[PATCH 3/3] bsp/powerpc: Move libcpu timer to bsps
Wed Mar 21 07:16:34 UTC 2018
Use only one timer driver variant based on the standard PowerPC time
base.
This patch is a part of the BSP source reorganization.
Update #3285.
 .../timer.c => bsps/powerpc/shared/ppc-dec-timer.c |   0
 bsps/powerpc/ss555/dev/timer.c                     | 104 ---------------------
 c/src/lib/libbsp/powerpc/beatnik/Makefile.am       |   2 +-
 c/src/lib/libbsp/powerpc/gen5200/Makefile.am       |   4 +-
 c/src/lib/libbsp/powerpc/gen83xx/Makefile.am       |   2 +-
 c/src/lib/libbsp/powerpc/haleakala/Makefile.am     |   4 +-
 .../libbsp/powerpc/haleakala/startup/bspstart.c    |   5 -
 .../libbsp/powerpc/motorola_powerpc/Makefile.am    |   2 +-
 c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am    |   4 +-
 c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am    |   4 +-
 .../libbsp/powerpc/mpc8260ads/startup/bspstart.c   |   4 -
 c/src/lib/libbsp/powerpc/mvme3100/Makefile.am      |   2 +-
 c/src/lib/libbsp/powerpc/mvme5500/Makefile.am      |   2 +-
 c/src/lib/libbsp/powerpc/psim/Makefile.am          |   2 +-
 c/src/lib/libbsp/powerpc/qemuppc/Makefile.am       |   4 +-
 c/src/lib/libbsp/powerpc/ss555/Makefile.am         |   2 +-
 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c  |   4 -
 c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am        |   4 +-
 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c |   6 --
 c/src/lib/libbsp/powerpc/virtex/Makefile.am        |   5 +-
 .../lib/libbsp/powerpc/virtex/timer/timer-config.c |  58 ------------
 c/src/lib/libbsp/powerpc/virtex4/Makefile.am       |   4 +-
 .../lib/libbsp/powerpc/virtex4/startup/bspstart.c  |   4 -
 c/src/lib/libbsp/powerpc/virtex5/Makefile.am       |   4 +-
 .../lib/libbsp/powerpc/virtex5/startup/bspstart.c  |   4 -
 c/src/lib/libcpu/powerpc/Makefile.am               |  38 --------
 c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c     | 103 --------------------
 c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c      |  94 -------------------
 c/src/lib/libcpu/powerpc/ppc403/timer/timer.c      |  73 ---------------
 29 files changed, 24 insertions(+), 524 deletions(-)
 rename c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c => bsps/powerpc/shared/ppc-dec-timer.c (100%)
 delete mode 100644 bsps/powerpc/ss555/dev/timer.c
 delete mode 100644 c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c
 delete mode 100644 c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
 delete mode 100644 c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
 delete mode 100644 c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c b/bsps/powerpc/shared/ppc-dec-timer.c
similarity index 100%
rename from c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c
rename to bsps/powerpc/shared/ppc-dec-timer.c
diff --git a/bsps/powerpc/ss555/dev/timer.c b/bsps/powerpc/ss555/dev/timer.c
deleted file mode 100644
index 65deae961e..0000000000
--- a/bsps/powerpc/ss555/dev/timer.c
+++ /dev/null
@@ -1,104 +0,0 @@
- *  @file
- *  @brief Timer Driver for the PowerPC MPC5xx.
- *  This file manages the interval timer on the PowerPC MPC5xx.
- *  @noe This is not the PIT, but rather the RTEMS interval timer.
- *  We shall use the bottom 32 bits of the timebase register,
- *  MPC5xx port sponsored by Defence Research and Development Canada - Suffield
- *  Copyright (C) 2004, Real-Time Systems Inc. (querbach at realtime.bc.ca)
- *  Derived from c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c:
- *  Author: Jay Monkman (jmonkman at frasca.com)
- *  Copywright (C) 1998 by Frasca International, Inc.
- *  Derived from c/src/lib/libcpu/ppc/ppc403/timer/timer.c:
- *  Author:     Andrew Bray <andy at i-cubed.co.uk>
- *  COPYRIGHT (c) 1995 by i-cubed ltd.
