want to contribute to project
Cillian O'Donnell
cpodonnell8 at gmail.com
Wed Mar 14 21:13:00 UTC 2018
On 14 March 2018 at 19:51, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 14 March 2018 at 18:26, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> I'm still getting the Covoar not found error
>> I'm not able to understand what am I missing, if it needs a fix, please
>> help me understand the code.
> Have a look where all the rsb tools were built. Does covoar appear in
> there?
> The directory is something like:
> cd ~/development/rtems/4.12/bin
Sorry, nevermind that, just remenbered I had put covoar there for
something else.
You mentioned before that waf built covoar properly and it appeared in:
"covoar is in /rtems-tools/build/covoar"
is it this or is it rtems-tools/build/tester/covoar
and you're definitely using the coverage-merge branch of my github
https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>> Thanks
>> On 9 March 2018 at 22:20, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On 9 Mar 2018 10:15 p.m., "Vijay Kumar Banerjee" <
>>> vijaykumar9597 at gmail.com> wrote:
>>> On 9 Mar 2018 3:34 a.m., "Joel Sherrill" <joel.sherrill at gmail.com>
>>> wrote:
>>> On Sun, Mar 4, 2018 at 4:52 AM, Cillian O'Donnell <cpodonnell8 at gmail.com
>>> > wrote:
>>>> On 3 March 2018 at 22:18, Vijay Kumar Banerjee <
>>>>> Hello sir,
>>>>> I need some guidance to proceed to apply for #2920 as my GSoC project.
>>>>> I wanted to know the following points :
>>>>> 1. What are the prerequisites (do I have to produce something ? like
>>>>> the hello world )
>>>> Other than the hello world, there's no official prerequisites. Usually
>>>> the next thing is to fix a small bug, have a look at the tickets here:
>>>> https://devel.rtems.org/query
>>>>> 2. reference materials (like specific doc), to familiarise with the
>>>>> rtems-tester and rsb .
>>>> Relevant to you would be RTEMS Tester section of the main user manual.
>>>> The rest of the manual should be useful for setting up rtems in general.
>>>> https://docs.rtems.org/branches/master/user/tools/tester.html
>>> Running this and submitting some results for a BSP on a simulator would
>>> be a good step.
>>> This project requires doing that a lot. You can do one BSP that runs on
>>> a gdb based simulator
>>> and another on a qemu based simulator.
>>> I'll surely do that . currently I'm trying to run cillian's project ,
>>> facing some issues with the test.py , which I'll try to fix , probably it's
>>> related to the path . I'll be at the other part of the country for a few
>>> days (4 days ), after that I'll try to submit results for a BSP on a
>>> simulator
>>> There is a project based on qemu that includes coverage trace ability.
>>>> The links to the previous projects which you already found and the
>>>> other links I've mentioned.
>>>>> 3. how to properly plan the project into phase wise tasks and weekly
>>>>> sub-tasks.
>>>> Essentially it would be:
>>>> 1. Get coverage analysis running again (converting the config files to
>>>> .ini and a couple of fixes to some of the parsing in the sections that
>>>> haven't been integrated, might be all that it takes).
>>>> 2. Then get the coverage tools integrated with RTEMS Tester. Which is
>>>> fix the outstanding issues that are mentioned in:
>>>> https://devel.rtems.org/ticket/2920
>>>> Chris Johns might have things to add to this, ultimately the
>>>> integration to RTEMS Tester will be up to him.
>>> I would add finishing getting the Couverture qemu into the RSB.
>>> Okay sir.
>>> Once the setup is running, there are a couple of meaty projects.
>>> Chris and I have talked about reworking the report generation in covoar.
>>> Currently, the C++ code writes HTML and txt files. It would be nice to
>>> have covoar generate something which is subsequently processed
>>> with a report generator. We don't have a complete solution in mind but
>>> writing Sphinx like the RTEMS documentation is an option. One challenge
>>> is that the current HTML output has filtering capability and that
>>> wouldn't
>>> be possible (I think) using Sphinx.
>>> The other desirable capability is to ensure the gcov output is correct
>>> and
>>> can be processed by the GNU gcov tool to produce reports with the same
>>> results as covoar. I think Cillian got a start on this but only as far
>>> as noting
>>> it wasn't always the same. We have a mentor from the GCC community
>>> to help with this.
