/powerpc/ss555/start}/irq_init.c (100%)
 rename {c/src/lib/libcpu/powerpc/mpc5xx/exceptions => bsps/powerpc/ss555/start}/raw_exception.c (100%)
 delete mode 100644 c/src/lib/libcpu/powerpc/mpc5xx/README
 delete mode 100644 c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c
 delete mode 100644 c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c b/bsps/powerpc/ss555/dev/clock.c
similarity index 100%
rename from c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c
rename to bsps/powerpc/ss555/dev/clock.c
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c b/bsps/powerpc/ss555/dev/console-generic.c
rename from c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c
rename to bsps/powerpc/ss555/dev/console-generic.c
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c b/bsps/powerpc/ss555/dev/timer.c
rename from c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c
rename to bsps/powerpc/ss555/dev/timer.c
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c b/bsps/powerpc/ss555/start/irq.c
rename from c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c
rename to bsps/powerpc/ss555/start/irq.c
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S b/bsps/powerpc/ss555/start/irq_asm.S
rename from c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S
rename to bsps/powerpc/ss555/start/irq_asm.S
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c b/bsps/powerpc/ss555/start/irq_init.c
rename from c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c
rename to bsps/powerpc/ss555/start/irq_init.c
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.c b/bsps/powerpc/ss555/start/raw_exception.c
rename from c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.c
rename to bsps/powerpc/ss555/start/raw_exception.c
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index 6997ece985..0a85ecd539 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -37,16 +37,16 @@ libbsp_a_SOURCES += startup/tm27supp.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/cache/cache.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/exceptions/ppc_exc_print.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/clock.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/console-generic.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/timer.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq_asm.S
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq_init.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/raw_exception.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors_init.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors.S
-libbsp_a_LIBADD = \
-    ../../../libcpu/@RTEMS_CPU@/mpc5xx/clock.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc5xx/console-generic.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc5xx/exceptions.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc5xx/irq.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc5xx/timer.rel
 include $(top_srcdir)/../../../../automake/local.am
 include $(srcdir)/../../../../../../bsps/powerpc/shared/shared.am
 include $(srcdir)/../../../../../../bsps/powerpc/ss555/headers.am
diff --git a/c/src/lib/libbsp/powerpc/ss555/README b/c/src/lib/libbsp/powerpc/ss555/README
index d4b020ba19..54d0bfa85a 100644
--- a/c/src/lib/libbsp/powerpc/ss555/README
+++ b/c/src/lib/libbsp/powerpc/ss555/README
@@ -256,3 +256,27 @@ Sample programs:
     - The loopback, fileio, unilimited, and pppd tests fail due to memory
       limitations.
     - The paranoia program dies on a floating-point assist exception.
+Various non-BSP-dependent support routines.
+timer -		Support for the RTEMS timer tick, using the Programmable
+		Interval Timer (PIT).
+console-generic	- Console support via the on-chip dual SCI port in the QSMCM
+		module.
+exception -	Installation and deinstallation of exception handlers, by
+		manipulation of exception vector table.
+irq -		Exception handler for all external and decrementer interrupts.
+		Generalized interrupt handler which calls specific handlers
+		via entries in the interrupt connection table.  Interrupt
+		connection table maintenance routines.  USIU and UIMB
+		interrupt masking and level control.
+timer -		Support for RTEMS timer tests, using the PowerPC timebase
+		(TB) registers.
+vectors -	Compressed MPC5XX exception vector table, exception handler
+		prologues, default exception handler.  Code to initialize
+		table with default handlers.
diff --git a/c/src/lib/libcpu/powerpc/Makefile.am b/c/src/lib/libcpu/powerpc/Makefile.am
index 724dfea710..6d5bc19e5b 100644
--- a/c/src/lib/libcpu/powerpc/Makefile.am
+++ b/c/src/lib/libcpu/powerpc/Makefile.am
@@ -45,41 +45,6 @@ if ppc405
 ## ppc4xx/include
 endif # ppc405
-## mpc5xx
-EXTRA_DIST += mpc5xx/README
-if mpc5xx
-# mpc5xx/clock
-noinst_PROGRAMS += mpc5xx/clock.rel
-mpc5xx_clock_rel_SOURCES = mpc5xx/clock/clock.c
-mpc5xx_clock_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc5xx_clock_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc5xx/console-generic
-noinst_PROGRAMS += mpc5xx/console-generic.rel
-mpc5xx_console_generic_rel_SOURCES = mpc5xx/console-generic/console-generic.c
-mpc5xx_console_generic_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc5xx_console_generic_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc5xx/exceptions
-noinst_PROGRAMS += mpc5xx/exceptions.rel
-mpc5xx_exceptions_rel_SOURCES = mpc5xx/exceptions/raw_exception.c
-mpc5xx_exceptions_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc5xx_exceptions_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc5xx/irq
-noinst_PROGRAMS += mpc5xx/irq.rel
-mpc5xx_irq_rel_SOURCES = mpc5xx/irq/irq.c mpc5xx/irq/irq_init.c mpc5xx/irq/irq_asm.S
-mpc5xx_irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc5xx_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc5xx/timer
-noinst_PROGRAMS += mpc5xx/timer.rel
-mpc5xx_timer_rel_SOURCES = mpc5xx/timer/timer.c
-mpc5xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc5xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
 if mpc6xx
 # mpc6xx/mmu
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/README b/c/src/lib/libcpu/powerpc/mpc5xx/README
deleted file mode 100644
index 54d6985649..0000000000
--- a/c/src/lib/libcpu/powerpc/mpc5xx/README
+++ /dev/null
@@ -1,23 +0,0 @@
-Various non-BSP-dependent support routines.
