autotools build fail from rsb
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Mar 17 16:34:46 UTC 2018
hello ,
As suggested by Gedare , I have started this thread on the build error that
I'm getting .
I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error while trying
to build autotools from rsb
I'm using fedora 27 64bit .
P.S: the error report is attached
-- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180317/0a07a0fa/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building automake-1.12.6-x86_64-linux-gnu-1
Command Line: ../source-builder/sb-set-builder --prefix=/home/develpment/rtems devel/autotools
Python: 2.7.14 (default, Feb 27 2018, 20:43:24) [GCC 7.3.1 20180130 (Red Hat 7.3.1-2)]
git://git.rtems.org/rtems-source-builder.git/origin/4b3e0f8e3d6998b84a2503dd2e11578989b1672b
Linux lunatic 4.15.8-300.fc27.x86_64 #1 SMP Fri Mar 9 18:11:36 UTC 2018 x86_64
Tail of the build log:
-r-xr-xr-x 1000/1000 443 2012-12-15 15:04 automake-1.12.6/t/tap-more-w.sh
-rwxr-xr-x 1000/1000 3150 2012-12-14 01:27 automake-1.12.6/t/testsuite-summary-count.sh
-rwxr-xr-x 1000/1000 1509 2012-12-14 22:28 automake-1.12.6/t/aclocal-path.sh
-rwxr-xr-x 1000/1000 1043 2012-12-14 22:28 automake-1.12.6/t/version6.sh
-rwxr-xr-x 1000/1000 2050 2012-12-14 22:28 automake-1.12.6/t/distcheck-configure-flags-am.sh
-rwxr-xr-x 1000/1000 1577 2012-12-14 22:28 automake-1.12.6/t/tests-environment-backcompat.sh
-rwxr-xr-x 1000/1000 2966 2012-12-14 22:28 automake-1.12.6/t/backcompat5.sh
-rwxr-xr-x 1000/1000 970 2012-12-14 22:28 automake-1.12.6/t/gcj2.sh
-rwxr-xr-x 1000/1000 1561 2012-12-14 22:28 automake-1.12.6/t/ccnoco3.sh
-r-xr-xr-x 1000/1000 218 2012-12-15 15:04 automake-1.12.6/t/depcomp-lt-makedepend.tap
-rwxr-xr-x 1000/1000 1323 2012-12-14 22:28 automake-1.12.6/t/pr279.sh
-r-xr-xr-x 1000/1000 201 2012-12-15 15:04 automake-1.12.6/t/depcomp-lt-cpp.tap
-rwxr-xr-x 1000/1000 1436 2012-12-14 22:28 automake-1.12.6/t/cond21.sh
-rwxr-xr-x 1000/1000 1651 2012-12-14 22:28 automake-1.12.6/t/alpha.sh
-rwxr-xr-x 1000/1000 1577 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-concurrency-2.sh
-rwxr-xr-x 1000/1000 1135 2012-12-14 22:28 automake-1.12.6/t/cond20.sh
-rwxr-xr-x 1000/1000 1050 2012-12-14 22:28 automake-1.12.6/t/tar2.sh
-rwxr-xr-x 1000/1000 997 2012-12-14 22:28 automake-1.12.6/t/cond28.sh
-rwxr-xr-x 1000/1000 2369 2012-12-14 22:28 automake-1.12.6/t/libtool7.sh
-rwxr-xr-x 1000/1000 1376 2012-12-14 22:28 automake-1.12.6/t/cond18.sh
-rwxr-xr-x 1000/1000 1818 2012-12-14 15:13 automake-1.12.6/t/vala-headers.sh
-rwxr-xr-x 1000/1000 1676 2012-12-14 22:28 automake-1.12.6/t/java-clean.sh
-rwxr-xr-x 1000/1000 1290 2012-12-14 22:28 automake-1.12.6/t/specflg6.sh
-rwxr-xr-x 1000/1000 1856 2012-12-14 22:28 automake-1.12.6/t/output7.sh
-rwxr-xr-x 1000/1000 1604 2012-12-14 22:28 automake-1.12.6/t/py-compile-basedir.sh
-rwxr-xr-x 1000/1000 1724 2012-12-14 22:28 automake-1.12.6/t/txinfo24.sh
