[PATCH] Eliminate PowerPC libcpu/page.h
Joel Sherrill
joel at rtems.org
Wed Mar 28 16:31:32 UTC 2018
Started to eliminate warnings and then realized that only one one-line
macro in the file was used by a few files. The rest of the file was
was not needed. Eliminate the file.
Closes #3354.
bsps/powerpc/beatnik/include/bsp.h | 8 +--
bsps/powerpc/headers.am | 1 -
bsps/powerpc/include/libcpu/page.h | 66 ----------------------
c/src/lib/libbsp/powerpc/shared/bootloader/misc.c | 4 +-
c/src/lib/libbsp/powerpc/shared/bootloader/mm.c | 4 +-
c/src/lib/libbsp/powerpc/shared/bootloader/pci.c | 1 -
.../lib/libbsp/powerpc/shared/console/polled_io.c | 1 -
.../libbsp/powerpc/shared/startup/pgtbl_setup.c | 4 +-
8 files changed, 13 insertions(+), 76 deletions(-)
delete mode 100644 bsps/powerpc/include/libcpu/page.h
diff --git a/bsps/powerpc/beatnik/include/bsp.h b/bsps/powerpc/beatnik/include/bsp.h
index 8301b97..4a475eb 100644
--- a/bsps/powerpc/beatnik/include/bsp.h
+++ b/bsps/powerpc/beatnik/include/bsp.h
@@ -133,11 +133,11 @@ extern void BSP_motload_pci_fixup(void);
#define BSP_I2C_THM_NAME BSP_I2C_DS1621_NAME
#define BSP_I2C_DS1621_RAW_NAME "ds1621-raw"
-#define BSP_I2C_VPD_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", "BSP_I2C_VPD_EEPROM_NAME)
-#define BSP_I2C_USR_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", "BSP_I2C_USR_EEPROM_NAME)
-#define BSP_I2C_DS1621_DEV_NAME (BSP_I2C_BUS0_NAME ", "BSP_I2C_DS1621_NAME)
+#define BSP_I2C_VPD_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_VPD_EEPROM_NAME)
+#define BSP_I2C_USR_EEPROM_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_USR_EEPROM_NAME)
+#define BSP_I2C_DS1621_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_NAME)
#define BSP_I2C_THM_DEV_NAME BSP_I2C_DS1621_DEV_NAME
-#define BSP_I2C_DS1621_RAW_DEV_NAME (BSP_I2C_BUS0_NAME ", "BSP_I2C_DS1621_RAW_NAME)
+#define BSP_I2C_DS1621_RAW_DEV_NAME (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_RAW_NAME)
/* Initialize the I2C driver and register all devices
diff --git a/bsps/powerpc/headers.am b/bsps/powerpc/headers.am
index cb54160..1712240 100644
--- a/bsps/powerpc/headers.am
+++ b/bsps/powerpc/headers.am
@@ -37,7 +37,6 @@ include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/e500_mmu.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/io.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/irq.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/mmu.h
-include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/page.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/pgtable.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/powerpc-utility.h
include_libcpu_HEADERS += ../../../../../bsps/powerpc/include/libcpu/pte121.h
diff --git a/bsps/powerpc/include/libcpu/page.h b/bsps/powerpc/include/libcpu/page.h
deleted file mode 100644
index 3efbdef..0000000
--- a/bsps/powerpc/include/libcpu/page.h
+++ /dev/null
@@ -1,66 +0,0 @@
- * page.h
- * PowerPC memory management structures
- * It is a stripped down version of linux ppc file...
