getentropy() implementation on BBB
Udit agarwal dev.madaari at gmail.com
Sun Mar 11 18:22:12 UTC 2018
Hi,
I have updated the patch and tested getentropy() , it did seem to work
(Logs: here
<https://gist.github.com/madaari/17bdec209eac993538b0192fba014918>).
Moreover, i've added BSD-2-clause license please verify it once. Also, i
need to shift
TRNG register structure from AM335x.h to bbb_getentropy.c . since, keeping
it in am335x.h
requires including stdint.h (for uint32_t etc) which i don't think would be
right, do let me know if this
is the right way.
Here's the patch:
>From f87b39708dd06482957fc7b33e78ab0ee095287b Mon Sep 17 00:00:00 2001
Date: Sun, 11 Mar 2018 23:34:17 +0530
Subject: [PATCH] Added getentropy support to BBB BSP
 bsps/arm/include/libcpu/am335x.h                   |  22 +++-
 c/src/lib/libbsp/arm/beagle/Makefile.am            |   4 +-
 .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 128
 3 files changed, 152 insertions(+), 2 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/beagle/getentropy/bbb_getentropy.c
diff --git a/bsps/arm/include/libcpu/am335x.h
b/bsps/arm/include/libcpu/am335x.h
index 367e97c..bbdc8d0 100644
--- a/bsps/arm/include/libcpu/am335x.h
+++ b/bsps/arm/include/libcpu/am335x.h
@@ -14,6 +14,9 @@
  * Modified by Ben Gras <beng at shrike-systems.com> to add lots
  * of beagleboard/beaglebone definitions, delete lpc32xx specific
  * ones, and merge with some other header files.
+ * Modified by Udit agarwal <dev.madaari at gmail.com> to add random
+ * number generating module definitions.
 #if !defined(_AM335X_H_)
@@ -701,4 +704,21 @@
 #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
(0x00000020u)
 #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
-#endif
+/* TRNG Register */
+/* RNG base address */
+#define RNG_BASE 0x48310000
+/* RNG clock control */
+#define CM_PER_RNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
+/* rng module clock status bits */
+#define AM335X_CLK_RNG_BIT_MASK (0x30000)
+/* Offset from RNG base for output ready flag */
+#define RNG_STATUS_RDY (1u <<  0)
+/* Offset from RNG base for FRO related error */
+#define RNG_STATUS_ERR (1u <<  1)
+/* Offset from RNG base for clock status */
+#define RNG_STATUS_CLK (1u << 31)
+/* enable module */
+#define AM335X_RNG_ENABLE (1 << 10)
+#endif
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8251660..5d5ade3 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -40,7 +40,6 @@ libbsp_a_LIBADD =
 # Shared
 libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
 libbsp_a_SOURCES += ../../shared/src/bsp-fdt.c
 libbsp_a_SOURCES += ../../shared/bspclean.c
 libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
@@ -88,6 +87,9 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
 #pwm
 libbsp_a_SOURCES += pwm/pwm.c
+#getentropy
+libbsp_a_SOURCES += getentropy/bbb_getentropy.c
 #RTC
 libbsp_a_SOURCES += rtc.c
 libbsp_a_SOURCES += ../../shared/tod.c
diff --git a/c/src/lib/libbsp/arm/beagle/getentropy/bbb_getentropy.c
b/c/src/lib/libbsp/arm/beagle/getentropy/bbb_getentropy.c
new file mode 100644
index 0000000..117c6b8
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/getentropy/bbb_getentropy.c
@@ -0,0 +1,128 @@
+* @file
+* @ingroup arm_beagle
+* @brief Getentropy implementation on BeagleBone Black BSP
+*Copyright 2018 Udit kumar agarwal <dev.madaari at gmail.com>
+*Redistribution and use in source and binary forms, with or without
+*modification, are permitted provided that the following conditions are
met:
+*1. Redistributions of source code must retain the above copyright notice,
+*   this list of conditions and the following disclaimer.
+*2. Redistributions in binary form must reproduce the above copyright
notice,
+*   this list of conditions and the following disclaimer in the
documentation
+*   and/or other materials provided with the distribution.
+*THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS"
+*AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+*IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+*ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+*LIABLE FOR ANY DIRECT,INDIRECT, INCIDENTAL, SPECIAL,EXEMPLARY, OR
+*CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+*SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,OR PROFITS; OR BUSINESS
+*INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,WHETHER IN
CONTRACT,
+*STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
+*ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY
+*OF SUCH DAMAGE.
