[PATCH] Eliminate config.inc.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Mar 20 09:57:29 UTC 2018
Am 20.03.2018 um 02:14 schrieb Chris Johns:
> On 20/03/2018 02:16, Christian Mauderer wrote:
>> Most of the values in config.inc haven't been used any more. The only
>> part left has been the ip addresses for some of the test.
> Why not just removed the parts not being used?
>> All other values are not used and might irritate new users.
> Why would it? It would irritate existing "users" if the hard coded set up
> conflicts with any networks they use.
> I do not agree with a hard coded set of addresses and I cannot see a compelling
> reason given in this patch to do this.
> The way the setting of these is currently handled may end up being part of the
> #3351 resolution once that ticket's path is resolved.
>> Generating the header for the network configuration adds quite some
>> lines to the build system.
> It is not that much, it exists and it works. The code being removed is about 30
> lines while the generated waf script is over 3000 lines long.
> How is this complicating the build system?
I think it is currently the only generated header file. Therefore it is
a special case and special cases are always hard to handle. But I'll
re-do the patch so that it only removes the parts that are not used or
never worked.
>> On the other side it seems not really that
>> necessary to make the network configuration for the tests configurable.
> Why?
>> Therefore this patch elimintates that too and uses fixed IP addresses in
>> the (previously generated) network-config.h header instead. If someone
>> really needs to run the tests with some other IP addresses, he still can
>> locally change the header (instead of the config.inc).
> Sorry, lets not go there. As a policy I would like to see RTEMS avoid touching
> code this way so tests can run. Saying this requires developers walk patches
> through repeated changes to the repo and that is an overhead for them, it
> complicates continuous integration set ups and it added complexity to an audit
> process wanting to run any certification effort.
>>  config.inc                                         | 15 --------
>>  libbsd.txt                                         | 30 +++------------
>>  libbsd_waf.py                                      | 36 -----------------
>>  .../test/{network-config.h.in => network-config.h} |  8 ++--
>>  waf_generator.py                                   | 45 ----------------------
>>  wscript                                            |  5 ---
>>  6 files changed, 10 insertions(+), 129 deletions(-)
>>  delete mode 100644 config.inc
>>  rename testsuite/include/rtems/bsd/test/{network-config.h.in => network-config.h} (92%)
>> diff --git a/config.inc b/config.inc
>> deleted file mode 100644
>> index 3432a5fc..00000000
>> --- a/config.inc
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -# Mandatory: Select your BSP and installation prefix
>> -TARGET = arm-rtems4.11
>> -BSP = realview_pbx_a9_qemu
>> -PREFIX = /opt/rtems-4.11
>> -# Optional: Separate installation base directory
>> -INSTALL_BASE = $(PREFIX)/$(TARGET)/$(BSP)
>> -# Optional: Network test configuration
>> -TEST_RUNNER = $(BSP)
>> -NET_CFG_SELF_IP = 10.0.2.1
>> -NET_CFG_NETMASK = 255.255.0.0
>> -NET_CFG_PEER_IP = 192.168.100.11
>> -NET_CFG_GATEWAY_IP = 192.168.100.11
>> -NET_TAP_INTERFACE = tap0
>> diff --git a/libbsd.txt b/libbsd.txt
>> index 71d5cc8d..d57d1884 100644
>> --- a/libbsd.txt
>> +++ b/libbsd.txt
>> @@ -42,7 +42,6 @@ installed.
>>  . Clone the Git repository +git clone git://git.rtems.org/rtems-libbsd.git+.
>>  . Change into the RTEMS BSD library root directory.
>> -. Edit the `config.inc` configuration file and adjust it to your environment.
>>  . Run +waf configure ...+.
>>  . Run +waf+.
>>  . Run +waf install+.
>> @@ -119,29 +118,6 @@ devices (you can run multiple test instances on one virtual network).
>>  The build system based on the Waf build system. To build with Waf please refer
>>  to the README.waf file.
>> -===== Example Configuration =====
>> -In the BSD library source directory edit the file `config.inc`.  Continuing on
>> -the above, the `config.inc` used to match the above is:
>> -TARGET = arm-rtems4.12
>> -BSP = xilinx_zynq_a9_qemu
>> -PREFIX = $(HOME)/sandbox/install
>> -NET_CFG_SELF_IP = 10.0.0.2
>> -NET_CFG_PEER_IP = 10.0.0.1
>> -NET_CFG_GATEWAY_IP = 10.0.0.1
>>  === BSD Library Initialization ===
>>  To initialise the BSD Library create a suitable rc.conf file. The FreeBSD man
>> @@ -273,6 +249,12 @@ their own implementation of the `rtems_bsd_get_allocator_domain_size()`
>>  function (for example in the module which calls `rtems_bsd_initialize()`) if
>>  different values are desired.  The default size is 8MiB for all domains.