-rwxr-xr-x 1000/1000 1928 2012-12-14 22:28 automake-1.12.6/t/txinfo28.sh
-rwxr-xr-x 1000/1000 2310 2012-12-14 22:28 automake-1.12.6/t/suffix10.tap
-rwxr-xr-x 1000/1000 1090 2012-12-14 22:28 automake-1.12.6/t/tap-planskip-later-errors.sh
-rwxr-xr-x 1000/1000 945 2012-12-14 22:28 automake-1.12.6/t/ar-lib7.sh
-rwxr-xr-x 1000/1000 1481 2012-12-14 22:28 automake-1.12.6/t/dist-auxfile-2.sh
-rwxr-xr-x 1000/1000 1399 2012-12-14 22:28 automake-1.12.6/t/tap-empty.sh
-rwxr-xr-x 1000/1000 1427 2012-12-14 22:28 automake-1.12.6/t/suffix9.sh
-rwxr-xr-x 1000/1000 1523 2012-12-14 22:28 automake-1.12.6/t/license.sh
-rwxr-xr-x 1000/1000 1372 2012-12-14 22:28 automake-1.12.6/t/tap-negative-numbers.sh
-rwxr-xr-x 1000/1000 1411 2012-12-14 22:28 automake-1.12.6/t/colon7.sh
-rwxr-xr-x 1000/1000 2192 2012-12-14 22:28 automake-1.12.6/t/primary-prefix-couples-documented-valid.sh
-rwxr-xr-x 1000/1000 4034 2012-12-14 22:28 automake-1.12.6/t/txinfo21.sh
-rwxr-xr-x 1000/1000 1942 2012-12-14 15:13 automake-1.12.6/t/vala-per-target-flags.sh
-rwxr-xr-x 1000/1000 1639 2012-12-14 22:28 automake-1.12.6/t/suffix-custom-subobj-and-specflg.sh
-rwxr-xr-x 1000/1000 909 2012-12-14 22:28 automake-1.12.6/t/prefix.sh
-rwxr-xr-x 1000/1000 1150 2012-12-14 22:28 automake-1.12.6/t/cond10.sh
-r-xr-xr-x 1000/1000 499 2012-12-15 15:04 automake-1.12.6/t/tap-planskip-unplanned-w.sh
-rwxr-xr-x 1000/1000 1765 2012-12-14 22:28 automake-1.12.6/t/aclocal-install-fail.sh
-r-xr-xr-x 1000/1000 496 2012-12-15 15:04 automake-1.12.6/t/check-tests-in-builddir-w.sh
-rwxr-xr-x 1000/1000 928 2012-12-14 22:28 automake-1.12.6/t/backsl3.sh
-rwxr-xr-x 1000/1000 872 2012-12-14 22:28 automake-1.12.6/t/comment.sh
-rwxr-xr-x 1000/1000 2501 2012-12-14 22:28 automake-1.12.6/t/dejagnu4.sh
-rwxr-xr-x 1000/1000 2387 2012-12-14 22:28 automake-1.12.6/t/yacc-nodist.sh
-rwxr-xr-x 1000/1000 1355 2012-12-14 22:28 automake-1.12.6/t/link_dist.sh
-rwxr-xr-x 1000/1000 2284 2012-12-14 22:28 automake-1.12.6/t/cond39.sh
-rwxr-xr-x 1000/1000 2539 2012-12-14 22:28 automake-1.12.6/t/vartypo2.sh
-rwxr-xr-x 1000/1000 928 2012-12-14 22:28 automake-1.12.6/t/exdir.sh
-rwxr-xr-x 1000/1000 1040 2012-12-14 22:28 automake-1.12.6/t/nodep.sh
-rwxr-xr-x 1000/1000 1695 2012-12-14 22:28 automake-1.12.6/t/suffix-chain.tap
-rwxr-xr-x 1000/1000 1039 2012-12-14 22:28 automake-1.12.6/t/comment3.sh
-rwxr-xr-x 1000/1000 1404 2012-12-14 22:28 automake-1.12.6/t/werror2.sh
-rwxr-xr-x 1000/1000 1096 2012-12-14 22:28 automake-1.12.6/t/cond44.sh
-r-xr-xr-x 1000/1000 471 2012-12-15 15:04 automake-1.12.6/t/tap-msg0-result-w.sh
-rwxr-xr-x 1000/1000 1600 2012-12-14 22:28 automake-1.12.6/t/acloca13.sh
-rwxr-xr-x 1000/1000 1647 2012-12-14 22:28 automake-1.12.6/t/suffix5.sh
-rwxr-xr-x 1000/1000 1854 2012-12-14 22:28 automake-1.12.6/t/am-tests-environment.sh
-rwxr-xr-x 1000/1000 1219 2012-12-14 22:28 automake-1.12.6/t/libobj15b.sh
-rwxr-xr-x 1000/1000 847 2012-12-14 22:28 automake-1.12.6/t/badopt.sh