- *  To anyone who acknowledges that this file is provided "AS IS"
- *  without any express or implied warranty:
- *      permission to use, copy, modify, and distribute this file
- *      for any purpose is hereby granted without fee, provided that
- *      the above copyright notice and this notice appears in all
- *      copies, and that the name of i-cubed limited not be used in
- *      advertising or publicity pertaining to distribution of the
- *      software without specific, written prior permission.
- *      i-cubed limited makes no representations about the suitability
- *      of this software for any purpose.
- *  Derived from c/src/lib/libcpu/hppa1_1/timer/timer.c:
- *  COPYRIGHT (c) 1989-2007.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <rtems/btimer.h>
-#include <mpc5xx.h>
-static volatile uint32_t Timer_starting;
-static bool benchmark_timer_find_average_overhead;
-extern uint32_t bsp_timer_least_valid;
-extern uint32_t bsp_timer_average_overhead;
- *  This is so small that this code will be reproduced where needed.
-static inline uint32_t get_itimer(void)
-   uint32_t ret;
-   __asm__ volatile ("mftb %0" : "=r" ((ret))); /* TBLO */
-   return ret;
-void benchmark_timer_initialize(void)
-  /* set interrupt level and enable timebase. This should never */
-  /*  generate an interrupt however. */
-  usiu.tbscrk = USIU_UNLOCK_KEY;
-  usiu.tbscr |= USIU_TBSCR_TBIRQ(4) 	/* interrupt priority level */
-              | USIU_TBSCR_TBF 		/* freeze timebase during debug */
-              | USIU_TBSCR_TBE;		/* enable timebase */
-  usiu.tbscrk = 0;
-  Timer_starting = get_itimer();
-benchmark_timer_t benchmark_timer_read(void)
-  uint32_t clicks;
-  uint32_t total;
-  clicks = get_itimer();
-  total = clicks - Timer_starting;
-  if ( benchmark_timer_find_average_overhead == 1 )
-    return total;          /* in XXX microsecond units */
-  else {
-    if ( total < bsp_timer_least_valid ) {
-      return 0;            /* below timer resolution */
-    return (total - bsp_timer_average_overhead);
-void benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
-  benchmark_timer_find_average_overhead = find_flag;
diff --git a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
index 30ad34a881..d9a45d6c17 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
@@ -165,10 +165,10 @@ libbsp_a_SOURCES += ../../shared/tod.c tod/todcfg.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/cache/cache.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/irq/ppc-irq-legacy.c
+libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/ppc-dec-timer.c
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/mpc6xx/clock.rel \
     ../../../libcpu/@RTEMS_CPU@/mpc6xx/mmu.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc6xx/timer.rel \
     ../../../libcpu/@RTEMS_CPU@/mpc6xx/altivec.rel
 if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/powerpc/gen5200/Makefile.am b/c/src/lib/libbsp/powerpc/gen5200/Makefile.am
index efaea4bc91..5f9b3da88f 100644
--- a/c/src/lib/libbsp/powerpc/gen5200/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/gen5200/Makefile.am
@@ -111,9 +111,9 @@ libbsp_a_SOURCES += network_5200/network.c
 endif
-libbsp_a_LIBADD =  ../../../libcpu/@RTEMS_CPU@/mpc6xx/mmu.rel \
+libbsp_a_LIBADD =  ../../../libcpu/@RTEMS_CPU@/mpc6xx/mmu.rel
 include $(top_srcdir)/../../../../automake/local.am
 include $(srcdir)/../../../../../../bsps/powerpc/shared/shared.am
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/Makefile.am b/c/src/lib/libbsp/powerpc/gen83xx/Makefile.am
index 94971badab..a0eb6eb8fc 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/gen83xx/Makefile.am
@@ -74,9 +74,9 @@ libbsp_a_SOURCES += i2c/i2c_init.c
 libbsp_a_SOURCES += spi/spi_init.c
 	../../../libcpu/@RTEMS_CPU@/mpc83xx/i2c.rel  \
 	../../../libcpu/@RTEMS_CPU@/mpc83xx/spi.rel \
 	../../../libcpu/@RTEMS_CPU@/mpc83xx/gtm.rel
diff --git a/c/src/lib/libbsp/powerpc/haleakala/Makefile.am b/c/src/lib/libbsp/powerpc/haleakala/Makefile.am
index 951e4931ad..b461f23058 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/haleakala/Makefile.am
@@ -44,9 +44,9 @@ endif
-libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/ppc403/clock.rel \
