How to build librtemscpu.a and librtemsbsp.a in the future?
Fri Mar 23 14:27:22 UTC 2018
Hello,
I tried to consolidate the cpukit Makefile.am. This ended up in the
following problem. The content of librtemscpu.a depends on the CPU port.
This is currently done via a non-standard
_SUBDIRS = ../@RTEMS_CPU@
construct. The wrapup/Makefile.am combines several static libraries into
one librtemscpu.a. With librtemsbsp.am we have a similar problem. This
archive unpack and re-create step seems to be a bit expensive. Why can't
we use an MRI script, e.g.
create ./sparc-rtems5/erc32/lib/librtemscpu.a
addlib ./sparc-rtems5/c/erc32/cpukit/librtemscpu.a
addlib ./sparc-rtems5/c/erc32/cpukit/score/cpu/sparc/libscorecpu.a
save
end
Would conditional Makefile.am parts be more efficient, e.g. in
cpukit/Makefile.am
if CPU_ARM
include score/cpu/arm/make.am
endif
if CPU_XXX
How would waf deal with this problem?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