-rwxr-xr-x 1000/1000 5751 2012-12-14 22:28 automake-1.12.6/t/silent-many-gcc.sh
-rwxr-xr-x 1000/1000 1193 2012-12-14 22:28 automake-1.12.6/t/ldadd.sh
-rwxr-xr-x 1000/1000 1253 2012-12-14 22:28 automake-1.12.6/t/hdr-vars-defined-once.sh
-rwxr-xr-x 1000/1000 1535 2012-12-14 22:28 automake-1.12.6/t/txinfo26.sh
-r-xr-xr-x 1000/1000 468 2012-12-15 15:04 automake-1.12.6/t/check-subst-prog-w.sh
-rwxr-xr-x 1000/1000 2579 2012-12-14 22:28 automake-1.12.6/t/stdlib2.sh
-rwxr-xr-x 1000/1000 1782 2012-12-14 22:28 automake-1.12.6/t/ansi2knr-no-more.sh
-rwxr-xr-x 1000/1000 1585 2012-12-14 22:28 automake-1.12.6/t/ltlibsrc.sh
-rwxr-xr-x 1000/1000 1193 2012-12-14 22:28 automake-1.12.6/t/subobj10.sh
-rwxr-xr-x 1000/1000 4573 2012-12-14 22:28 automake-1.12.6/t/maken3.sh
-r-xr-xr-x 1000/1000 471 2012-12-15 15:04 automake-1.12.6/t/tap-xfail-tests-w.sh
-rwxr-xr-x 1000/1000 1438 2012-12-14 22:28 automake-1.12.6/t/pr279-2.sh
-rwxr-xr-x 1000/1000 6757 2012-12-14 22:28 automake-1.12.6/t/silent-many-generic.sh
-rwxr-xr-x 1000/1000 3799 2012-12-14 22:28 automake-1.12.6/t/cscope.tap
-rwxr-xr-x 1000/1000 1618 2012-12-14 22:28 automake-1.12.6/t/self-check-explicit-skips.sh
-rwxr-xr-x 1000/1000 1348 2012-12-14 22:28 automake-1.12.6/t/posixsubst-extradist.sh
-rwxr-xr-x 1000/1000 1327 2012-12-14 22:28 automake-1.12.6/t/acloca19.sh
-rwxr-xr-x 1000/1000 2064 2012-12-14 01:32 automake-1.12.6/t/vala-vpath.sh
-rwxr-xr-x 1000/1000 2724 2012-12-14 01:32 automake-1.12.6/t/vala-mix2.sh
-r-xr-xr-x 1000/1000 432 2012-12-15 15:04 automake-1.12.6/t/check11-w.sh
-r-xr-xr-x 1000/1000 488 2012-12-15 15:04 automake-1.12.6/t/check-exported-srcdir-w.sh
-rwxr-xr-x 1000/1000 1400 2012-12-14 01:27 automake-1.12.6/t/self-check-shell-no-trail-bslash.sh
-rwxr-xr-x 1000/1000 1540 2012-12-14 22:28 automake-1.12.6/t/programs-primary-rewritten.sh
-rwxr-xr-x 1000/1000 1340 2012-12-14 22:28 automake-1.12.6/t/link_fccxx.sh
-rwxr-xr-x 1000/1000 3351 2012-12-14 22:28 automake-1.12.6/t/backcompat3.sh
-rwxr-xr-x 1000/1000 2503 2012-12-14 22:28 automake-1.12.6/t/aclocal-acdir.sh
-rwxr-xr-x 1000/1000 1359 2012-12-14 22:28 automake-1.12.6/t/init.sh
-rwxr-xr-x 1000/1000 1838 2012-12-14 22:28 automake-1.12.6/t/cond19.sh
-r-xr-xr-x 1000/1000 491 2012-12-15 15:04 automake-1.12.6/t/tap-planskip-bailout-w.sh
-rwxr-xr-x 1000/1000 1403 2012-12-14 22:28 automake-1.12.6/t/autodist-acconfig-no-subdir.sh
-rwxr-xr-x 1000/1000 2451 2012-12-14 22:28 automake-1.12.6/t/remake-gnulib-add-header.sh
-rwxr-xr-x 1000/1000 1541 2012-12-14 22:28 automake-1.12.6/t/yflags-var-expand.sh
-rwxr-xr-x 1000/1000 1321 2012-12-14 22:28 automake-1.12.6/t/link_fcxx.sh
-rwxr-xr-x 1000/1000 1688 2012-12-14 22:28 automake-1.12.6/t/dirlist.sh
-rwxr-xr-x 1000/1000 1835 2012-12-14 22:28 automake-1.12.6/t/tap-xfail-tests.sh
-r-xr-xr-x 1000/1000 455 2012-12-15 15:04 automake-1.12.6/t/tap-bailout-w.sh
