Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu Mar 15 10:22:19 UTC 2018
On 15 March 2018 at 03:58, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> hello ,
> as told by Joel , I started this thread to further discuss the coverage
> analysis toolset .
> Current status is , I'm trying to builld and run rtems-test from the
> coverage-merge branch of the previous GSoC student Cillian .
> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
> I'm getting an error that says .
> "Covoar not found !"
It's supposed to find it in rtems-tools/build/tester/covoar/ If it's in
there it should be fine. Can you show me the contents of that directory?
cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $ ls
> the Covoar appeared in rtems-tools/tester/covoar .
> Vijay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/455e7eb0/attachment.html>
