Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Mar 21 09:42:03 UTC 2018
Sir ,
I have done the changes in the proposal , based on the comments in the
google doc , please review it and suggest any further changes if required
Thank you ,
-- vijay
P.S : the previous version is in parentheses , I will remove them after you
review the changes .
On 18 March 2018 at 16:05, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Thanks Cillian :)
> It's great to see it running , I'll do some background reading about RSB,
> and RTEMS-Tools along with the covoar code . And also work on my python
> skills.
> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and that
> also worked.
> I'm also waiting for Joel and other mentors' review on my draft proposal,
> so that I can also work on it and make any changes if needed.
> Thanks .
> -- vijay
> On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> It worked !
>> That's great! That's the good news then. I was using an old leon3 build
>> and maybe some older Qemu too and I think that's why I didn't see any
>> issues initially. I was hoping you could see the coverage running and the
>> reports generated from that but it looks like the full update to the
>> current master will be necessary to have a look. So until the parsing for
>> the INI files is added to the coverage.py we won't see the coverage
>> running. Unfortunately, I'm in the middle of exams until the following
>> Monday so I won't be able to sink any more time into it until then. You can
>> still figure out the RSB problem you're having and do some background
>> reading, brush up on your Python skills, have a read of the covoar code
>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covoar/covoar.cc
>> just skim through, read the comments, get a sense of the what it's doing
>> and in what order.
>>> It's great to see it running ! I have attached the result .
>>> -- vijay
>>> On 18 March 2018 at 02:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> yes it prints hello world
>>>> Alright I've added an .ini for leon3-qemu to the current rtems-tools.
>>>> Pull this branch
>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>> and try
>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>>>> --rtems-bsp=leon3_qemu $HOME/development/rtems/leon3/
>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>> -- vijay
>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> If you run just one test by itself without rtems-test
>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio -nographic
>>>>>> -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>> Does the hello world print out?
>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>> I built it manually
>>>>>>> the environment variable PATH looks like this
>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>> I tried to run rtems-test again without --coverage , it gives the
>>>>>>> same result
>>>>>>> I have attached the log.
>>>>>>> -- vijay
>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Yes this is something more than my build, I'll need someone a bit
>>>>>>>> more expert in the RSB to step in there. In the meantime, lets just build
>>>>>>>> couverture-qemu manually so we can see is everything else working.
>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>> cd qemu
>>>>>>>> ./configure --target-list=sparc-softmmu --prefix=$HOME/qemu/install
>>>>>>>> --disable-docs --disable-virtfs --disable-werror
>>>>>>>> make
>>>>>>>> make install
>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>> Then run rtem-test and see what happens
>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>> is the issue coming from my system ? I'm using fedora 27 64bit
>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>> yes , the same thing happens
>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> If you build regular qemu with the RSB, does the same thing
>>>>>>>>>>> happen?
>>>>>>>>>>> Try
>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>> still the same error
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>> Just checked and the build was failing because one of the
>>>>>>>>>>>>> patches needed its hash to be updated to sha256. Just pushed that change.
>>>>>>>>>>>>> The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>>>>>>>>>>>>> ee/couverture-build )
>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the log
>>>>>>>>>>>>>>>> file
>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special
>>>>>>>>>>>>>>> version of qemu designed for generating extra trace data for coverage
>>>>>>>>>>>>>>> analysis). That's what those errors are about. I have an RSB build for that.
>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>>>>>>>>>>>>>> /couverture-build
>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>> I know what the other problem is too. I have a specific
>>>>>>>>>>>>>>> environment variable defined for the path, sorry I can't even remember
>>>>>>>>>>>>>>> putting it there, I thought that was automatically generated (probably
>>>>>>>>>>>>>>> should be, another thing to add to the list :)... ). So wherever you stuck
>>>>>>>>>>>>>>> the export path for where the rsb built the tools, in .bashrc or whatever
>>>>>>>>>>>>>>> you're using. Also put something like:
>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory with
>>>>>>>>>>>>>>> all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage is
>>>>>>>>>>>>>>>>> everything ok?
>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that directory
>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to further
>>>>>>>>>>>>>>>>>>>> discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in there it
>>>>>>>>>>>>>>>>>>> should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180321/1c219ede/attachment-0001.html>