-rwxr-xr-x 1000/1000 2912 2012-12-14 22:28 automake-1.12.6/t/acloca18.sh
-rwxr-xr-x 1000/1000 1419 2012-12-14 22:28 automake-1.12.6/t/nodep2.sh
-rwxr-xr-x 1000/1000 2976 2012-12-14 22:28 automake-1.12.6/t/instdir-no-empty.sh
-rwxr-xr-x 1000/1000 1302 2012-12-14 22:28 automake-1.12.6/t/aclocal3.sh
-rwxr-xr-x 1000/1000 1735 2012-12-14 22:28 automake-1.12.6/t/aclocal4.sh
-r-xr-xr-x 1000/1000 519 2012-12-15 15:04 automake-1.12.6/t/tap-with-and-without-number-w.sh
-rwxr-xr-x 1000/1000 2387 2012-12-14 22:28 automake-1.12.6/t/acloca10.sh
-rwxr-xr-x 1000/1000 2206 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-driver-install.sh
-rwxr-xr-x 1000/1000 1017 2012-12-14 22:28 automake-1.12.6/t/javasubst.sh
-rwxr-xr-x 1000/1000 2054 2012-12-14 22:28 automake-1.12.6/t/yaccvpath.sh
-rwxr-xr-x 1000/1000 1501 2012-12-14 22:28 automake-1.12.6/t/test-missing2.sh
-rwxr-xr-x 1000/1000 1626 2012-12-14 22:28 automake-1.12.6/t/subobj11c.sh
-rwxr-xr-x 1000/1000 1225 2012-12-14 22:28 automake-1.12.6/t/compile_f90_c_cxx.sh
-rwxr-xr-x 1000/1000 1371 2012-12-14 22:28 automake-1.12.6/t/tap-ambiguous-directive.sh
-rwxr-xr-x 1000/1000 3956 2012-12-14 22:28 automake-1.12.6/t/test-driver-custom-xfail-tests.sh
-rwxr-xr-x 1000/1000 2065 2012-12-14 22:28 automake-1.12.6/t/dist-missing-included-m4.sh
-rwxr-xr-x 1000/1000 2054 2012-12-14 22:28 automake-1.12.6/t/check4.sh
-rwxr-xr-x 1000/1000 2664 2012-12-14 22:28 automake-1.12.6/t/remake-after-makefile-am.sh
-rwxr-xr-x 1000/1000 1158 2012-12-14 22:28 automake-1.12.6/t/libtool5.sh
-rwxr-xr-x 1000/1000 1035 2012-12-14 22:28 automake-1.12.6/t/libobj3.sh
-rwxr-xr-x 1000/1000 1043 2012-12-14 22:28 automake-1.12.6/t/cxxlibobj.sh
-rwxr-xr-x 1000/1000 3427 2012-12-14 22:28 automake-1.12.6/t/spy.sh
-rwxr-xr-x 1000/1000 2195 2012-12-14 22:28 automake-1.12.6/t/yacc-dist-nobuild-subdir.sh
-rwxr-xr-x 1000/1000 2080 2012-12-14 22:28 automake-1.12.6/t/yaccpp.sh
-rwxr-xr-x 1000/1000 1214 2012-12-14 22:28 automake-1.12.6/t/cond43.sh
-rwxr-xr-x 1000/1000 2149 2012-12-14 22:28 automake-1.12.6/t/txinfo16.sh
-rwxr-xr-x 1000/1000 2554 2012-12-14 01:32 automake-1.12.6/t/vala-mix.sh
-rwxr-xr-x 1000/1000 2613 2012-12-14 22:28 automake-1.12.6/t/subdir-add2-pr46.sh
+ cd automake-1.12.6
-rwxr-xr-x 1000/1000 2182 2012-12-14 22:28 automake-1.12.6/t/python10.sh
-rwxr-xr-x 1000/1000 2106 2012-12-14 22:28 automake-1.12.6/t/fort4.sh
+ /bin/chmod -R a+rX,g-w,o-w .
-rwxr-xr-x 1000/1000 1935 2012-12-14 22:28 automake-1.12.6/t/conffile-leading-dot.sh
-rwxr-xr-x 1000/1000 1605 2012-12-14 22:28 automake-1.12.6/t/aclocal.sh
-rwxr-xr-x 1000/1000 1682 2012-12-14 22:28 automake-1.12.6/t/mmode.sh
-rwxr-xr-x 1000/1000 1113 2012-12-14 22:28 automake-1.12.6/t/alloca2.sh
-r-xr-xr-x 1000/1000 479 2012-12-15 15:04 automake-1.12.6/t/tap-driver-stderr-w.sh
-rwxr-xr-x 1000/1000 1141 2012-12-14 22:28 automake-1.12.6/t/mdate4.sh
-r-xr-xr-x 1000/1000 471 2012-12-15 15:04 automake-1.12.6/t/tap-plan-middle-w.sh