-    ../../../libcpu/@RTEMS_CPU@/ppc403/timer.rel
+libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/ppc403/clock.rel
diff --git a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
index f3788b1bd2..18b45f33df 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
@@ -75,8 +75,6 @@ LINKER_SYMBOL(intrStack_size);
 /* Expected by clock.c */
 uint32_t    bsp_clicks_per_usec;
-uint32_t    bsp_timer_least_valid;
-uint32_t    bsp_timer_average_overhead;
 /*-------------------- Haleakala-specific UART setup -------------------------*/
@@ -182,9 +180,6 @@ void bsp_start( void )
   bsp_clicks_per_usec = 400;
   rtems_counter_initialize_converter(bsp_clicks_per_usec * 1000000);
-  bsp_timer_average_overhead = 2;
-  bsp_timer_least_valid = 3;
    * Initialize default raw exception handlers.
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
index 71c7de90b9..75139b05e9 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
@@ -116,12 +116,12 @@ endif
 libbsp_a_LIBADD = \
     polledIO.rel \
 EXTRA_DIST += BOOTING README.mtx603e README.MVME2100 README.MVME2300 \
diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am b/c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am
index b2f612216b..8cb70bb00d 100644
--- a/c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am
@@ -107,14 +107,14 @@ endif
 # BSP library
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/misc.rel \
     ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/irq.rel \
     ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/siu.rel \
     ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/edma.rel \
     ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/emios.rel \
-    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/dspi.rel \
-    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/timer.rel
+    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/dspi.rel
diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am b/c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am
index d039345167..f01305d3c0 100644
--- a/c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am
@@ -55,11 +55,11 @@ libbsp_a_SOURCES += network/network.c
 endif
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/mpc8260/console-generic.rel \
     ../../../libcpu/@RTEMS_CPU@/mpc8260/cpm.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc8260/mmu.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc8260/timer.rel
+    ../../../libcpu/@RTEMS_CPU@/mpc8260/mmu.rel
 EXTRA_DIST += times
diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
index 837543567f..44ec072775 100644
--- a/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
@@ -68,8 +68,6 @@ bool       bsp_serial_external_clock;
 bool       bsp_serial_xon_xoff;
 bool       bsp_serial_cts_rts;
 uint32_t   bsp_serial_rate;
-uint32_t   bsp_timer_average_overhead; /* Average overhead of timer in ticks */
-uint32_t   bsp_timer_least_valid;      /* Least valid number from timer      */
 extern char IntrStack_start [];
 extern char intrStack [];
@@ -172,8 +170,6 @@ void bsp_start(void)
   bsp_serial_xon_xoff 	     = 0;
   bsp_serial_cts_rts 	     = 0;
   bsp_serial_rate 	     = 9600;
-  bsp_timer_average_overhead = 3;
   bsp_clock_speed 	   = 40000000;
   rtems_counter_initialize_converter(bsp_clock_speed);
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
index 6d6ae37f01..d0ddfa62bb 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
@@ -107,9 +107,9 @@ endif
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/e500/clock.rel \
-    ../../../libcpu/@RTEMS_CPU@/e500/timer.rel \
     ../../../libcpu/@RTEMS_CPU@/e500/mmu.rel
 if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
index 6bc467fbf0..c85cd8804f 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
@@ -85,11 +85,11 @@ dist_project_lib_DATA += ../shared/startup/linkcmds.share
 libbsp_a_LIBADD = \
-    ../../../libcpu/@RTEMS_CPU@/mpc6xx/timer.rel\
 if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/powerpc/psim/Makefile.am b/c/src/lib/libbsp/powerpc/psim/Makefile.am
index 1df73b75f0..18bb28d51a 100644
--- a/c/src/lib/libbsp/powerpc/psim/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/psim/Makefile.am