-timer -		Support for the RTEMS timer tick, using the Programmable
-		Interval Timer (PIT).
-console-generic	- Console support via the on-chip dual SCI port in the QSMCM
-		module.
-exception -	Installation and deinstallation of exception handlers, by
-		manipulation of exception vector table.
-irq -		Exception handler for all external and decrementer interrupts.
-		Generalized interrupt handler which calls specific handlers
-		via entries in the interrupt connection table.  Interrupt
-		connection table maintenance routines.  USIU and UIMB
-		interrupt masking and level control.
-timer -		Support for RTEMS timer tests, using the PowerPC timebase
-		(TB) registers.
-vectors -	Compressed MPC5XX exception vector table, exception handler
-		prologues, default exception handler.  Code to initialize
-		table with default handlers.
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c b/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c
index 51db6a62c1..0000000000
--- a/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c
+++ /dev/null
@@ -1,68 +0,0 @@
- * mpc505/509 external interrupt controller management.
-#include "ictrl.h"
-#include <rtems.h>
-#include <rtems/score/powerpc.h>
- * Internal routines.
-static unsigned long volatile *const IRQAND     =
-              (unsigned long volatile *const)0x8007EFA4;
-static void nullHandler()
-/* Interrupt dispatch table. */
-static ExtIsrHandler extIrqHandlers[NUM_IRQS] =
-  nullHandler,
-  nullHandler,
-  nullHandler,
-  nullHandler,
-  nullHandler,
-  nullHandler,
-  nullHandler
-/* RTEMS external interrupt handler. Calls installed external interrupt
-   handlers for every pending external interrupt in turn. */
-static rtems_isr extIsr_( rtems_vector_number i )
-#define BIT_NUMBER(val, bit) \
-    __asm__ volatile ( "cntlzw %0, %1; srawi %0, %0, 1": "=r" (bit) : "r" (val) );
-  int bit;
-  (void)i;
-  BIT_NUMBER(*IRQAND & IMASK_ALL, bit);
-  while ( bit < NUM_IRQS ) {
-    extIrqHandlers[bit]();
- * Public routines
-void extIrqSetHandler(ExtInt interrupt,ExtIsrHandler handler)
-  extIrqHandlers[interrupt] = handler;
-void extIsrInit( void )
-  int i = 0;
-  extIrqDisable(IMASK_ALL);
-  for( i = 0; i < NUM_IRQS; i++)
-    extIrqHandlers[i] = nullHandler;
-  set_vector(extIsr_,PPC_IRQ_EXTERNAL,1);
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h b/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h
index 303ece825d..0000000000
--- a/c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h
+++ /dev/null
@@ -1,75 +0,0 @@
-#ifndef _ICTRL_H
-#define _ICTRL_H
- * FIXME: should be somehow merged into general RTEMS interrupt
- * management code.
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define _SIU_IRQENABLE  ((unsigned long volatile *const)0x8007EFA8)
-#define _SIU_IRQPEND    ((unsigned long volatile *const)0x8007EFA0)
-/* Interrupt masks. */
-enum {
-  IMASK_EXT0  = 0x80000000,
-  IMASK_EXT1  = 0x20000000,
-  IMASK_EXT2  = 0x08000000,
-  IMASK_EXT3  = 0x02000000,
-  IMASK_EXT4  = 0x00800000,
-  IMASK_EXT5  = 0x00200000,
-  IMASK_EXT6  = 0x00080000,
-  IMASK_ALL   = IMASK_EXT0 | IMASK_EXT1 | IMASK_EXT2 | IMASK_EXT3 |
-                IMASK_EXT4 | IMASK_EXT5 | IMASK_EXT6
-/* Interrupt numbers. */
-typedef enum {
-  IRQ_EXT0,
-  IRQ_EXT1,
-  IRQ_EXT2,
-  IRQ_EXT3,
-  IRQ_EXT4,
-  IRQ_EXT5,
-  IRQ_EXT6,
-  NUM_IRQS
-} ExtInt;
-/* Type of external interrupt handlers */
-typedef void (*ExtIsrHandler) (void);
-/* Initialization. Must be called once after RTEMS interrupts sybsystem
-   is initiailized. 'predriver_hook' is one of such places. */
-extern void extIsrInit( void );
-/* Set interrupt handler 'handler' for external interrupt number
-   'interrupt'. */
-extern void extIrqSetHandler(ExtInt interrupt, ExtIsrHandler handler);
-/* Check is external interrupt 'irq' (IMASK_XXXX) is pended. */
-#define extIrqIsSet(irq) \
-  (*_SIU_IRQPEND & (irq))
-/* Enable external interrupt 'irq' (IMASK_XXXX) processing. */
-#define extIrqEnable(irq) \
-  (*_SIU_IRQENABLE |= (irq))
-/* Disable external interrupt 'irq' (IMASK_XXXX) processing. */
-#define extIrqDisable(irq) \
-  (*_SIU_IRQENABLE &= ~(irq))
-/* Check if external interrupt 'irq' (IMASK_XXXX) processing is
-   enabled. */
-#define extIrqGetEnable \
-  (*_SIU_IRQENABLE)
-#ifdef __cplusplus
-#endif
-#endif /* _ICTRL_H */
2.12.3