-rwxr-xr-x 1000/1000 2580 2012-12-14 22:28 automake-1.12.6/t/subdir-add-pr46.sh
-rwxr-xr-x 1000/1000 1363 2012-12-14 22:28 automake-1.12.6/t/java-no-duplicate.sh
-rwxr-xr-x 1000/1000 3362 2012-12-14 22:28 automake-1.12.6/t/parallel-tests2.sh
-rwxr-xr-x 1000/1000 1703 2012-12-14 22:28 automake-1.12.6/t/nodef.sh
-rwxr-xr-x 1000/1000 1311 2012-12-14 22:28 automake-1.12.6/t/link_f_only.sh
-rwxr-xr-x 1000/1000 1848 2012-12-14 22:28 automake-1.12.6/t/deleted-am.sh
-rwxr-xr-x 1000/1000 1178 2012-12-14 22:28 automake-1.12.6/t/tap-msg0-bailout.sh
-rwxr-xr-x 1000/1000 926 2012-12-14 22:28 automake-1.12.6/t/txinfo6.sh
-r-xr-xr-x 1000/1000 515 2012-12-15 15:04 automake-1.12.6/t/tap-no-merge-stdout-stderr-w.sh
-rwxr-xr-x 1000/1000 1429 2012-12-14 22:28 automake-1.12.6/t/missing4.sh
-rwxr-xr-x 1000/1000 1445 2012-12-14 22:28 automake-1.12.6/t/gnuwarn.sh
-rwxr-xr-x 1000/1000 2082 2012-12-14 22:28 automake-1.12.6/t/aclocal-path-install-serial.sh
-rwxr-xr-x 1000/1000 1547 2012-12-14 22:28 automake-1.12.6/t/output12.sh
-rwxr-xr-x 1000/1000 2095 2012-12-14 22:28 automake-1.12.6/t/subobj11a.sh
-rwxr-xr-x 1000/1000 1143 2012-12-14 22:28 automake-1.12.6/t/depend6.sh
-rwxr-xr-x 1000/1000 1490 2012-12-14 22:28 automake-1.12.6/t/confsub.sh
-rwxr-xr-x 1000/1000 936 2012-12-14 22:28 automake-1.12.6/t/spell.sh
-rwxr-xr-x 1000/1000 1050 2012-12-14 22:28 automake-1.12.6/t/unused.sh
-rwxr-xr-x 1000/1000 1905 2012-12-14 22:28 automake-1.12.6/t/python-dist.sh
-rwxr-xr-x 1000/1000 1403 2012-12-14 22:28 automake-1.12.6/t/empty-sources-primary.tap
-rwxr-xr-x 1000/1000 1734 2012-12-14 22:28 automake-1.12.6/t/pluseq9.sh
-rwxr-xr-x 1000/1000 945 2012-12-14 22:28 automake-1.12.6/t/libobj4.sh
-r-xr-xr-x 1000/1000 428 2012-12-15 15:04 automake-1.12.6/t/check4-w.sh
-rwxr-xr-x 1000/1000 1466 2012-12-14 22:28 automake-1.12.6/t/libtoo10.sh
-rwxr-xr-x 1000/1000 1106 2012-12-14 22:28 automake-1.12.6/t/pr72.sh
-rwxr-xr-x 1000/1000 1349 2012-12-14 22:28 automake-1.12.6/t/dejagnu6.sh
-rwxr-xr-x 1000/1000 983 2012-12-14 22:28 automake-1.12.6/t/override-html.sh
-rwxr-xr-x 1000/1000 2449 2012-12-14 22:28 automake-1.12.6/t/check-tests-in-builddir.sh
-rwxr-xr-x 1000/1000 2890 2012-12-14 22:28 automake-1.12.6/t/am-missing-prog.sh
-rwxr-xr-x 1000/1000 2934 2012-12-14 22:28 automake-1.12.6/t/aclocal7.sh
-rwxr-xr-x 1000/1000 1452 2012-12-14 22:28 automake-1.12.6/t/cygnus-no-installinfo.sh
-rwxr-xr-x 1000/1000 1247 2012-12-14 22:28 automake-1.12.6/t/pr266.sh
-rwxr-xr-x 1000/1000 1355 2012-12-14 22:28 automake-1.12.6/t/auxdir8.sh
-rwxr-xr-x 1000/1000 2080 2012-12-14 22:28 automake-1.12.6/t/self-check-is_newest.tap
-rwxr-xr-x 1000/1000 1660 2012-12-14 22:28 automake-1.12.6/t/cygnus-dependency-tracking.sh
-rwxr-xr-x 1000/1000 3854 2012-12-14 22:28 automake-1.12.6/t/parallel-tests-interrupt.tap
-rwxr-xr-x 1000/1000 1035 2012-12-14 22:28 automake-1.12.6/t/badline.sh
-rwxr-xr-x 1000/1000 1052 2012-12-14 22:28 automake-1.12.6/t/ar3.sh
