[PATCH] Added Getentropy() support to beagle BSP
Thu Mar 15 05:59:37 UTC 2018
On 15/03/18 05:56, Udit agarwal wrote:
>  c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 6 ++++++
>  1 file changed, 6 insertions(+)
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> index 11e24dc..b26b6a8 100644
> --- a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> +++ b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> @@ -17,6 +17,8 @@
>  #include <string.h>
>  #include <rtems/sysinit.h>
> +static rtems_mutex atsam_trng_reg =
> RTEMS_MUTEX_INITIALIZER("atsam_trng_reg");
Is this a register or a mutex?
>  static void atsam_trng_enable(void)
>      PMC_EnablePeripheral(ID_TRNG);
> @@ -29,9 +31,12 @@ int getentropy(void *ptr, size_t n)
>          uint32_t random;
>          size_t copy;
> +        rtems_mutex_lock(&atsam_trng_reg);
>          while ((TRNG_GetStatus() & TRNG_ISR_DATRDY) == 0) {
>              /* wait */
> +        rtems_mutex_unlock(&atsam_trng_reg);
Now the status register read is protected by a mutex.
>     random = TRNG_GetRandData();
Can you ensure that this read is correct in a multi-threaded application
(the status register has the right value during the read)?
> @@ -51,6 +56,7 @@ int getentropy(void *ptr, size_t n)
>          ptr += copy;
> +    rtems_mutex_destroy(&atsam_trng_reg);
Here  you destroy the mutex. What happens if you call getentropy() a
second time?
> return 0;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