>>> Once the gcov output is trustworthy, we can try other tools like lcov to
>>> see what other reports we can get.
>>> Thank you for describing the object in detail , I'll read more about
>>> covoar and try to understand how it generates the output and how it can be
>>> modified .
>>>> The order in which the problems are listed in that ticket are probably
>>>> the order in which you would complete them, the stuff about generating the
>>>> xml reports and gcov and all of that is probably a 2nd or 3rd phase task
>>>> for you depending on how it goes. The plan can change as you go along, its
>>>> just important that you make a plan to begin with.
>>>> Good luck,
>>>> Cillian.
>>>>> Thank you,
>>>>> Vijay k.
>>>>> On 1 March 2018 at 15:38, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 1 March 2018 at 09:10, Vijay Kumar Banerjee <
>>>>>>> hello,
>>>>>>> while trying to figure out the starting point, I came across this
>>>>>>> project form GSoC 2017 by C.P. O'Donell
>>>>>>> https://summerofcode.withgoogle.com/archive/2017/projects/49
>>>>>>> 25375616385024/
>>>>>>> Is this the project that has previous works on the project I'm
>>>>>>> wanting to take (#2920) ? If not , please help me find the right one.
>>>>>> Hi Vijay,
>>>>>> Yes that's the one, let me know if you have any questions about it.
>>>>>> When I checked last month coverage is not working with the RTEMS Tester
>>>>>> because the configuration files for the bsps in rtems-tools/tester/rtems
>>>>>> have been converted from .mc to .ini So the old .mc files I mention need to
>>>>>> be converted before it will work again.
>>>>>> This is what I wrote as the final documentation, it should help you
>>>>>> reproduce what I had working last summer.
>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools
>>>>>> Try this branch in github for the starting point:
>>>>>> Good luck with the project,
>>>>>> Cillian.
>>>>>>> Also, please guide me with reading references and some small tickets
>>>>>>> related to the project .
>>>>>>> Thank you ,
>>>>>>> Vijay k.
>>>>>>> On 26 February 2018 at 21:54, Vijay Kumar Banerjee <
>>>>>>>> Thank you for giving me a detailed introduction to the project
>>>>>>>> objectives and mentors.
>>>>>>>> I am interested in # 2920: "Improve Coverage analysis toolkit".
>>>>>>>> Please guide me with the resources to get started with the project
>>>>>>>> and get a deep understanding.
>>>>>>>> Thank you
>>>>>>>> Vijay
>>>>>>>> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>>>>>>>>> christian.mauderer at embedded-brains.de> wrote:
>>>>>>>>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>>>>>>>>> > Hello,
>>>>>>>>> > As told by Joel, I sent the screenshots of my working hello
>>>>>>>>> world to his
>>>>>>>>> > personal email and have also included my name in the GSoC
>>>>>>>>> tracking page .
>>>>>>>>> > + Make Eclipse Target Interaction work with RTEMS
>>>>>>>>> > (https://www.eclipse.org/tcf/)
>>>>>>>>> > + Improvements to our coverage reporting. GCOV validation and
>>>>>>>>> covoar
>>>>>>>>> > reporting improvements
>>>>>>>>> > + wifi integration improvements
>>>>>>>>> > + aarch64 port
>>>>>>>>> > + x86_64 port / non-legacy PC BSP
>>>>>>>>> > - This project is large so we would need to work with whoever
>>>>>>>>> wants
>>>>>>>>> > to tackle it
>>>>>>>>> > to find the best subset for GSoC.
>>>>>>>>> > Based on this list I went through the OpenProjects page
>>>>>>>>> > and came across the following Tickets .,
>>>>>>>>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>>>>>>>>> > out of them , I find these interesting
>>>>>>>>> > 1. "Improve coverage Analysis Toolset " (#2920);
>>>>>>>>> This area is mine. The ticket mat or may not be a great
>>>>>>>>> description of the goals. There are probably three things that need to be
>>>>>>>>> done.
>>>>>>>>> + Integrate ran recipes for Couverture variant of qemu. This might
>>>>>>>>> be a very small task. Last year's student just didn't get this integrated
>>>>>>>>> and was waiting for some patches to be merged on their side.