-rwxr-xr-x 1000/1000 2926 2012-12-14 22:28 automake-1.12.6/t/location.sh
-rwxr-xr-x 1000/1000 1392 2012-12-14 22:28 automake-1.12.6/t/substtarg.sh
-rwxr-xr-x 1000/1000 1289 2012-12-14 22:28 automake-1.12.6/t/instsh3.sh
-rw-r--r-- 1000/1000 256772 2012-12-14 22:28 automake-1.12.6/automake.in
drwxr-xr-x 1000/1000 0 2012-12-15 22:26 automake-1.12.6/doc/
drwxr-xr-x 1000/1000 0 2012-12-15 22:25 automake-1.12.6/doc/amhello/
-rw-r--r-- 1000/1000 225 2012-12-14 01:27 automake-1.12.6/doc/amhello/Makefile.am
-rw-r--r-- 1000/1000 100 2012-12-14 01:17 automake-1.12.6/doc/amhello/README
drwxr-xr-x 1000/1000 0 2012-12-15 22:25 automake-1.12.6/doc/amhello/src/
-rw-r--r-- 1000/1000 232 2012-12-14 01:27 automake-1.12.6/doc/amhello/src/Makefile.am
-rw-r--r-- 1000/1000 328 2012-12-14 01:27 automake-1.12.6/doc/amhello/src/main.c
-rw-r--r-- 1000/1000 384 2012-12-14 01:27 automake-1.12.6/doc/amhello/configure.ac
-rw-r--r-- 1000/1000 233720 2012-12-15 15:04 automake-1.12.6/doc/automake.info-2
-rw-r--r-- 1000/1000 7679 2012-12-15 15:04 automake-1.12.6/doc/automake.info
-rw-r--r-- 1000/1000 75807 2012-12-15 15:05 automake-1.12.6/doc/amhello-1.0.tar.gz
-rw-r--r-- 1000/1000 75111 2012-12-15 15:04 automake-1.12.6/doc/automake.info-3
-rw-r--r-- 1000/1000 78473 2012-12-15 15:05 automake-1.12.6/doc/automake-history.info
-rw-r--r-- 1000/1000 23549 2012-12-14 01:27 automake-1.12.6/doc/fdl.texi
-rw-r--r-- 1000/1000 299158 2012-12-15 15:04 automake-1.12.6/doc/automake.info-1
-rw-r--r-- 1000/1000 515710 2012-12-14 22:28 automake-1.12.6/doc/automake.texi
-rw-r--r-- 1000/1000 52598 2012-12-14 01:27 automake-1.12.6/doc/automake-history.texi
-rw-r--r-- 1000/1000 103 2012-12-15 15:04 automake-1.12.6/doc/version.texi
-rw-r--r-- 1000/1000 103 2012-12-15 15:04 automake-1.12.6/doc/stamp-vti
-rwxr-xr-x 1000/1000 16688 2012-12-14 01:27 automake-1.12.6/doc/help2man
-rw-r--r-- 1000/1000 1348 2012-12-15 15:04 automake-1.12.6/aclocal.m4
-rw-r--r-- 1000/1000 96774 2012-12-14 22:28 automake-1.12.6/NEWS
+ cd /home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1
+ SB_CXC=no
==> clean %{buildroot}: /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root
+ echo '==> clean %{buildroot}: /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root'
+ /bin/rm -rf /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root
+ /bin/mkdir -p /home/lunatic/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-linux-gnu-1-root-root
==> %build:
+ echo '==> %build:'
++ pwd
+ build_top=/home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1
