[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal
dev.madaari at gmail.com
Thu Mar 15 08:20:45 UTC 2018
On Thu, Mar 15, 2018 at 1:19 PM, Sebastian Huber <
> On 15/03/18 08:13, Udit agarwal wrote:
>> Oh yes, i think i misinterpreted your previous suggestion of surrounding
>> the while loop by mutex, it should be the outer while loop. some thing like
>> this?:
>> while (n > 0) {
>> uint32_t random;
>> size_t copy;
>> rtems_mutex_lock(&atsam_trng_mutex);
> Now you correctly use the mutex to produce 32-bits of random data.
> Currently the likely user of getrandom() is
> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=
> blob;f=newlib/libc/stdlib/arc4random.c;h=3cccc3ed46a5e9e
> 756d4e216cb7686589eb60993;hb=HEAD#l89
> So, you need 12 mutex lock/unlock operations for this. I would protect the
> while (n > 0) loop with a single mutex lock/unlock.
Ok,Like this?
while (n > 0) {
rtems_mutex_unlock(&atsam_trng_mutex);
Also, will it be ok to keep atsam_trng_mutex even after user has finished
using getentropy() i.e when we don't use destroy(&atsam_trng_mutex) at all?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/1d7cc87f/attachment.html>