>>>>>>>>> + Verify the gcov output from covoar is correct and the gcov (and
>>>>>>>>> similar tools) matches the coverage reports it generates. We have someone
>>>>>>>>> from the GCC community to help mentor here.
>>>>>>>>> + Covoar generates HTML and text output directly. There is a
>>>>>>>>> desire for it to generate something equally useful that is processed by
>>>>>>>>> existing tools to generate reports. One possible option for this output
>>>>>>>>> could be Sphinx like our regular documentation. Or it could be a
>>>>>>>>> data-centric format processed by other tools. The current HTML allows
>>>>>>>>> filtering and sorting so not losing information and ease of use is
>>>>>>>>> important. This probably will end up simplifying C++ and adding Python.
>>>>>>>>> > 2. "libbsd:WiFi support needs rc.conf integration " (#3222)
>>>>>>>>> Christian's project to mentor.
>>>>>>>>> > also I came across # 3302 :" Build system conversion of BSP
>>>>>>>>> Config(.cfg)
>>>>>>>>> > files to pkg-config(.pc) files"
>>>>>>>>> > (I have some knowledge of Python, but not proficient in it, I
>>>>>>>>> can learn
>>>>>>>>> > it better if it's required )
>>>>>>>>> > which I find interesting
>>>>>>>>> This one is Chris Johns project to mentor. It is an important and
>>>>>>>>> logically the next step in replacing our build system with the Python based
>>>>>>>>> waf. If you get through this one before the summer is out, then working on
>>>>>>>>> waf would probably make sense.
>>>>>>>>> Did I miss one?
>>>>>>>>> Hello Vijay,
>>>>>>>>> all of the projects would be good ones.
>>>>>>>>> The #2920 and #3302 are more connected to the host tools. They
>>>>>>>>> should be
>>>>>>>>> doable with few or no real hardware. But you should ask the two
>>>>>>>>> potential mentors about that.
>>>>>>>>> For the #3222 you would need some board supported by the libbsd
>>>>>>>>> (like
>>>>>>>>> Beagle Bone Black) and I would suggest a JTAG debugger (some
>>>>>>>>> OpenOCD
>>>>>>>>> based or similar).
>>>>>>>>> > Am I following the right tickets? If not please help me find the
>>>>>>>>> right ones.
>>>>>>>>> The tickets are the right ones.
>>>>>>>>> > Out of these , which one do you recommend me to take ?
>>>>>>>>> I would recommend to take a more detailed look at the tickets and
>>>>>>>>> start
>>>>>>>>> to ask some questions about it on the mailing list with CC to the
>>>>>>>>> (potential) mentors.
>>>>>>>>> Maybe you could also try to find some small tickets related to
>>>>>>>>> similar
>>>>>>>>> topics and just try to work on these. That could help you find out
>>>>>>>>> what
>>>>>>>>> you want to do.
>>>>>>>>> > My experience with C/C++ : I am proficient in C++11 with STL .
>>>>>>>>> Also
>>>>>>>>> > proficient in C language .
>>>>>>>>> > My experience with opensource : This is the first open source
>>>>>>>>> project
>>>>>>>>> > I'm taking up .
>>>>>>>>> It's no problem if it's your first Open Source project. That's the
>>>>>>>>> point
>>>>>>>>> of GSoC: To collect first Open Source experience.
>>>>>>>>> Best regards
>>>>>>>>> Christian Mauderer
>>>>>>>>> > Thank you ,
>>>>>>>>> > Vijay K.
>>>>>>>>> embedded brains GmbH
>>>>>>>>> Herr Christian Mauderer
>>>>>>>>> Dornierstr. 4
>>>>>>>>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>>>>>>>>> D-82178 Puchheim
>>>>>>>>> Germany
>>>>>>>>> email: christian.mauderer at embedded-brains.de
>>>>>>>>> Phone: +49-89-18 94 741 - 18
>>>>>>>>> Fax: +49-89-18 94 741 - 08
>>>>>>>>> PGP: Public key available on request.
>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>>>>>>>> EHUG.
>>>>>>>>> _______________________________________________
>>>>>>>>> devel mailing list
>>>>>>>>> devel at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180314/98297e2e/attachment-0001.html>