+ export PATH=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/develpment/rtems/bin:/home/lunatic/development/rtems/rsb/source-builder:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root-cxc/devel/autotools-internal.bset/home/develpment/rtems/bin:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/develpment/rtems/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ PATH=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/develpment/rtems/bin:/home/lunatic/development/rtems/rsb/source-builder:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root-cxc/devel/autotools-internal.bset/home/develpment/rtems/bin:/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/develpment/rtems/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ test yes = yes
+ am_prefix=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/develpment/rtems
+ test x86_64-linux-gnu '!=' x86_64-linux-gnu
+ export CFLAGS CFLAGS_FOR_BUILD CC
+ CFLAGS='-O2 -pipe -I/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/devel/autotools-internal.bset/home/develpment/rtems/include '
+ ./configure --build=x86_64-linux-gnu --host=x86_64-linux-gnu --verbose --prefix=/home/lunatic/development/rtems/rsb/rtems/build/tmp/sb-root/home/develpment/rtems
checking whether make supports nested variables... yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether ln -s works... yes
checking for perl... /bin/perl
checking whether /bin/perl supports ithreads... yes
checking for tex... no
checking for yacc... no
checking for byacc... no
checking for bison... bison -y
checking for lex... lex
checking whether autoconf is installed... yes
checking whether autoconf works... yes
checking whether autoconf is recent enough... yes
checking whether ln works... yes
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
configure: will now look for a sturdy POSIX shell, for our testsuite
checking for sh... /bin/sh
checking for sh5... no
checking for dash... no
checking for ash... no
checking for bash... /bin/bash
checking for zsh... no
checking for ksh... no
checking for pdksh... no
checking whether /bin/sh supports $(cmd)... yes
checking whether /bin/sh supports $((expr))... yes
checking whether /bin/sh supports ${#var}... yes
checking whether /bin/sh supports ${var#glob} and ${var%glob}... yes
checking whether /bin/sh preserves exit traps with "set -e"... yes
checking whether /bin/sh can define exit traps in a shell function... yes
checking whether /bin/sh corrupts stderr with "set -x"... no
checking whether /bin/sh can return early from "dot-sourced" files... yes
checking whether /bin/sh supports alias named like shell builtins... yes
checking whether /bin/sh supports "test -e"... yes
configure: shell /bin/sh is good enough, stop looking
configure: will use /bin/sh as the testsuite shell
configure: will now look for generic compilers
checking for x86_64-linux-gnu-cc... no
checking for x86_64-linux-gnu-gcc... no
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking for x86_64-linux-gnu-aCC... no
checking for x86_64-linux-gnu-CC... no
checking for x86_64-linux-gnu-FCC... no
checking for x86_64-linux-gnu-KCC... no
checking for x86_64-linux-gnu-RCC... no
checking for x86_64-linux-gnu-xlC_r... no
checking for x86_64-linux-gnu-xlC... no
