MMU was Re: Contribute to a project under GSOC 2018
Abhinav Jain
jainab.2009 at gmail.com
Fri Mar 16 18:48:14 UTC 2018
Sir,
I have prepared a draft proposal for GSoC 2018 as suggested by you.
I request you to please guide me whether I have made it correctly or not,
whether I have written some big plans or more things can be included.
The link for the Proposal is:
https://docs.google.com/document/d/1boKGnnzQGCzxIVqBVMWvK7OFJTvWKzWDXj1EvuEuq5o/edit?usp=sharing
Thanks and Regards
Abhinav Jain
On Wed, Mar 14, 2018 at 10:47 PM, Abhinav Jain <jainab.2009 at gmail.com>
wrote:
> Sir,
> Thanks for the guidance. I am studying ARM architecture and trying to find
> out the difference in it's architecture from other ones, I am trying to
> understand what can be the minimum changes to the existing framework to get
> it working on other architectures.
> Thanks and Regards
> Abhinav Jain
> On Wed, Mar 14, 2018, 10:41 PM Gedare Bloom <gedare at rtems.org> wrote:
>> The framework exists in the rtems source code, underneath
>> c/src/lib/libbsp/arm.
>> Start with the GSoC template, adjust the dates, start adding details.
>> When you have a draft you can invite comments for review.
>> On Wed, Mar 14, 2018 at 12:18 PM, Abhinav Jain <jainab.2009 at gmail.com>
>> wrote:
>> > Sir,
>> > The description of the RoadRunner OS is mentioned in the document
>> provided
>> > by you,
>> > https://pdfs.semanticscholar.org/3c92/7ed6b426fccfb203dd96be9b7591b3
>> 744f1f.pdf
>> > The link (http://ieeexplore.ieee.org/document/7509439/?part=1) which I
>> > mentioned in the previous mail deals with memory management scheme for
>> the
>> > MMU-less embedded systems.
>> > If there is already a framework for ARM MMU, I will try to extend it to
>> > other architectures as much as possible, I read about various
>> architectures
>> > in past couple of days.
>> > I request you to please provide the link to the available framework so
>> that
>> > I can study that and proceed with its enhancement if possible. Also, I
>> > request you to please guide me for my GSoC proposal.
>> > Thanks and Regards
>> > Abhinav Jain
>> > On Wed, Mar 14, 2018 at 9:37 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> Abhinav,
>> >> Send me the linked article. Does it describe the RoadRunner OS
>> >> approach? I am not familiar with it.
>> >> Note that there is a basic framework for ARM MMU in place already.
>> >> Adoption/adaptation of it to other architectures is preferred versus
>> >> replacing it, unless absolutely necessary.
>> >> On Wed, Mar 14, 2018 at 12:03 PM, Abhinav Jain <jainab.2009 at gmail.com>
>> >> wrote:
>> >> > Sir,
>> >> > I studied the documents provided by you in the previous mail, also I
>> >> > read a
>> >> > document from http://ieeexplore.ieee.org/document/7509439/?part=1.
>> >> > As told by you in the previous mail that the first issue to be
>> solved is
>> >> > to
>> >> > provide a BSP-level framework for MMU/MPU hardware, after reading the
>> >> > memory
>> >> > protection in roadrunner operating system, I think that with some
>> >> > changes,
>> >> > the same concept can be implemented in the RTEMS for memory
>> protection.
>> >> > I request you to please guide me whether I am right in the approach
>> or I
>> >> > have to think differently.
>> >> > Thanks and Regards
>> >> > Abhinav Jain
>> >> > On Wed, Mar 7, 2018 at 10:49 AM, Abhinav Jain <jainab.2009 at gmail.com
>> >> > wrote:
>> >> >> Sir,
>> >> >> Thanks a lot for the guidance. I will study the documents provided
>> by
>> >> >> you
>> >> >> and will try to find more about this to increase my knowledge about
>> >> >> Memory
>> >> >> support.
>> >> >> I will start preparing a draft proposal as per the template
>> provided on
>> >> >> the RTEMS GSoC page.
>> >> >> Thanks and Regards
>> >> >> Abhinav Jain
>> >> >> On Mar 6, 2018 10:25 PM, "Gedare Bloom" <gedare at rtems.org> wrote:
>> >> >> On Sun, Mar 4, 2018 at 1:50 AM, Abhinav Jain <jainab.2009 at gmail.com
>> >> >> wrote:
>> >> >> > Sir,
>> >> >> > Thanks for your time and consideration. I was discussing this
>> project
>> >> >> > with
>> >> >> > Gedare Sir and he guided me, how to proceed.
>> >> >> > I am studying various things before proceeding with the code part
>> but
>> >> >> > for
>> >> >> > now, I request you to please guide me what should be my next
>> steps to
>> >> >> > work
>> >> >> > on this project under GSOC'18.
