[PATCH] bsp/atsam: Fix GMAC Rx Descriptor fields.
Fri Mar 16 14:08:39 UTC 2018
On Wed, Mar 14, 2018 at 10:51 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
>  bsps/arm/atsam/include/libchip/include/gmac.h | 15 +++++++++------
>  1 file changed, 9 insertions(+), 6 deletions(-)
> diff --git a/bsps/arm/atsam/include/libchip/include/gmac.h b/bsps/arm/atsam/include/libchip/include/gmac.h
> index 64e0079c25..a4227920bd 100644
> --- a/bsps/arm/atsam/include/libchip/include/gmac.h
> +++ b/bsps/arm/atsam/include/libchip/include/gmac.h
> @@ -186,13 +186,16 @@ typedef struct _GmacRxDescriptor {
>                                          vlanPriority: 3,       /** VLAN priority (if VLAN detected) */
>                                          bPriorityDetected: 1,  /** Priority tag detected */
>                                          bVlanDetected: 1,      /**< VLAN tag detected */
> -                                        bTypeIDMatch: 1,       /**< Type ID match */
> -                                        bAddr4Match: 1,        /**< Address register 4 match */
> -                                        bAddr3Match: 1,        /**< Address register 3 match */
> -                                        bAddr2Match: 1,        /**< Address register 2 match */
> -                                        bAddr1Match: 1,        /**< Address register 1 match */
> +                                        typeIDMatchOrCksumResult: 2,
> +#define   GMAC_RXDESC_ST_CKSUM_RESULT_NOT_CHECKED        (0)
> +#define   GMAC_RXDESC_ST_CKSUM_RESULT_IP_CHECKED         (1)
> +#define   GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_TCP_CHECKED (2)
> +#define   GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_UDP_CHECKED (3)
I find these #define in the middle of a struct definition quite
irregular. Is there a compelling reason they go here, or can they go
outside the struct?
> +                                        bTypeIDMatchFoundOrCksumSNAPState: 1,
> +                                        specAddrMatchRegister: 2,
> +                                        bSpecAddrMatchFound: 1,
>                                          reserved: 1,
> -                                        bExtAddrMatch: 1,      /**< External address match */
>                                          bUniHashMatch: 1,      /**< Unicast hash match */
>                                          bMultiHashMatch: 1,    /**< Multicast hash match */
>                                          bBroadcastDetected: 1;  /**< Global all ones broadcast
> 2.13.6
> devel mailing list
> devel at rtems.org
