[PATCH v2 1/2] waf: Support building from libbsd.py directly from waf.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Mar 27 07:56:45 UTC 2018
Am 27.03.2018 um 09:00 schrieb Christian Mauderer:
> Am 26.03.2018 um 14:59 schrieb Christian Mauderer:
>> Hello Chris,
>> I took the liberty to rebase the patches to the latest master. See the
>> two following v3 mails. I'll take a look at the configuration based on
>> these patches.
>> I think that you wanted to make i386 tests. After that it might would be
>> a good idea to commit them. What do you think?
>> Best regards
>> Christian
> Hello Chris,
> just noted: The freebsd-to-rtems.py (with -R) doesn't work anymore. I'll
> fix that.
> Maybe it would be a good idea to develop that (and the config options)
> on a branch (on a user specific repo on git.rtems.org) and post it for
> review? At least it's a bigger change.
> Best regards
> Christian
Most likely there will be some more changes till the configuration is
implemented. So I created a branch called ticket-3351 for review here:
https://git.rtems.org/christianm/rtems-libbsd.git/log/?h=ticket-3351
I added a fix for the freebsd-to-rtems.py to that branch.
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