- * Copyright (C) 1999 Eric Valette (valette at crf.canon.fr)
- * Canon Centre Recherche France.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _LIBCPU_PAGE_H
-#define _LIBCPU_PAGE_H
-/* PAGE_SHIFT determines the page size */
-#define PAGE_SHIFT 12
-#define PAGE_SIZE (1UL << PAGE_SHIFT)
-#define PAGE_MASK (~(PAGE_SIZE-1))
-#define PAGE_OFFSET 0xc0000000
-#ifndef ASM
- * .. while these make it easier on the compiler
-typedef unsigned long pte_t;
-typedef unsigned long pmd_t;
-typedef unsigned long pgd_t;
-typedef unsigned long pgprot_t;
-#define pte_val(x) (x)
-#define pmd_val(x) (x)
-#define pgd_val(x) (x)
-#define pgprot_val(x) (x)
-#define __pte(x) (x)
-#define __pmd(x) (x)
-#define __pgd(x) (x)
-#define __pgprot(x) (x)
-/* align addr on a size boundry - adjust address up if needed -- Cort */
-#define _ALIGN(addr,size) (((addr)+size-1)&(~(size-1)))
-/* to align the pointer to the (next) page boundary */
-#define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK)
-#define clear_page(page) memset((void *)(page), 0, PAGE_SIZE)
-#define copy_page(to,from) memcpy((void *)(to), (void *)(from), PAGE_SIZE)
-/* map phys->virtual and virtual->phys for RAM pages */
-#define __pa(x) ((unsigned long)(x)-PAGE_OFFSET)
-#define __va(x) ((void *)((unsigned long)(x)+PAGE_OFFSET))
-#define MAP_NR(addr) (((unsigned long)addr-PAGE_OFFSET) >> PAGE_SHIFT)
-#define MAP_PAGE_RESERVED (1<<15)
-extern unsigned long get_zero_page_fast(void);
-#endif /* ASM */
-#endif /* _LIBCPU_PAGE_H */
diff --git a/c/src/lib/libbsp/powerpc/shared/bootloader/misc.c b/c/src/lib/libbsp/powerpc/shared/bootloader/misc.c
index 111e02b..5084672 100644
--- a/c/src/lib/libbsp/powerpc/shared/bootloader/misc.c
+++ b/c/src/lib/libbsp/powerpc/shared/bootloader/misc.c
@@ -19,11 +19,13 @@
#include "bootldr.h"
#include <libcpu/spr.h>
#include "zlib.h"
-#include <libcpu/page.h>
#include <libcpu/byteorder.h>
#include <rtems/bspIo.h>
#include <bsp.h>
+/* to align the pointer to the (next) page boundary */
+#define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK)
SPR_RO(PPC_PVR)
struct inode;
diff --git a/c/src/lib/libbsp/powerpc/shared/bootloader/mm.c b/c/src/lib/libbsp/powerpc/shared/bootloader/mm.c
index ea3cdde..e954218 100644
--- a/c/src/lib/libbsp/powerpc/shared/bootloader/mm.c
+++ b/c/src/lib/libbsp/powerpc/shared/bootloader/mm.c
@@ -41,9 +41,11 @@
#include <libcpu/mmu.h>
#include <limits.h>
extern void (tlb_handlers)(void);
extern void (_handler_glue)(void);
diff --git a/c/src/lib/libbsp/powerpc/shared/bootloader/pci.c b/c/src/lib/libbsp/powerpc/shared/bootloader/pci.c
index 0c9472e..c9daca4 100644
--- a/c/src/lib/libbsp/powerpc/shared/bootloader/pci.c
+++ b/c/src/lib/libbsp/powerpc/shared/bootloader/pci.c
@@ -19,7 +19,6 @@
#include "pci.h"
#include <libcpu/io.h>
#include <bsp/consoleIo.h>
#include <bsp.h>
diff --git a/c/src/lib/libbsp/powerpc/shared/console/polled_io.c b/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
index 1086e59..331515b 100644
--- a/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
+++ b/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
@@ -16,7 +16,6 @@
#include <sys/types.h>
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c b/c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c
index 66bb8ef..8a8407b 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c
@@ -1,6 +1,5 @@
#include <libcpu/pte121.h>
@@ -15,6 +14,9 @@
* Also, the 'setup' routine must reduce
* *pmemsize by the size of the page table.
* Authorship
1.8.3.1