+#include <libcpu/am335x.h>
+#include <unistd.h>
+#include <string.h>
+#include <rtems/sysinit.h>
+#include <stdint.h>
+/* max refill 34 * 256 cycles */
+#define AM335X_RNG_MAX_REFILL (34 << 16)
+/* min refill 33 * 64 cycles */
+#define AM335X_RNG_MIN_REFILL (33 << 0)
+/* startup 33 * 256 cycles */
+#define AM335X_RNG_STARTUP_CYCLES (33 << 16)
+/* TRNG register structure */
+struct bbb_trng_register
+    uint64_t output;     /* 00 */
+    uint32_t status;     /* 08 */
+    uint32_t irq_en;     /* 0c */
+    uint32_t status_clr; /* 10 */
+    uint32_t control;    /* 14 */
+    uint32_t config;     /* 18 */
+typedef struct bbb_trng_register bbb_trng_register;
+/* maximun and minimum refill cycle sets the number of samples to be taken
+   from FRO to generate random number */
+static void am335x_rng_enable(volatile bbb_trng_register *rng)
+    rng->control = rng->config = 0;
+    rng->config |= AM335X_RNG_MIN_REFILL | AM335X_RNG_MAX_REFILL ;
+    rng->control |= AM335X_RNG_STARTUP_CYCLES | AM335X_RNG_ENABLE ;
+static void am335x_rng_clock_enable(void)
+    *(volatile uint8_t *) CM_PER_RNG_CLKCTRL = 2;
+    while(
+      *(volatile uint32_t *) CM_PER_RNG_CLKCTRL &
+      AM335X_CLK_RNG_BIT_MASK
+        /* wait */
+static uint64_t trng_getranddata(volatile bbb_trng_register *rng)
+    uint64_t output = rng->output;
+    return output;
+int getentropy(void *ptr, size_t n)
+    volatile bbb_trng_register  *rng = (bbb_trng_register*) RNG_BASE;
+    am335x_rng_enable(rng);
+    while (n > 0)
+        uint64_t random;
+        size_t copy;
+        /* wait untill RNG becomes ready with next set of random data */
+        while( ( rng->status & RNG_STATUS_RDY ) == 0 )
+            /* wait */
+        random = trng_getranddata(rng);
+        /* Checking for error by masking all bits other then error bit in
+           status register */
+        if( ((rng->status & RNG_STATUS_ERR)>>1) == 1)
+            /* clear the status flag after reading to generate new random
+               value */
+            rng->status_clr = RNG_STATUS_RDY;
+            copy = sizeof(random);
+            if ( n < copy )
+                copy = n;
+            memcpy(ptr, &random, copy);
+            n -= copy;
+            ptr = (char*)ptr + copy;
+    return 0;
+RTEMS_SYSINIT_ITEM(
+    am335x_rng_clock_enable,
+    RTEMS_SYSINIT_DEVICE_DRIVERS,
+    RTEMS_SYSINIT_ORDER_LAST
1.9.1
Best regards,
Udit agarwal
On Wed, Mar 7, 2018 at 11:40 PM, Christian Mauderer <list at c-mauderer.de>
wrote:
> Hello Udit,
> let me start with a hint: It's quite normal that the first patches of a
> contributor get a lot of attention and have a lot of revisions. That can
> be quite annoying for the one who writes the patch. But please
> understand it in the way it's thought: As suggestions for improvement.
> Did you already test that patches? There is a (quite basic) test in the
> RTEMS testsuite: libtests/getentropy01. This test should run without
> problems. If you have a debugger, you might also want to check whether
> your getentropy implementation is reached and not the generic one.
> The patch looks quite good already. But like I said: A lot of revisions.
> I added some further remarks in the patch below ;-)
> Best regards
> Christian
> Am 07.03.2018 um 11:26 schrieb Udit agarwal:
> > Hi,
> > I have updated the code, please have a look.
> > From 74b8f4f5b9dd929b71ed5fb9dd0bc721a6f27a28 Mon Sep 17 00:00:00 2001
> > From: Udit agarwal <dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>
> > Date: Wed, 7 Mar 2018 15:52:13 +0530
> > Subject: [PATCH] Added getentropy support to beagle BSP
> >  bsps/arm/include/libcpu/am335x.h                   | 34 ++++++++-
> >  .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 88
> >  3 files changed, 125 insertions(+), 1 deletion(-)
> > index 367e97c..92af6dc 100644
> > @@ -14,6 +14,9 @@
> > <mailto:beng at shrike-systems.com>> to add lots
> > <mailto:dev.madaari at gmail.com>> to add random
> > + * number generating module definitions along with register structure.
