patch regarding 'RTEMS not booting with Qemu PREP larger than 256Mb'
Joel Sherrill
joel at rtems.org
Tue Mar 6 17:36:26 UTC 2018
On Tue, Mar 6, 2018 at 11:25 AM, Éric Tremblay <e.tremblay at axis-canada.com>
wrote:
> Hi Gedare, Joel,
> Unfortunately I do not have access to hw so I cannot test in this
> environment.
Hmm... We will have to find someone with a board to test it. I have a few
users in mind.
> Do you want me to create the ticket or one of you will take care of it?
It would be best if you do, because you have the issue and patch.
> Thanks,
> Eric
> On Tue, Mar 6, 2018 at 12:02 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Mar 5, 2018 at 5:37 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > Can you file a ticket with the patch attached? We don't change things
>> on a
>> > release
>> > branch without a ticket? devel.rtems.org
>> +1
>> > Are you able to test this on real hardware? It touches files in shared
>> which
>> > will
>> > be used by multiple powerpc BSPs so it would be good to have feedback on
>> > real HW.
>> +2
>> This should be verified on hw before applying especially to a release.
>> If it affects hw, also change the comments to just say "greater than
>> 256 MiB" without specifying qemu -m option.
>> > FWIW we are trying to wrap up a set of patches for a 4.11 release and it
>> > would
>> > be good to have this in the ticket queue for consideration.
>> > Thanks.
>> > --joel
>> > On Mon, Mar 5, 2018 at 2:31 PM, Éric Tremblay <
>> > wrote:
>> >> Hi,
>> >> I posted a question last week about a strange behavior I was getting
>> using
>> >> RTEMS with qemu-system-ppc. Anytime I was specifying more than 256Mb
>> of
>> >> memory using the -m option the RTEMS kernel was not booting. Here is
>> an
>> >> example of command line I was using:
>> >> qemu-system-ppc -M prep -kernel ./hello.ralf -bios
>> >> /home/qemu_fakerom/qemu_fakerom.bin -cpu 750cxe -nographic -no-reboot
>> -m 384
>> >> Model:
>> >> Serial:
>> >> Processor/Bus frequencies (Hz): 300000000/100000000
>> >> Time Base Divisor: 1000
>> >> Memory Size: 18000000
>> >> Residual: 102afd4 (length 27148)
>> >> PCI: Probing PCI hardware
>> >> RTEMS 4.x/PPC load:
>> >> Uncompressing the kernel...
>> >> Kernel at 0x00000000, size=0x495b0
>> >> Initrd at 0x00000000, size=0x0
>> >> Residual data at 0x0004a000
>> >> Command line at 0x00051000
>> >> done
>> >> Now booting... <<<<<<<<<<<<<<<<
>> execution
>> >> stuck here
>> >> I have spent quite some time debugging this issue and I traced it back
>> to
>> >> two issues for which I am submitting a patch. Please understand this
>> is my
>> >> first time using RTEMS and debugging a bootloader so my patch might
>> not be
>> >> accurate but it does fix the behavior I mentioned above. With this
>> patch I
>> >> can successfully launch a "Hello World" and specify more memory (-m
>> 512 for
>> >> example).
>> >> My patch is quite simple since it simply allows the system to access
>> >> section of memory. Please let me know if this is a suitable
>> correction, if
>> >> this is totally wrong I would like to know how this could be fixed
>> since our
>> >> application will use around 512Mb of memory and the current state of
>> things
>> >> won't work.
>> >> Thank you for your cooperation,
>> >> Eric
>> >> PS: I am using RTEMS release 4.11.3.
>> >> I am using Qemu v 2.5.0
>> >> I am running in a Linux Ubuntu VM (intel 64 bits)
>> >> c/src/lib/libbsp/powerpc/shared/start/start.S | 18
>> >> c/src/lib/libbsp/powerpc/shared/startup/bspstart.c | 18
>> >> 2 files changed, 36 insertions(+)
>> >> diff --git a/c/src/lib/libbsp/powerpc/shared/start/start.S
>> >> b/c/src/lib/libbsp/powerpc/shared/start/start.S
>> >> index 729c89c40b..532c1f9ee4 100644
>> >> --- a/c/src/lib/libbsp/powerpc/shared/start/start.S
>> >> +++ b/c/src/lib/libbsp/powerpc/shared/start/start.S
>> >> @@ -93,6 +93,24 @@ __rtems_entry_point:
>> >> mtspr IBAT0L,r8
>> >> mtspr IBAT0U,r11
>> >> isync
>> >> +/* Map section where residual is located if outside
>> >> + * the first 256Mb of RAM. This is to support cases
>> >> + * where the user supplies the -m option with Qemu
>> >> + * in order to have more memory available to the system.
>> >> + mr r9, r1 /* Get where residual was mapped */
>> >> + lis r12,0xf0000000 at h
>> >> + and r9,r9,r12
>> >> + cmpi 0,1,r9, 0
>> >> + beq skip_BAT1_config
>> >> + isync
>> >> + ori r11,r9,0x1ffe
>> >> + mtspr DBAT1L,r8 /* N.B. 6xx (not 601) have valid */
>> >> + mtspr DBAT1U,r11 /* bit in upper BAT register */
>> >> + mtspr IBAT1L,r8
>> >> + mtspr IBAT1U,r11
>> >> + isync
>> >> +skip_BAT1_config:
>> >> * we now have the 1st 256M of ram mapped with the bats. We are still
>> >> diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
>> >> b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
>> >> index 5a97cc8531..f80835b117 100644
>> >> --- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
>> >> +++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
>> >> @@ -300,6 +300,24 @@ void bsp_start( void )
>> >> _BSP_clear_hostbridge_errors(0 /* enableMCP */, 0/*quiet*/);
>> >> + if (BSP_mem_size > 0x10000000)
>> >> + /* Support cases with qemu supplied -m option and mem size larger
>> than
>> >> 256Mb.
>> >> + * We use BAT3 in order to obtain access to the top section of the
>> >> RAM.
>> >> + * We also need to do this just before setting up the page table
>> >> because
>> >> + * this is where the page table will be located.
>> >> + const unsigned int mem256Count = (BSP_mem_size / 0x10000000);
>> >> + const unsigned int BAT3Addr = ((BSP_mem_size % 0x10000000) ?
>> >> + (mem256Count * 0x10000000) :
>> >> + ((mem256Count-1) * 0x10000000));
>> >> + setdbat(3, BAT3Addr, BAT3Addr, 0x10000000, IO_PAGE);
>> >> +#ifdef SHOW_MORE_INIT_SETTINGS
>> >> + printk("Setting up BAT3 for large memory support. (BAT3 -->
>> >> 0x%x)\n", BAT3Addr);
>> >> +#endif
>> >> /* Allocate and set up the page table mappings
>> >> * This is only available on >604 CPUs.
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180306/b1cc38ff/attachment-0002.html>