@@ -62,10 +62,10 @@ endif
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am b/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
index ad42c39373..2b268bc0e4 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
@@ -52,9 +52,9 @@ libbsp_a_SOURCES = $(startup_SOURCES) $(clock_SOURCES) $(console_SOURCES) \
     $(irq_SOURCES)
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index 0a85ecd539..50cbdc6bba 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -37,9 +37,9 @@ libbsp_a_SOURCES += startup/tm27supp.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/exceptions/ppc_exc_print.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/clock.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/console-generic.c
-libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/dev/timer.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq_asm.S
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq.c
 libbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/irq_init.c
diff --git a/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c b/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
index 56be333921..f47ca7d5be 100644
--- a/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
@@ -39,8 +39,6 @@ extern unsigned long intrStackPtr;
 uint32_t   bsp_clock_speed;	       /* Serial clocks per second */
  *  bsp_start()
@@ -90,8 +88,6 @@ void bsp_start(void)
   bsp_clicks_per_usec = BSP_CRYSTAL_HZ / 4 / 1000000;
   bsp_clock_speed     = BSP_CLOCK_HZ;	/* for SCI baud rate generator */
-  bsp_timer_least_valid      = 0;
-  bsp_timer_average_overhead = 0;
   rtems_counter_initialize_converter(BSP_CRYSTAL_HZ / 4);
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am b/c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am
index 8188ad5c03..f04ed45748 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am
@@ -63,13 +63,13 @@ libbsp_a_SOURCES += network/network_scc.c
 endif
 libbsp_a_LIBADD = \
     ../../../libcpu/@RTEMS_CPU@/mpc8xx/console-generic.rel \
     ../../../libcpu/@RTEMS_CPU@/mpc8xx/cpm.rel \
     ../../../libcpu/@RTEMS_CPU@/mpc8xx/clock.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc8xx/mmu.rel \
-    ../../../libcpu/@RTEMS_CPU@/mpc8xx/timer.rel
+    ../../../libcpu/@RTEMS_CPU@/mpc8xx/mmu.rel
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c b/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
index 90753f4982..a4865cc104 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
@@ -46,10 +46,6 @@ uint32_t bsp_time_base_frequency;
 /* Legacy */
 uint32_t bsp_clicks_per_usec; /* for PIT driver: OSCCLK */
-/* for timer: */
 static const char *bsp_tqm_get_cib_string( const char *cib_id)
   char srch_pattern[10] = "";
@@ -145,8 +141,6 @@ void bsp_start( void)
   bsp_time_base_frequency = BSP_bus_frequency / 16;
   bsp_clicks_per_usec = bsp_time_base_frequency / 1000000;
   rtems_counter_initialize_converter(bsp_time_base_frequency);
   /* Initialize exception handler */
diff --git a/c/src/lib/libbsp/powerpc/virtex/Makefile.am b/c/src/lib/libbsp/powerpc/virtex/Makefile.am
index 355b0ca83f..cb23c69d78 100644
--- a/c/src/lib/libbsp/powerpc/virtex/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/virtex/Makefile.am
@@ -62,11 +62,8 @@ if HAS_NETWORKING
 libbsp_a_SOURCES += = network/xiltemac.c
 endif
-# timer
-libbsp_a_SOURCES += timer/timer-config.c
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/ppc403/timer.rel
diff --git a/c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c b/c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c
index bdea6bb775..0000000000
--- a/c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c
+++ /dev/null
@@ -1,58 +0,0 @@
- *  Author:	Thomas Doerfler <td at imd.m.isar.de>
- *              IMD Ingenieurbuero fuer Microcomputertechnik
- *  COPYRIGHT (c) 1998 by IMD
- *  Changes from IMD are covered by the original distributions terms.
- *  This file has been derived from the papyrus BSP:
- *  Modifications for spooling console driver and control of memory layout
- *  with linker command file by
- *              Thomas Doerfler <td at imd.m.isar.de>
- *  for these modifications:
- *  COPYRIGHT (c) 1997 by IMD, Puchheim, Germany.
