MMU was Re: Contribute to a project under GSOC 2018
Abhinav Jain
jainab.2009 at gmail.com
Fri Mar 23 19:06:54 UTC 2018
Sir,
I have researched about the current MMU support available in RTEMS and I
have mentioned about it in the proposal. Also as per your guidance, I have
omitted the idea of developing memory protection for architectures not
having MMU, rather I will give my full focus to developing MMU support for
RISC -V architecture.
I request you to please review the proposal and guide me if some changes
are to be made to this, or if I should work on some other architecture. I
am researching more about the difference in MMU in RISC -V and PowerPC and
ARM, for which the MMU support is already available in RTEMS.
https://docs.google.com/document/d/1boKGnnzQGCzxIVqBVMWvK7OFJTvWKzWDXj1EvuEuq5o/edit?usp=sharing
Thanks and Regards
Abhinav Jain
On Sat, Mar 17, 2018 at 1:29 PM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
> Sir,
> Thanks for the guidance and feedback. I have shared the draft proposal
> through GSoC application. I will make the changes as per your suggestions
> and will add the details mentioned by you.
> Thanks and Regards
> Abhinav Jain
> On Sat, Mar 17, 2018 at 12:47 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> high-level comments:
>> * add citations to relevant literature that you used for inspiration.
>> * start to write a design plan for the bsp-level framework you envision.
>> * it would be a good idea to review the existing mmu support in RTEMS.
>> * link to this google doc as your "Draft" from your GSoC application,
>> and also upload an initial "Final" pdf, which you can continue to
>> revise.
>> Gedare
>> On Fri, Mar 16, 2018 at 2:48 PM, Abhinav Jain <jainab.2009 at gmail.com>
>> wrote:
>> > Sir,
>> > I have prepared a draft proposal for GSoC 2018 as suggested by you.
>> > I request you to please guide me whether I have made it correctly or
>> not,
>> > whether I have written some big plans or more things can be included.
>> > The link for the Proposal is:
>> > Thanks and Regards
>> > Abhinav Jain
>> > On Wed, Mar 14, 2018 at 10:47 PM, Abhinav Jain <jainab.2009 at gmail.com>
>> > wrote:
>> >> Sir,
>> >> Thanks for the guidance. I am studying ARM architecture and trying to
>> find
>> >> out the difference in it's architecture from other ones, I am trying to
>> >> understand what can be the minimum changes to the existing framework
>> to get
>> >> it working on other architectures.
>> >> Thanks and Regards
>> >> Abhinav Jain
>> >> On Wed, Mar 14, 2018, 10:41 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >>> The framework exists in the rtems source code, underneath
>> >>> c/src/lib/libbsp/arm.
>> >>> Start with the GSoC template, adjust the dates, start adding details.
>> >>> When you have a draft you can invite comments for review.
>> >>> On Wed, Mar 14, 2018 at 12:18 PM, Abhinav Jain <jainab.2009 at gmail.com
>> >>> wrote:
>> >>> > Sir,
>> >>> > The description of the RoadRunner OS is mentioned in the document
>> >>> > provided
>> >>> > by you,
>> >>> > https://pdfs.semanticscholar.org/3c92/7ed6b426fccfb203dd96be
>> 9b7591b3744f1f.pdf
>> >>> > The link (http://ieeexplore.ieee.org/document/7509439/?part=1)
>> which I
>> >>> > mentioned in the previous mail deals with memory management scheme
>> for
>> >>> > the
>> >>> > MMU-less embedded systems.
>> >>> > If there is already a framework for ARM MMU, I will try to extend
>> it to
>> >>> > other architectures as much as possible, I read about various
>> >>> > architectures
>> >>> > in past couple of days.
>> >>> > I request you to please provide the link to the available framework
>> so
>> >>> > that
>> >>> > I can study that and proceed with its enhancement if possible.
>> Also, I
>> >>> > request you to please guide me for my GSoC proposal.
>> >>> > Thanks and Regards
>> >>> > Abhinav Jain
>> >>> > On Wed, Mar 14, 2018 at 9:37 PM, Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >>> >> Abhinav,
>> >>> >> Send me the linked article. Does it describe the RoadRunner OS
>> >>> >> approach? I am not familiar with it.
>> >>> >> Note that there is a basic framework for ARM MMU in place already.
>> >>> >> Adoption/adaptation of it to other architectures is preferred
>> versus
>> >>> >> replacing it, unless absolutely necessary.
