[PATCH 10/12] mvme5500/include/bsp/VMEConfig.h: Remove spaces after \ and remove tabs
Thu Mar 15 22:35:59 UTC 2018
 bsps/powerpc/mvme5500/include/bsp/VMEConfig.h | 30 +++++++++++++--------------
 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/bsps/powerpc/mvme5500/include/bsp/VMEConfig.h b/bsps/powerpc/mvme5500/include/bsp/VMEConfig.h
index ecc5789..a5b43df 100644
--- a/bsps/powerpc/mvme5500/include/bsp/VMEConfig.h
+++ b/bsps/powerpc/mvme5500/include/bsp/VMEConfig.h
@@ -32,36 +32,36 @@ int BSP_VMEIrqMgrInstall(void);
  * hardcoded window lengths that match this
  * layout:
-#define _VME_A32_WIN0_ON_PCI	        0x90000000
+#define _VME_A32_WIN0_ON_PCI            0x90000000
 /* If _VME_CSR_ON_PCI is defined then the A32 window is reduced to accommodate
  * CSR for space.
-#define _VME_CSR_ON_PCI			0x9e000000
-#define _VME_A24_ON_PCI			0x9f000000
-#define _VME_A16_ON_PCI			0x9fff0000
+#define _VME_CSR_ON_PCI                 0x9e000000
+#define _VME_A24_ON_PCI                 0x9f000000
+#define _VME_A16_ON_PCI                 0x9fff0000
 /* Reuse BAT 0 for VME */
-#define BSP_VME_BAT_IDX			0
+#define BSP_VME_BAT_IDX                 0
 /* start of the A32 window on the VME bus
  * TODO: this should perhaps be a configuration option
-#define _VME_A32_WIN0_ON_VME	0x20000000
+#define _VME_A32_WIN0_ON_VME            0x20000000
 /* if _VME_DRAM_OFFSET is defined, the BSP
  * will map our RAM onto the VME bus, starting
  * at _VME_DRAM_OFFSET
-#define _VME_DRAM_OFFSET		0x90000000
+#define _VME_DRAM_OFFSET                0x90000000
-#define BSP_VME_UNIVERSE_INSTALL_IRQ_MGR(err)			\
-	do {											\
-	  err = vmeUniverseInstallIrqMgrAlt(VMEUNIVERSE_IRQ_MGR_FLAG_SHARED,\
-             0, BSP_GPP_VME_VLINT0, \
-             1, BSP_GPP_VME_VLINT1, \
-             2, BSP_GPP_VME_VLINT2, \
+#define BSP_VME_UNIVERSE_INSTALL_IRQ_MGR(err) \
+        do { \
+          err = vmeUniverseInstallIrqMgrAlt(VMEUNIVERSE_IRQ_MGR_FLAG_SHARED, \
+             0, BSP_GPP_VME_VLINT0, \
+             1, BSP_GPP_VME_VLINT1, \
+             2, BSP_GPP_VME_VLINT2, \
              3, BSP_GPP_VME_VLINT3, \
-             -1 /* terminate list  */);  \
-	} while (0)
+             -1 /* terminate list  */);  \
+        } while (0)
 #endif
1.8.3.1