checking for x86_64-linux-gnu-c++... no
checking for x86_64-linux-gnu-cxx... no
checking for x86_64-linux-gnu-cc++... no
checking for x86_64-linux-gnu-gpp... no
checking for x86_64-linux-gnu-g++... no
checking for aCC... no
checking for CC... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking for x86_64-linux-gnu-xlf95... no
checking for x86_64-linux-gnu-f95... no
checking for x86_64-linux-gnu-fort... no
checking for x86_64-linux-gnu-ifort... no
checking for x86_64-linux-gnu-ifc... no
checking for x86_64-linux-gnu-efc... no
checking for x86_64-linux-gnu-pgfortran... no
checking for x86_64-linux-gnu-pgf95... no
checking for x86_64-linux-gnu-lf95... no
checking for x86_64-linux-gnu-ftn... no
checking for x86_64-linux-gnu-nagfor... no
checking for x86_64-linux-gnu-xlf90... no
checking for x86_64-linux-gnu-f90... no
checking for x86_64-linux-gnu-pgf90... no
checking for x86_64-linux-gnu-pghpf... no
checking for x86_64-linux-gnu-epcf90... no
checking for x86_64-linux-gnu-g95... no
checking for x86_64-linux-gnu-gfortran... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgfortran... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking for nagfor... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for g95... no
checking for gfortran... no
checking whether the Fortran compiler works... no
configure: WARNING: Fortran compiler cannot create executables
configure: tests requiring the Fortran compiler will be skipped
checking for x86_64-linux-gnu-xlf... no
checking for x86_64-linux-gnu-f77... no
checking for x86_64-linux-gnu-frt... no
checking for x86_64-linux-gnu-pgf77... no
checking for x86_64-linux-gnu-cf77... no
checking for x86_64-linux-gnu-fort77... no
checking for x86_64-linux-gnu-fl32... no
checking for x86_64-linux-gnu-af77... no
checking for x86_64-linux-gnu-g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for g77... no
checking whether the Fortran 77 compiler works... no
configure: WARNING: Fortran 77 compiler cannot create executables
configure: tests requiring the Fortran 77 compiler will be skipped
configure: will now look for GNU compilers
configure: cc is already a GNU C compiler
configure: c++ is already a GNU C++ compiler
checking for x86_64-linux-gnu-gcj... no
checking for gcj... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating t/wrap/aclocal-1.12
config.status: creating t/wrap/automake-1.12
+ make -j 4 all
GEN automake
GEN aclocal
GEN t/ax/shell-no-trail-bslash
GEN runtest
GEN doc/aclocal.1
GEN doc/automake.1
GEN lib/Automake/Config.pm
GEN t/ax/test-defs.sh
GEN doc/aclocal-1.12.1
GEN doc/automake-1.12.1
help2man: can't get `--help' info from automake-1.12
Try `--no-discard-stderr' if option outputs to stderr
make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
make: *** Waiting for unfinished jobs....
shell cmd failed: /bin/sh -ex /home/lunatic/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-linux-gnu-1/doit
