RTEMS monitor commands and the shell
Paul Whitfield paulw at omnitronics.com.au
Fri Mar 16 07:43:07 UTC 2018
We have hit this problem with rtems 4.10.
I think the monitor commands should be treated the same as the other shell commands.
It should be possible to disable via shellconfig.h - by default all are enabled, but that can be disabled.
In our application, the monitor 'exit' command was particularly problematic because customers connect to the monitor via telnet then type exit to end the telnet session.
The exit command would trigger a fatal error exception, resulting in several bug reports that were 'device restarted for no reason'. :-(
Regards
Paul Whitfield
Paul Whitfield
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Chris Johns
Sent: Friday, 16 March 2018 3:01 PM
To: Development
Subject: RTEMS monitor commands and the shell
Hi,
The monitor commands are registered automatically in `rtems_shell_init_once()` which means an application has no control over these being present, the command mix and naming, for example there is a `config` command in the monitor.
I am not sure what to do, if it is removed some applications may break assuming these commands are present. A way to disable the command using shellconfig.h would be nice.
Suggestions?
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
Scanned by Moncrieff Technology Solutions Secure Mail Appliance
