Query regarding libbsd update
Udit agarwal
dev.madaari at gmail.com
Sat Mar 17 21:59:35 UTC 2018
Hi,
Thanks for pointing that out. I think back porting the driver would be the
most viable option. So, i'll move ahead with that.
Since, my proposal is almost ready, considering other libbsd projects at
this time, would be a bit difficult.
Thanks and regards,
Udit agarwal
On Sun, Mar 18, 2018 at 2:39 AM, Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 17.03.2018 um 19:40 schrieb Udit agarwal:
> > Hi Sebastian, Hi all,
> > One part of my GSoC project consists of importing SDIO driver from
> > FreeBSD head (as on july 2017 or later). As far as importing is
> > concerned there is a lot of information in libbsd.txt or on previous
> > GSoC student's blogs which can help me understand the process. However,
> > before importing i also need to update libbsd base to FreeBSD head(as on
> > july 2017 or later). I couldn't find much information regarding this
> > update process. It would be really helpful if you point me towards its
> > relevant documentation or give me a gist of the whole process. That
> > would again help me understand the process better, and thus propose a
> > more elaborated and realistic time-line.
> > Thanks and Regards
> > Udit agarwal
> Hello Udit,
> there is no step-by-step guide (or any other guide) regarding a complete
> FreeBSD update. That has to do with the fact that there is no standard
> way to do it. Each update is quite unique.
> The basic steps are the following ones:
> - Use the freebsd-to-rtems.py script to move the changes to freebsd-org
> folder.
> - Rebase the changes in freebsd-org to the latest head.
> - Re-Import the files with freebsd-to-rtems.py.
> - Take a look at what changed in FreeBSD and fix everything.
> The first three are easy. The last one is really hard if you don't know
> the code.
> I have seen that you are able to search through code quite quickly. But
> I also have seen that you had some trouble with the mutex in the
> getentropy patch. Although I'm sure you don't have problems learning the
> necessary basics I think that it is quite likely that it will use up too
> much time of the project. So I would suggest to plan the alternative
> solution: Backport the driver. Although with that there will be no patch
> that we can integrate into the current libbsd, it is a solution that is
> doable in the scope of your GSoC project.
> If you prefer to produce code that will be integrated quickly, you can
> still think about the other libbsd projects.
> Regards
> Christian Mauderer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/c95fc69d/attachment.html>
