autotools build fail from rsb
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Mar 18 10:36:28 UTC 2018
I have set the PATH like this
/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/luna
tic/.local/bin:/home/lunatic/bin
I'm still getting the same error
-- vijay
On 18 March 2018 at 16:01, Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Mar 17, 2018 at 12:37 PM, Joel Sherrill <joel at rtems.org> wrote:
> > I answered what I think the cause is on another thread.
> > Take the ancient RTEMS autotools out of your PATH while building qemu.
> Use a
> > PATH without RTEMS tools in it. I think the ancient automake version we
> use
> > must have --help which help2man can't parse.
> I don't think this is the solution, because the failure happens while
> trying to build the autotools.
> > On Mar 17, 2018 11:34 AM, "Vijay Kumar Banerjee" <
> vijaykumar9597 at gmail.com>
> > wrote:
> >> hello ,
> >> As suggested by Gedare , I have started this thread on the build error
> >> that I'm getting .
> >> I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error while
> trying
> >> to build autotools from rsb
> >> I'm using fedora 27 64bit .
> >> P.S: the error report is attached
> >> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/2e70f2e2/attachment.html>