- *      copies. IMD makes no representations about the suitability
- *  Derived from c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c:
- *  COPYRIGHT (c) 1989, 1990, 1991, 1992, 1993, 1994.
- *  Modifications for PPC405GP by Dennis Ehlin
-#include <stdint.h>
-#include <stdbool.h>
- *  Driver configuration parameters
-/* Average overhead of timer in ticks */
-uint32_t bsp_timer_average_overhead = 2;
-/* Least valid number from timer */
-uint32_t bsp_timer_least_valid = 3;
diff --git a/c/src/lib/libbsp/powerpc/virtex4/Makefile.am b/c/src/lib/libbsp/powerpc/virtex4/Makefile.am
index 256ace53e8..fe1adc7847 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/virtex4/Makefile.am
@@ -46,9 +46,9 @@ libbsp_a_SOURCES += irq/irq_init.c
 libbsp_a_SOURCES += mmu/mmu.c
 EXTRA_DIST += times
diff --git a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
index fa7c1137e9..f67c1c3603 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
@@ -96,8 +96,6 @@ LINKER_SYMBOL(bsp_exc_vector_base);
@@ -167,8 +165,6 @@ void bsp_start(void)
   /* Timebase register ticks/microsecond;  The application may override these */
   bsp_clicks_per_usec        = 350;
diff --git a/c/src/lib/libbsp/powerpc/virtex5/Makefile.am b/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
index f25045845f..89c7b9b5d6 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
@@ -48,9 +48,9 @@ libbsp_a_SOURCES += irq/irq_init.c
-libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/e500/clock.rel \
+libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/e500/clock.rel
 EXTRA_DIST += times
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
index c865abe3a1..44e7512e55 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
@@ -97,8 +97,6 @@ LINKER_SYMBOL(bsp_exc_vector_base);
  * Bus Frequency
@@ -189,8 +187,6 @@ void bsp_start(void)
     BSP_bus_frequency / (BSP_time_base_divisor / 1000)
    * Initialize the interrupt related settings.
diff --git a/c/src/lib/libcpu/powerpc/Makefile.am b/c/src/lib/libcpu/powerpc/Makefile.am
index 6d5bc19e5b..e83d47a772 100644
--- a/c/src/lib/libcpu/powerpc/Makefile.am
+++ b/c/src/lib/libcpu/powerpc/Makefile.am
@@ -24,12 +24,6 @@ endif
 ppc403_console_rel_CPPFLAGS = $(AM_CPPFLAGS)
 ppc403_console_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# ppc403/timer
-noinst_PROGRAMS += ppc403/timer.rel
-ppc403_timer_rel_SOURCES = ppc403/timer/timer.c
-ppc403_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-ppc403_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 # ppc403/tty_drv
 if ppc405
 noinst_PROGRAMS += ppc403/tty_drv.rel
@@ -61,12 +55,6 @@ mpc6xx_clock_rel_SOURCES = mpc6xx/clock/c_clock.c mpc6xx/clock/c_clock.h
 mpc6xx_clock_rel_CPPFLAGS = $(AM_CPPFLAGS)
 mpc6xx_clock_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc6xx/timer
-noinst_PROGRAMS += mpc6xx/timer.rel
-mpc6xx_timer_rel_SOURCES = mpc6xx/timer/timer.c
-mpc6xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc6xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 # mpc6xx/altivec
 noinst_PROGRAMS += mpc6xx/altivec.rel
 mpc6xx_altivec_rel_SOURCES = mpc6xx/altivec/vec_sup.c mpc6xx/altivec/vec_sup_asm.S
@@ -83,14 +71,6 @@ e500_clock_rel_CPPFLAGS = $(AM_CPPFLAGS)
 e500_clock_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
-# e500/timer
-if e500_timer
-noinst_PROGRAMS += e500/timer.rel
-e500_timer_rel_SOURCES = mpc6xx/timer/timer.c
-e500_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-e500_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
 # e500/mmu
 if e500_mmu
