want to contribute to project
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sat Mar 3 22:18:04 UTC 2018
Hello sir,
I need some guidance to proceed to apply for #2920 as my GSoC project.
I wanted to know the following points :
 1. What are the prerequisites (do I have to produce something ? like the
hello world )
 2. reference materials (like specific doc), to familiarise with the
rtems-tester and rsb .
 3. how to properly plan the project into phase wise tasks and weekly
sub-tasks.
Thank you,
Vijay k.
On 1 March 2018 at 15:38, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 1 March 2018 at 09:10, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> hello,
>> while trying to figure out the starting point, I came across this project
>> form GSoC 2017 by C.P. O'Donell
>> https://summerofcode.withgoogle.com/archive/2017/projects/
>> 4925375616385024/
>> Is this the project that has previous works on the project I'm wanting to
>> take (#2920) ? If not , please help me find the right one.
> Hi Vijay,
> Yes that's the one, let me know if you have any questions about it. When I
> checked last month coverage is not working with the RTEMS Tester because
> the configuration files for the bsps in rtems-tools/tester/rtems have been
> converted from .mc to .ini So the old .mc files I mention need to be
> converted before it will work again.
> This is what I wrote as the final documentation, it should help you
> reproduce what I had working last summer.
> https://devel.rtems.org/wiki/GSoC/2017/coveragetools
> Try this branch in github for the starting point:
> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
> Good luck with the project,
> Cillian.
>> Also, please guide me with reading references and some small tickets
>> related to the project .
>> Thank you ,
>> Vijay k.
>> On 26 February 2018 at 21:54, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Thank you for giving me a detailed introduction to the project
>>> objectives and mentors.
>>>  I am interested in # 2920: "Improve Coverage analysis toolkit".
>>> Please guide me with the resources to get started with the project and
>>> get a deep understanding.
>>> Thank you
>>> Vijay
>>> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
>>>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>>>> christian.mauderer at embedded-brains.de> wrote:
>>>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>>>> > Hello,
>>>> > As told by Joel, I sent the screenshots of my working hello world to
>>>> his
>>>> > personal email and have also included my name in the GSoC tracking
>>>> page .
>>>> > + Make Eclipse Target Interaction work with RTEMS
>>>> > (https://www.eclipse.org/tcf/)
>>>> > + Improvements to our coverage reporting. GCOV validation and covoar
>>>> > reporting improvements
>>>> > + wifi integration improvements
>>>> > + aarch64 port
>>>> > + x86_64 port / non-legacy PC BSP
>>>> >    - This project is large so we would need to work with whoever wants
>>>> > to tackle it
>>>> >      to find the best subset for GSoC.
>>>> > Based on this list I went through the OpenProjects page
>>>> > and came across the following Tickets .,
>>>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>>>> > out of them , I find these interesting
>>>> > 1.  "Improve coverage Analysis Toolset " (#2920);
>>>> This area is mine. The ticket mat or may not be a great description of
>>>> the goals. There are probably three things that need to be done.
>>>> + Integrate ran recipes for Couverture variant of qemu. This might be a
>>>> very small task. Last year's student just didn't get this integrated and
>>>> was waiting for some patches to be merged on their side.
>>>> + Verify the gcov output from covoar is correct and the gcov (and
>>>> similar tools) matches the coverage reports it generates. We have someone
>>>> from the GCC community to help mentor here.
>>>> + Covoar generates HTML and text output directly. There is a desire for
>>>> it to generate something equally useful that is processed by existing tools
>>>> to generate reports. One possible option for this output could be Sphinx
>>>> like our regular documentation. Or it could be a data-centric format
>>>> processed by other tools. The current HTML allows filtering and sorting so
>>>> not losing information and ease of use is important. This probably will end
>>>> up simplifying C++ and adding Python.
>>>> > 2.  "libbsd:WiFi support needs rc.conf integration " (#3222)
>>>> Christian's project to mentor.
>>>> > also I came across # 3302 :" Build system conversion of BSP
>>>> Config(.cfg)
>>>> > files to pkg-config(.pc) files"
>>>> > (I have some knowledge of Python, but not proficient in it, I can
>>>> learn
>>>> > it better if it's required )
>>>> > which I find interesting
>>>> This one is Chris Johns project to mentor. It is an important and
>>>> logically the next step in replacing our build system with the Python based
>>>> waf. If you get through this one before the summer is out, then working on
>>>> waf would probably make sense.
>>>> Did I miss one?
>>>> Hello Vijay,
>>>> all of the projects would be good ones.
>>>> The #2920 and #3302 are more connected to the host tools. They should be
>>>> doable with few or no real hardware. But you should ask the two
>>>> potential mentors about that.
>>>> For the #3222 you would need some board supported by the libbsd (like
>>>> Beagle Bone Black) and I would suggest a JTAG debugger (some OpenOCD
>>>> based or similar).
>>>> > Am I following the right tickets? If not please help me find the
>>>> right ones.
>>>> The tickets are the right ones.
>>>> > Out of these , which one do you recommend me to take ?
>>>> I would recommend to take a more detailed look at the tickets and start
>>>> to ask some questions about it on the mailing list with CC to the
>>>> (potential) mentors.
>>>> Maybe you could also try to find some small tickets related to similar
>>>> topics and just try to work on these. That could help you find out what
>>>> you want to do.
>>>> > My experience with C/C++ : I am proficient in C++11 with STL . Also
>>>> > proficient in C language .
>>>> > My experience with opensource : This is the first open source project
>>>> > I'm taking up .
>>>> It's no problem if it's your first Open Source project. That's the point
>>>> of GSoC: To collect first Open Source experience.
>>>> Best regards
>>>> Christian Mauderer
>>>> > Thank you ,
>>>> > Vijay K.
>>>> embedded brains GmbH
>>>> Herr Christian Mauderer
>>>> Dornierstr. 4
>>>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>>>> D-82178 Puchheim
>>>> Germany
>>>> email: christian.mauderer at embedded-brains.de
>>>> Phone: +49-89-18 94 741 - 18
>>>> Fax:   +49-89-18 94 741 - 08
>>>> PGP: Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180304/389bca43/attachment-0002.html>
