Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Mar 16 16:48:23 UTC 2018
still the same error
-- vijay
On 16 March 2018 at 21:39, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Just checked and the build was failing because one of the patches needed
> its hash to be updated to sha256. Just pushed that change. The build
> finishes successfully on my end. Pull that change into couverture-build
> branch and try it again. I'm not seeing any automake stuff here, so just
> check that and let me know.
> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> building couverture-qemu from rtems-source-builder (
>> https://github.com/cillianodonnell/rtems-source-builder/
>> tree/couverture-build )
>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>> I have attached the error report .
>> -- vijay
>> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> It runs with a bunch of errors . I have attached the log file
>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version of
>>> qemu designed for generating extra trace data for coverage analysis).
>>> That's what those errors are about. I have an RSB build for that.
>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>> /couverture-build
>>> and the instructions for building it are
>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>> gCouverture-QemuwiththeRSB
>>> I know what the other problem is too. I have a specific environment
>>> variable defined for the path, sorry I can't even remember putting it
>>> there, I thought that was automatically generated (probably should be,
>>> another thing to add to the list :)... ). So wherever you stuck the export
>>> path for where the rsb built the tools, in .bashrc or whatever you're
>>> using. Also put something like:
>>> export PATH=$HOME/development/rtems/5/bin:$PATH
>>> export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>>> or you could just copy covoar into the /bin directory with all the other
>>> rsb tools gcc and all that, it'll find it either way.
>>>> -- vijay
>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Looks good. If you run the samples without coverage is everything ok?
>>>>> So removing --coverage and tacking on /samples
>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>> Do the tests run?
>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>> I have attached the output of the ls of that directory
>>>>>> -- vijay
>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>> hello ,
>>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>>> coverage analysis toolset .
>>>>>>>> Current status is , I'm trying to builld and run rtems-test from
>>>>>>>> the coverage-merge branch of the previous GSoC student Cillian .
>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>>>>>> I'm getting an error that says .
>>>>>>>> "Covoar not found !"
>>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If
>>>>>>> it's in there it should be fine. Can you show me the contents of that
>>>>>>> directory?
>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>> $ ls
>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>> Vijay
>>>>>>>> _______________________________________________
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/2bf6eec1/attachment-0001.html>
