autotools build fail from rsb
Sun Mar 18 10:31:31 UTC 2018
On Sat, Mar 17, 2018 at 12:37 PM, Joel Sherrill <joel at rtems.org> wrote:
> I answered what I think the cause is on another thread.
> Take the ancient RTEMS autotools out of your PATH while building qemu. Use a
> PATH without RTEMS tools in it. I think the ancient automake version we use
> must have --help which help2man can't parse.
I don't think this is the solution, because the failure happens while
trying to build the autotools.
> On Mar 17, 2018 11:34 AM, "Vijay Kumar Banerjee" <vijaykumar9597 at gmail.com>
> wrote:
>> hello ,
>> As suggested by Gedare , I have started this thread on the build error
>> that I'm getting .
>> I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error while trying
>> to build autotools from rsb
>> I'm using fedora 27 64bit .
>> P.S: the error report is attached
>> -- vijay
