[PATCH] vprintf: Add handler that mutes all output.
Thu Mar 22 23:51:04 UTC 2018
On 22/03/2018 18:22, Christian Mauderer wrote:
> Am 22.03.2018 um 08:17 schrieb Chris Johns:
>> On 22/03/2018 17:40, Christian Mauderer wrote:
>>> This adds a vprintf handler that can be used to suppress all outputs of
>>> the libbsd.
>> Why would I want this?
>> How would I enable the output so I could see it, for example when working with
>> the code?
>> Chris
> Hello Chris,
> in this case, a customer asked for no additional output on the console.
> It would be easy to add the same to the application but it might can be
> useful for other users too therefore I added it to libbsd.
> Note that this is fully optional. It doesn't change the default
> behavior. You explicitly have to set the handler using a
>     old = rtems_bsd_set_vprintf_handler(rtems_bsd_vprintf_handler_mute);
> If you want to re-enable the output sometime later you could just set
> the vprintf handler to the old one again (return value of the set function).
Nice, I can see the need.
We really need a manual for libbsd or a section in the User Manual. Is it worth
adding something to libbsd.txt until we have somewhere so we do not forget to
document this?
Ok to push.
Thanks
