[PATCH 1/2] jffs2: Do not use command line defines
Tue Mar 27 23:01:36 UTC 2018
On 27/03/2018 22:01, Sebastian Huber wrote:
> Update #3375.
>  cpukit/libfs/Makefile.am                  | 2 --
>  cpukit/libfs/src/jffs2/src/build.c        | 2 ++
>  cpukit/libfs/src/jffs2/src/compat-crc32.c | 2 ++
>  cpukit/libfs/src/jffs2/src/compr.c        | 2 ++
>  cpukit/libfs/src/jffs2/src/compr_rtime.c  | 2 ++
>  cpukit/libfs/src/jffs2/src/compr_rubin.c  | 2 ++
>  cpukit/libfs/src/jffs2/src/compr_zlib.c   | 2 ++
>  cpukit/libfs/src/jffs2/src/debug.c        | 2 ++
>  cpukit/libfs/src/jffs2/src/dir-rtems.c    | 2 ++
>  cpukit/libfs/src/jffs2/src/erase.c        | 2 ++
>  cpukit/libfs/src/jffs2/src/flashio.c      | 2 ++
>  cpukit/libfs/src/jffs2/src/fs-rtems.c     | 2 ++
>  cpukit/libfs/src/jffs2/src/gc.c           | 2 ++
>  cpukit/libfs/src/jffs2/src/jffs2-config.h | 2 ++
>  cpukit/libfs/src/jffs2/src/malloc-rtems.c | 2 ++
>  cpukit/libfs/src/jffs2/src/nodelist.c     | 2 ++
>  cpukit/libfs/src/jffs2/src/nodemgmt.c     | 2 ++
>  cpukit/libfs/src/jffs2/src/read.c         | 2 ++
>  cpukit/libfs/src/jffs2/src/readinode.c    | 2 ++
>  cpukit/libfs/src/jffs2/src/scan.c         | 2 ++
>  cpukit/libfs/src/jffs2/src/write.c        | 2 ++
Does this change diverge the code from the up stream?
I am not sure I agree with this happening and the purpose of ticket #3375. I am
still considering this.
