Empting libcpu ...
Chris Johns
chrisj at rtems.org
Fri Mar 23 02:47:53 UTC 2018
Hi,
I have:
make[6]: Entering directory
'/opt/work/chris/rtems/kernel/bsps/xilinx_zynq_zedboard/arm-rtems5/c/xilinx_zynq_zedboard/lib/libcpu/arm'
gmake[6]: *** No rule to make target 'all-am'. Stop.
gmake[6]: Leaving directory
gmake[5]: *** [Makefile:654: arm] Error 2
Git will not remove a directory if there are untracked files present such as
configure and Makefile.in which means:
RTEMS_CPU_SUBDIRS(lib/libcpu)
if test -d "${srcdir}/lib/libcpu/${RTEMS_CPU}"; then
libcpu_cpu_subdir="${RTEMS_CPU}"
else
libcpu_cpu_subdir=
fi
AC_SUBST(libcpu_cpu_subdir)
thinks there is a libcpu even after cleaning up the generated files. Maybe the
test should be:
if test -d "${srcdir}/lib/libcpu/${RTEMS_CPU}/configure.ac"; then
else
libcpu_cpu_subdir=
fi
Patch posted.