 noinst_PROGRAMS += e500/mmu.rel
@@ -124,12 +104,6 @@ noinst_PROGRAMS += mpc8xx/mmu.rel
 mpc8xx_mmu_rel_SOURCES = mpc8xx/mmu/mmu.c
 mpc8xx_mmu_rel_CPPFLAGS = $(AM_CPPFLAGS)
 mpc8xx_mmu_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc8xx/timer
-noinst_PROGRAMS += mpc8xx/timer.rel
-mpc8xx_timer_rel_SOURCES = mpc8xx/timer/timer.c
-mpc8xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc8xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
 EXTRA_DIST += mpc8260/README
@@ -154,12 +128,6 @@ mpc8260_mmu_rel_SOURCES = mpc8260/mmu/mmu.c \
                           mpc8260/include/mmu.h
 mpc8260_mmu_rel_CPPFLAGS = $(AM_CPPFLAGS)
 mpc8260_mmu_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc8260/timer
-noinst_PROGRAMS += mpc8260/timer.rel
-mpc8260_timer_rel_SOURCES = mpc8260/timer/timer.c
-mpc8260_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc8260_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
@@ -209,12 +177,6 @@ noinst_PROGRAMS += mpc55xx/irq.rel
 mpc55xx_irq_rel_SOURCES = mpc55xx/irq/irq.c
 mpc55xx_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-# mpc6xx/timer
-noinst_PROGRAMS += mpc55xx/timer.rel
-mpc55xx_timer_rel_SOURCES = mpc6xx/timer/timer.c
-mpc55xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mpc55xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 # FEC
 noinst_PROGRAMS += mpc55xx/fec.rel
 mpc55xx_fec_rel_SOURCES = mpc55xx/fec/fec.c
diff --git a/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
index c20fdc5cca..0000000000
--- a/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
+++ /dev/null
@@ -1,103 +0,0 @@
- *  @file
- *  @brief Timer for the PowerPC MPC860
- *  @note This is not the PIT, but rather the RTEMS interval timer.
- *  Author: Andy Dachs <a.dachs at sstl.co.uk>
- *  Surrey Satellite Technlogy Limited
- *   Modified for MPC8260
- *   Derived from c/src/lib/libcpu/powerpc/mpc860/timer/timer.c:
-#include <rtems.h>
-#include <mpc8260.h>
-   uint32_t   ret;
-   return ret;
-  m860.tbscr |= M860_TBSCR_TBIRQ(4) | M860_TBSCR_TBE;
-  uint32_t   clicks;
-  uint32_t   total;
-  else {
diff --git a/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
index b82d76497d..0000000000
--- a/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
+++ /dev/null
@@ -1,94 +0,0 @@
- *  @file
- *  @brief Timer Driver for the PowerPC MPC8xx.
- *  This file manages the interval timer on the PowerPC MPC8xx.
-#include <rtems.h>
-#include <mpc8xx.h>
-   uint32_t   ret;
-   return ret;
-  m8xx.tbscr |= M8xx_TBSCR_TBIRQ(4) | M8xx_TBSCR_TBE;
-  uint32_t   clicks;
-  uint32_t   total;
-  else {
diff --git a/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c b/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
index f883facb80..0000000000
--- a/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
+++ /dev/null
@@ -1,73 +0,0 @@
- *  @file
- *  @brief Timer Driver for the PowerPC 405.
- *  This file manages the interval timer on the PowerPC 405.
- *  Derived from c/src/lib/libcpu/hppa1.1/timer/timer.c:
- *  Further mods for PPC405EX/EXr by Michael Hamel
-#include <rtems.h>
-#include <libcpu/powerpc-utility.h>
-static volatile uint32_t	startedAt;
-static bool                     subtractOverhead;
-  /* We are going to rely on clock.c to sort out where the clock comes from */
-  startedAt = ppc_time_base();
-	uint32_t   clicks, total;
-	clicks = ppc_time_base();
-	total = clicks - startedAt;
-	if ( ! subtractOverhead )
-	else if ( total < bsp_timer_least_valid )
-	else
-	subtractOverhead = find_flag;
2.12.3