>> +=== Tests ===
>> +There are tests for some features in the `testsuite` directory. Note that some
>> +of the tests use a fixed IP configuration that is defined in
>> +`testsuite/include/rtems/bsd/test/network-config.h`.
> It is not clear to me in this documentation how a developer who has clashing
> networks is suppose to handle these static settings and nothing here explains
> what what to do.
>>  == Network Stack Features
>>  http://roy.marples.name/projects/dhcpcd/index[DHCPCD(8)]:: DHCP client
>> diff --git a/libbsd_waf.py b/libbsd_waf.py
>> index 745512bf..642142e2 100644
>> --- a/libbsd_waf.py
>> +++ b/libbsd_waf.py
>> @@ -91,42 +91,6 @@ def build(bld):
>>      # Collect the libbsd uses
>>      libbsd_use = []
>> -    # Network test configuration
>> -    if not os.path.exists(bld.env.NET_CONFIG):
>> -        bld.fatal("network configuraiton '%s' not found" % (bld.env.NET_CONFIG))
>> -    net_cfg_self_ip = None
>> -    net_cfg_netmask = None
>> -    net_cfg_peer_ip = None
>> -    net_cfg_gateway_ip = None
>> -    net_tap_interface = None
>> -    try:
>> -        net_cfg_lines = open(bld.env.NET_CONFIG).readlines()
>> -    except:
>> -        bld.fatal("network configuraiton '%s' read failed" % (bld.env.NET_CONFIG))
>> -    lc = 0
>> -    for l in net_cfg_lines:
>> -        lc += 1
>> -        if l.strip().startswith("NET_CFG_"):
>> -            ls = l.split("=")
>> -            if len(ls) != 2:
>> -                bld.fatal("network configuraiton '%s' parse error: %d: %s" % (bld.env.NET_CONFIG, lc, l))
>> -            lhs = ls[0].strip()
>> -            rhs = ls[1].strip()
>> -            if lhs == "NET_CFG_SELF_IP":
>> -                net_cfg_self_ip = rhs
>> -            if lhs == "NET_CFG_NETMASK":
>> -                net_cfg_netmask = rhs
>> -            if lhs == "NET_CFG_PEER_IP":
>> -                net_cfg_peer_ip = rhs
>> -            if lhs == "NET_CFG_GATEWAY_IP":
>> -                net_cfg_gateway_ip = rhs
>> -            if lhs == "NET_TAP_INTERFACE":
>> -                net_tap_interface = rhs
>> -    bld(target = "testsuite/include/rtems/bsd/test/network-config.h",
>> -        source = "testsuite/include/rtems/bsd/test/network-config.h.in",
>> -        rule = "sed -e 's/@NET_CFG_SELF_IP@/%s/' -e 's/@NET_CFG_NETMASK@/%s/' -e 's/@NET_CFG_PEER_IP@/%s/' -e 's/@NET_CFG_GATEWAY_IP@/%s/' < ${SRC} > ${TGT}" % (net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_gateway_ip),
>> -        update_outputs = True)
>>      # copy headers if necessary
>>      header_build_copy_paths = [
>>                                 ('freebsd/crypto/openssl/crypto', '*.h', 'openssl'),
>> diff --git a/testsuite/include/rtems/bsd/test/network-config.h.in b/testsuite/include/rtems/bsd/test/network-config.h
>> similarity index 92%
>> rename from testsuite/include/rtems/bsd/test/network-config.h.in
>> rename to testsuite/include/rtems/bsd/test/network-config.h
>> index 2cef97db..c7350011 100755
>> --- a/testsuite/include/rtems/bsd/test/network-config.h.in
>> +++ b/testsuite/include/rtems/bsd/test/network-config.h
>> @@ -54,12 +54,12 @@
>>    #define NET_CFG_INTERFACE_0 "lo0"
>>  #endif
>> -#define NET_CFG_SELF_IP "@NET_CFG_SELF_IP@"
>> +#define NET_CFG_SELF_IP "10.0.2.1"
> I am OK with 192.168.0.1.
> ... then again that is a default used by most routers and a widely used network
> set up including the RTEMS server's internal networks and why my local networks
> are based around 10.* networks including subnets, VPNs, VLANs and PPT high speed
> server interconnects.
>> -#define NET_CFG_NETMASK "@NET_CFG_NETMASK@"
>> +#define NET_CFG_NETMASK "255.255.0.0"
> I would prefer 255.255.255.0.
>> -#define NET_CFG_PEER_IP "@NET_CFG_PEER_IP@"
>> +#define NET_CFG_PEER_IP "192.168.100.11"
> If the address above it changed what is used here ...
>> -#define NET_CFG_GATEWAY_IP "@NET_CFG_GATEWAY_IP@"
>> +#define NET_CFG_GATEWAY_IP "192.168.100.11"
> Anyway I think I have made my point :)
> Chris
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
