[PATCH v2] if_atsam: Add checksum offload.
Fri Mar 16 14:02:30 UTC 2018
Looks fine to me.
On Thu, Mar 15, 2018 at 4:09 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
>  rtemsbsd/sys/dev/atsam/if_atsam.c | 52 +++++++++++++++++++++++++++++++++------
>  1 file changed, 44 insertions(+), 8 deletions(-)
> diff --git a/rtemsbsd/sys/dev/atsam/if_atsam.c b/rtemsbsd/sys/dev/atsam/if_atsam.c
> index 794937be..86e232ab 100644
> --- a/rtemsbsd/sys/dev/atsam/if_atsam.c
> +++ b/rtemsbsd/sys/dev/atsam/if_atsam.c
> @@ -454,6 +454,33 @@ static void if_atsam_interrupt_handler(void *arg)
>                 (void)if_atsam_event_send(sc->tx_daemon_tid, tx_event);
> +static void rx_update_mbuf(struct mbuf *m, sGmacRxDescriptor *buffer_desc)
> +       int frame_len;
> +       frame_len = (int) (buffer_desc->status.bm.len);
> +       m->m_data = mtod(m, char*)+ETHER_ALIGN;
> +       m->m_len = frame_len;
> +       m->m_pkthdr.len = frame_len;
> +       /* check checksum offload result */
> +       m->m_pkthdr.csum_flags = 0;
> +       switch (buffer_desc->status.bm.typeIDMatchOrCksumResult) {
> +       case GMAC_RXDESC_ST_CKSUM_RESULT_IP_CHECKED:
> +               m->m_pkthdr.csum_flags = CSUM_IP_CHECKED | CSUM_IP_VALID;
> +               m->m_pkthdr.csum_data = 0xffff;
> +               break;
> +       case GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_TCP_CHECKED:
> +       case GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_UDP_CHECKED:
> +               m->m_pkthdr.csum_flags = CSUM_IP_CHECKED | CSUM_IP_VALID |
> +                   CSUM_L4_VALID | CSUM_L4_CALC;
> +               break;
>   * Receive daemon
> @@ -466,7 +493,6 @@ static void if_atsam_rx_daemon(void *arg)
>         struct mbuf *m;
>         struct mbuf *n;
>         volatile sGmacRxDescriptor *buffer_desc;
> -       int frame_len;
>         uint32_t tmp_rx_bd_address;
>         size_t i;
>         Gmac *pHw = sc->Gmac_inst.gGmacd.pHw;
> @@ -547,13 +573,8 @@ static void if_atsam_rx_daemon(void *arg)
>                                 /* New mbuf for desc */
>                                 n = if_atsam_new_mbuf(ifp);
>                                 if (n != NULL) {
> -                                       frame_len = (int)
> -                                           (buffer_desc->status.bm.len);
> +                                       rx_update_mbuf(m, buffer_desc);
> -                                       /* Update mbuf */
> -                                       m->m_data = mtod(m, char*)+ETHER_ALIGN;
> -                                       m->m_len = frame_len;
> -                                       m->m_pkthdr.len = frame_len;
>                                         IF_ATSAM_UNLOCK(sc);
>                                         sc->ifp->if_input(ifp, m);
>                                         IF_ATSAM_LOCK(sc);
> @@ -658,6 +679,7 @@ static bool if_atsam_send_packet(if_atsam_softc *sc, struct mbuf *m)
>         uint32_t tmp_val = 0;
>         bool success;
> +       int csum_flags = m->m_pkthdr.csum_flags;
>         if_atsam_tx_bd_cleanup(sc);
>         /* Wait for interrupt in case no buffer descriptors are available */
> @@ -706,6 +728,12 @@ static bool if_atsam_send_packet(if_atsam_softc *sc, struct mbuf *m)
>                 if (m == NULL) {
>                         tmp_val |= GMAC_TX_SET_EOF;
>                         tmp_val &= ~GMAC_TX_SET_USED;
> +                       if ((csum_flags & (CSUM_IP | CSUM_TCP | CSUM_UDP |
> +                           CSUM_TCP_IPV6 | CSUM_UDP_IPV6)) != 0) {
> +                               start_packet_tx_bd->status.bm.bNoCRC = 0;
> +                       } else {
> +                               start_packet_tx_bd->status.bm.bNoCRC = 1;
>                         _ARM_Data_synchronization_barrier();
>                         cur->status.val = tmp_val;
>                         start_packet_tx_bd->status.val &= ~GMAC_TX_SET_USED;
> @@ -979,9 +1007,13 @@ static void if_atsam_init(void *arg)
>         /* Configuration of DMAC */
>         dmac_cfg = (GMAC_DCFGR_DRBS(GMAC_RX_BUFFER_SIZE >> 6)) |
> -           GMAC_DCFGR_RXBMS(3) | GMAC_DCFGR_TXPBMS | GMAC_DCFGR_FBLDO_INCR16;
> +           GMAC_DCFGR_RXBMS(3) | GMAC_DCFGR_TXPBMS | GMAC_DCFGR_FBLDO_INCR16 |
> +           GMAC_DCFGR_TXCOEN;
>         GMAC_SetDMAConfig(sc->Gmac_inst.gGmacd.pHw, dmac_cfg, 0);
> +       /* Enable hardware checksum offload for receive */
> +       sc->Gmac_inst.gGmacd.pHw->GMAC_NCFGR |= GMAC_NCFGR_RXCOEN;
>         /* Shut down Transmit and Receive */
>         GMAC_ReceiveEnable(sc->Gmac_inst.gGmacd.pHw, 0);
>         GMAC_TransmitEnable(sc->Gmac_inst.gGmacd.pHw, 0);
> @@ -1461,6 +1493,10 @@ static int if_atsam_driver_attach(device_t dev)
>         ifp->if_ioctl = if_atsam_ioctl;
>         ifp->if_start = if_atsam_enet_start;
>         ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX;
> +       ifp->if_capabilities |= IFCAP_HWCSUM | IFCAP_HWCSUM_IPV6 |
> +           IFCAP_VLAN_HWCSUM;
> +       ifp->if_hwassist = CSUM_IP | CSUM_IP_UDP | CSUM_IP_TCP |
> +           CSUM_IP6_UDP | CSUM_IP6_TCP;
>         IFQ_SET_MAXLEN(&ifp->if_snd, TXBUF_COUNT - 1);
>         ifp->if_snd.ifq_drv_maxlen = TXBUF_COUNT - 1;
>         IFQ_SET_READY(&ifp->if_snd);
> 2.13.6
> devel mailing list
> devel at rtems.org
