RTEMS monitor commands and the shell
Fri Mar 16 09:29:40 UTC 2018
On 16/03/18 08:01, Chris Johns wrote:
> Hi,
> The monitor commands are registered automatically in `rtems_shell_init_once()`
> which means an application has no control over these being present, the command
> mix and naming, for example there is a `config` command in the monitor.
> I am not sure what to do, if it is removed some applications may break assuming
> these commands are present. A way to disable the command using shellconfig.h
> would be nice.
> Suggestions?
It would be nice to control all shell commands of RTEMS via the
shellconfig.h.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