>> >>> >> On Wed, Mar 14, 2018 at 12:03 PM, Abhinav Jain <
>> >>> >> wrote:
>> >>> >> > Sir,
>> >>> >> > I studied the documents provided by you in the previous mail,
>> also I
>> >>> >> > read a
>> >>> >> > document from http://ieeexplore.ieee.org/doc
>> ument/7509439/?part=1.
>> >>> >> > As told by you in the previous mail that the first issue to be
>> >>> >> > solved is
>> >>> >> > to
>> >>> >> > provide a BSP-level framework for MMU/MPU hardware, after reading
>> >>> >> > the
>> >>> >> > memory
>> >>> >> > protection in roadrunner operating system, I think that with some
>> >>> >> > changes,
>> >>> >> > the same concept can be implemented in the RTEMS for memory
>> >>> >> > protection.
>> >>> >> > I request you to please guide me whether I am right in the
>> approach
>> >>> >> > or I
>> >>> >> > have to think differently.
>> >>> >> > Thanks and Regards
>> >>> >> > Abhinav Jain
>> >>> >> > On Wed, Mar 7, 2018 at 10:49 AM, Abhinav Jain
>> >>> >> > wrote:
>> >>> >> >> Sir,
>> >>> >> >> Thanks a lot for the guidance. I will study the documents
>> provided
>> >>> >> >> by
>> >>> >> >> you
>> >>> >> >> and will try to find more about this to increase my knowledge
>> about
>> >>> >> >> Memory
>> >>> >> >> support.
>> >>> >> >> I will start preparing a draft proposal as per the template
>> >>> >> >> provided on
>> >>> >> >> the RTEMS GSoC page.
>> >>> >> >> Thanks and Regards
>> >>> >> >> Abhinav Jain
>> >>> >> >> On Mar 6, 2018 10:25 PM, "Gedare Bloom" <gedare at rtems.org>
>> wrote:
>> >>> >> >> On Sun, Mar 4, 2018 at 1:50 AM, Abhinav Jain
>> >>> >> >> wrote:
>> >>> >> >> > Sir,
>> >>> >> >> > Thanks for your time and consideration. I was discussing this
>> >>> >> >> > project
>> >>> >> >> > with
>> >>> >> >> > Gedare Sir and he guided me, how to proceed.
>> >>> >> >> > I am studying various things before proceeding with the code
>> part
>> >>> >> >> > but
>> >>> >> >> > for
>> >>> >> >> > now, I request you to please guide me what should be my next
>> >>> >> >> > steps to
>> >>> >> >> > work
>> >>> >> >> > on this project under GSOC'18.
>> >>> >> >> > Thanks and Regards
>> >>> >> >> > Abhinav Jain
>> >>> >> >> > On Sun, Mar 4, 2018 at 10:48 AM, Hesham Almatary
>> >>> >> >> > <heshamelmatary at gmail.com>
>> >>> >> >> > wrote:
>> >>> >> >> >> On Sun, Mar 4, 2018 at 10:20 AM, Joel Sherrill <
>> joel at rtems.org>
>> >>> >> >> >> wrote:
>> >>> >> >> >> > On Mar 3, 2018 12:16 PM, "Abhinav Jain"
>> >>> >> >> >> > wrote:
>> >>> >> >> >> > Sir/Madam,
>> >>> >> >> >> > I am Abhinav Jain, a second-year engineering student from
>> >>> >> >> >> > Delhi,
>> >>> >> >> >> > India.
>> >>> >> >> >> > I
>> >>> >> >> >> > have been working in Linux Kernel Development, I have been
>> >>> >> >> >> > writing
>> >>> >> >> >> > small
>> >>> >> >> >> > drivers and have a good knowledge of the operating system.
>> >>> >> >> >> > I have been studying about Memory Protection project(ticket
>> >>> >> >> >> > #2904)
>> >>> >> >> >> > for
>> >>> >> >> >> > around a month and found it really interesting. I studied
>> >>> >> >> >> > about
>> >>> >> >> >> > POSIX,
>> >>> >> >> >> > MMU
>> >>> >> >> >> > support in various other architecture and the memory
>> >>> >> >> >> > protection
>> >>> >> >> >> > APIs
>> >>> >> >> >> > in
>> >>> >> >> >> > various operating systems.I have been discussing the same
>> on
>> >>> >> >> >> > the
>> >>> >> >> >> > mailing
>> >>> >> >> >> > list.
>> >>> >> >> >> > I also solved an issue (#2522) around a week ago to gain
>> some
>> >>> >> >> >> > hands-on
>> >>> >> >> >> > code.