>> >> >> > Thanks and Regards
>> >> >> > Abhinav Jain
>> >> >> > On Sun, Mar 4, 2018 at 10:48 AM, Hesham Almatary
>> >> >> > <heshamelmatary at gmail.com>
>> >> >> > wrote:
>> >> >> >> On Sun, Mar 4, 2018 at 10:20 AM, Joel Sherrill <joel at rtems.org>
>> >> >> >> wrote:
>> >> >> >> > On Mar 3, 2018 12:16 PM, "Abhinav Jain" <jainab.2009 at gmail.com
>> >> >> >> > wrote:
>> >> >> >> > Sir/Madam,
>> >> >> >> > I am Abhinav Jain, a second-year engineering student from
>> Delhi,
>> >> >> >> > India.
>> >> >> >> > I
>> >> >> >> > have been working in Linux Kernel Development, I have been
>> writing
>> >> >> >> > small
>> >> >> >> > drivers and have a good knowledge of the operating system.
>> >> >> >> > I have been studying about Memory Protection project(ticket
>> #2904)
>> >> >> >> > for
>> >> >> >> > around a month and found it really interesting. I studied about
>> >> >> >> > POSIX,
>> >> >> >> > MMU
>> >> >> >> > support in various other architecture and the memory protection
>> >> >> >> > APIs
>> >> >> >> > in
>> >> >> >> > various operating systems.I have been discussing the same on
>> the
>> >> >> >> > mailing
>> >> >> >> > list.
>> >> >> >> > I also solved an issue (#2522) around a week ago to gain some
>> >> >> >> > hands-on
>> >> >> >> > code.
>> >> >> -ENOPATCH
>> >> >> >> > Welcome aboard.
>> >> >> >> > I would like to work on the Memory Protection project under
>> GSOC
>> >> >> >> > 2018,
>> >> >> >> > so I
>> >> >> >> > request you to please guide me regarding the steps to be
>> followed.
>> >> >> >> > Gedare conceived of what's there be so I cc'ed him. My
>> >> >> >> > recollection
>> >> >> >> > is
>> >> >> >> > that
>> >> >> >> > there were specific things he wanted to change and when that
>> was
>> >> >> >> > addressed,
>> >> >> >> > providing support for arenas on multiple architecture is
>> desirable
>> >> >> >> +1
>> >> >> >> There might be an opportunity to port RTEMS to RISC-V's
>> Supervisor
>> >> >> >> Mode which will need MMU support (currently it only runs on
>> M-Mode
>> >> >> >> which doesn't have MMU). Both QEMU and Spike simulators support
>> >> >> >> S-Mode.
>> >> >> Start to develop a draft proposal if you have not yet, starting with
>> >> >> our template. A successful proposal must contain a sound design and
>> >> >> good plan, which you will need a lot of time and feedback to
>> develop.
>> >> >> Don't read too much about 64-bit processor architectures and their
>> >> >> needs, since we have limited support there. The first issue to
>> resolve
>> >> >> is what kind of BSP-level interface should we provide over MMU/MPU
>> >> >> hardware, and then what can we do to use that BSP layer to provide
>> >> >> upper-layer services such as managed memory regions, better mmap()
>> >> >> support, "arena" allocators, etc. There are three views here:
>> >> >> 1. no mmu/mpu is available or it is not desired by end users.
>> >> >> 2. mmu/mpu are available, but should only be manipulated
>> >> >> statically/boot-time.
>> >> >> 3. mmu/mpu are available, and can be changed dynamically.
>> >> >> Managing #3 is the hardest, but accommodating 1 and 2 in any system
>> >> >> design is important. Another important concern is mmu/mpu with
>> limited
>> >> >> numbers of entries. Right now, we exist mainly in #1, and #2 is only
>> >> >> used to setup a linear 1:1 memory map with all permissions enabled
>> >> >> when the MMU/MPU can't be turned off. A few projects exist here and
>> >> >> there to also restrict permissions to thread stacks with a hook in
>> the
>> >> >> context switch to change the mpu/mmu state.
>> >> >> Since RTEMS has no multi-process model, the existing solutions in
>> >> >> general-purpose commodity OS do not apply, but you should still be
>> >> >> familiar with how they work for sure. It would also be good for you
>> to
>> >> >> review the solutions in the commodity RTOS domain, e.g. what does
>> >> >> vxworks, safertos, threadx, etc., provides in this field.
>> >> >> Some relevant citations to get more relevant background:
>> >> >> https://highintegritysystems.com/downloads/white_papers/
>> Using_an_MPU_to_Enforce_Spatial_Separation.pdf
>> 7ed6b426fccfb203dd96be9b7591b3744f1f.pdf
>> >> >> https://www.researchgate.net/publication/221033285_A_New_
>> Approach_to_Memory_Partitioning_in_On-Board_Spacecraft_Software
>> >> >> >> > Thanks and Regards
>> >> >> >> > Abhinav Jain
>> >> >> >> > _______________________________________________
>> >> >> >> > devel mailing list
>> >> >> >> > devel at rtems.org
>> >> >> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >> >> >> > devel mailing list
>> >> >> >> > devel at rtems.org
>> >> >> >> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180317/a7749558/attachment-0001.html>
