RSB build failure
Amaan Cheval amaan.cheval at gmail.com
Sat Mar 17 10:00:14 UTC 2018
Hi!
> checking for python...
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
> checking for python2.7... no
> configure: error: python is missing or unusable
That looks like the problem (at least on the surface). macOS does come with
Python built-in, but I don't believe that's good enough for development
(vague memories only of issues) - have you installed Python separately too?
If so, could you confirm that you have the python2.7 binary in your PATH
variable too?
On Sat, Mar 17, 2018 at 3:24 PM Vidushi Vashishth <reachvidu at gmail.com>
wrote:
> Hello!
> I was trying to set up the sparc/erc32 bsp on a new system and was
following the quickstart on the user manual. Though I have successfully
done this before, this time its throwing an error. PFA the rsb log file
with the error report. I was doing this to run the trace buffering
examples.
> Why is the shell command /bin/sh -ex failing?
> Regards,
> Vidushi
> devel mailing list
> devel at rtems.org