>> >>> >> >> -ENOPATCH
>> >>> >> >> >> > Welcome aboard.
>> >>> >> >> >> > I would like to work on the Memory Protection project under
>> >>> >> >> >> > GSOC
>> >>> >> >> >> > 2018,
>> >>> >> >> >> > so I
>> >>> >> >> >> > request you to please guide me regarding the steps to be
>> >>> >> >> >> > followed.
>> >>> >> >> >> > Gedare conceived of what's there be so I cc'ed him. My
>> >>> >> >> >> > recollection
>> >>> >> >> >> > is
>> >>> >> >> >> > that
>> >>> >> >> >> > there were specific things he wanted to change and when
>> that
>> >>> >> >> >> > was
>> >>> >> >> >> > addressed,
>> >>> >> >> >> > providing support for arenas on multiple architecture is
>> >>> >> >> >> > desirable
>> >>> >> >> >> +1
>> >>> >> >> >> There might be an opportunity to port RTEMS to RISC-V's
>> >>> >> >> >> Supervisor
>> >>> >> >> >> Mode which will need MMU support (currently it only runs on
>> >>> >> >> >> M-Mode
>> >>> >> >> >> which doesn't have MMU). Both QEMU and Spike simulators
>> support
>> >>> >> >> >> S-Mode.
>> >>> >> >> Start to develop a draft proposal if you have not yet, starting
>> >>> >> >> with
>> >>> >> >> our template. A successful proposal must contain a sound design
>> and
>> >>> >> >> good plan, which you will need a lot of time and feedback to
>> >>> >> >> develop.
>> >>> >> >> Don't read too much about 64-bit processor architectures and
>> their
>> >>> >> >> needs, since we have limited support there. The first issue to
>> >>> >> >> resolve
>> >>> >> >> is what kind of BSP-level interface should we provide over
>> MMU/MPU
>> >>> >> >> hardware, and then what can we do to use that BSP layer to
>> provide
>> >>> >> >> upper-layer services such as managed memory regions, better
>> mmap()
>> >>> >> >> support, "arena" allocators, etc. There are three views here:
>> >>> >> >> 1. no mmu/mpu is available or it is not desired by end users.
>> >>> >> >> 2. mmu/mpu are available, but should only be manipulated
>> >>> >> >> statically/boot-time.
>> >>> >> >> 3. mmu/mpu are available, and can be changed dynamically.
>> >>> >> >> Managing #3 is the hardest, but accommodating 1 and 2 in any
>> system
>> >>> >> >> design is important. Another important concern is mmu/mpu with
>> >>> >> >> limited
>> >>> >> >> numbers of entries. Right now, we exist mainly in #1, and #2 is
>> >>> >> >> only
>> >>> >> >> used to setup a linear 1:1 memory map with all permissions
>> enabled
>> >>> >> >> when the MMU/MPU can't be turned off. A few projects exist here
>> and
>> >>> >> >> there to also restrict permissions to thread stacks with a hook
>> in
>> >>> >> >> the
>> >>> >> >> context switch to change the mpu/mmu state.
>> >>> >> >> Since RTEMS has no multi-process model, the existing solutions
>> in
>> >>> >> >> general-purpose commodity OS do not apply, but you should still
>> be
>> >>> >> >> familiar with how they work for sure. It would also be good for
>> you
>> >>> >> >> to
>> >>> >> >> review the solutions in the commodity RTOS domain, e.g. what
>> does
>> >>> >> >> vxworks, safertos, threadx, etc., provides in this field.
>> >>> >> >> Some relevant citations to get more relevant background:
>> >>> >> >> https://highintegritysystems.com/downloads/white_papers/Usin
>> g_an_MPU_to_Enforce_Spatial_Separation.pdf
>> 9b7591b3744f1f.pdf
>> >>> >> >> https://www.researchgate.net/publication/221033285_A_New_App
>> roach_to_Memory_Partitioning_in_On-Board_Spacecraft_Software
>> >>> >> >> >> > Thanks and Regards
>> >>> >> >> >> > Abhinav Jain
>> >>> >> >> >> > _______________________________________________
>> >>> >> >> >> > devel mailing list
>> >>> >> >> >> > devel at rtems.org
>> >>> >> >> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >>> >> >> >> > devel mailing list
>> >>> >> >> >> > devel at rtems.org
>> >>> >> >> >> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180324/35fd81b8/attachment-0001.html>
