autotools build fail from rsb
Sun Mar 18 10:41:21 UTC 2018
Vijay,
On Sun, Mar 18, 2018 at 6:36 AM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> I have set the PATH like this
> /usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/home/lunatic/.local/bin:/home/lunatic/bin
> I'm still getting the same error
> -- vijay
> On 18 March 2018 at 16:01, Gedare Bloom <gedare at rtems.org> wrote:
>> On Sat, Mar 17, 2018 at 12:37 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > I answered what I think the cause is on another thread.
>> > Take the ancient RTEMS autotools out of your PATH while building qemu.
>> > Use a
>> > PATH without RTEMS tools in it. I think the ancient automake version we
>> > use
>> > must have --help which help2man can't parse.
>> I don't think this is the solution, because the failure happens while
>> trying to build the autotools.
What happens when you run on the command line:
$> automake-1.12 --help
>> > On Mar 17, 2018 11:34 AM, "Vijay Kumar Banerjee"
>> > wrote:
>> >> hello ,
>> >> As suggested by Gedare , I have started this thread on the build error
>> >> that I'm getting .
>> >> I'm getting automake-1.12.6-x86_64-linux-gnu-1 building error while
>> >> trying
>> >> to build autotools from rsb
>> >> I'm using fedora 27 64bit .
>> >> P.S: the error report is attached
>> >> -- vijay