> > @@ -701,4 +704,33 @@
> > (0x00000020u)
> > -#endif
> > +    uint64_t output; /*00*/
> > +    uint32_t status; /*08*/
> > +    uint32_t irq_en; /*0c*/
> > +    uint32_t status_clr; /*10*/
> > +    uint32_t control; /*14*/
> > +    uint32_t config; /*18*/
> > +#endif
> > index 8251660..bf92081 100644
> > @@ -88,9 +88,13 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
> >  #pwm
> > +#getentropy
> Adding that one is good. But please also remove the default
> implementation from the Makefile.am:
> Otherwise you might get problems during linking.
> >  #RTC
> You added a empty line in a section where you didn't change anything
> else. Normally that's not a good idea because it slightly obfuscates the
> history. Try to generate patches that only touch the area that is
> related to your change. If you really think that this line should be
> added, you should create a second patch with a description like "fix
> spacing" or similar. But I wouldn't suggest to do that.
> >  # Clock
> >  libbsp_a_SOURCES += clock.c
> >  libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
> > index 0000000..5b7c5d0
> > --- /dev/null
> > @@ -0,0 +1,88 @@
> > +* @file
> > +* Copyright (c) 2018 Udit kumar agarwal <dev.madaari at gmail.com
> > <http://gmail.com>>
> > +* The license and distribution terms for this file may be
> > +* found in the file LICENSE in this distribution or at
> > +* http://www.rtems.org/license/LICENSE.
> > +#include <rtems/types.h>
> taken
> > +static void am335x_rng_enable(bbb_trng_register *rng)
> > +    while( *(volatile uint32_t *) CM_PER_RNG_CLKCTRL &
> > AM335X_CLK_RNG_BIT_MASK ) {}
> Is this line within 80 characters? The RTEMS style uses lines <= 80 chars.
> When I'm already at style: Although it's not strictly enforced in BSPs,
> RTEMS uses two spaces for indentation. See
> https://devel.rtems.org/wiki/Developer/Coding/Conventions
> Also I don't think we have a style rule for that I would suggest that
> you mark it if you have an intentionally empty loop. That makes it clear
> that you didn't just forget to write some code. E.g.
>   while( some condition ) {
>     /* wait */
> > +static uint64_t trng_getranddata(bbb_trng_register *rng)
> > +    return output;
> > +    volatile const bbb_trng_register  *rng = (bbb_trng_register*)
> RNG_BASE;
> > +    while (n > 0)
> > +        uint64_t random;
> > +        size_t copy;
> > +        while( ( rng->status & RNG_STATUS_RDY ) == 0 );
> Again: I would suggest to mark it that this loop is intentionally empty.
> > in status register */
> <= 80 Chars?
> > +        if( ((rng->status & RNG_STATUS_ERR)>>1) == 0)
> > random value*/
> <= 80 Chars?
> > +            if ( n < copy )
> > +                copy = n;
> > +            n -= copy;
> > +    return 0;
> > 1.9.1
> > Regards,
> > Udit agarwal
> > On Tue, Mar 6, 2018 at 11:05 PM, Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> >     On Tue, Mar 6, 2018 at 9:43 AM, Udit agarwal <dev.madaari at gmail.com
> >     <mailto:dev.madaari at gmail.com>> wrote:
> >     > Hi,
> >     > Here's the updated code(I have also attached the patch PFA):
> >     > From 96e6e1bfd8cffeef5d309eb0a07fe2bfd086ef0a Mon Sep 17 00:00:00
> 2001
> >     > Date: Tue, 6 Mar 2018 20:07:44 +0530
> >     >  bsps/arm/beagle/headers.am <http://headers.am>
> >          |  1 +
> >     >  bsps/arm/beagle/include/bsp/bbb_getentropy.h       | 57
> >     >  bsps/arm/include/libcpu/am335x.h                   | 16 +++++
> >     >  c/src/lib/libbsp/arm/beagle/Makefile.am            |  4 ++
> >     >  .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 80
> >     >  5 files changed, 158 insertions(+)
> >     >  create mode 100644 bsps/arm/beagle/include/bsp/bbb_getentropy.h
> >     >  create mode 100644
> >     > diff --git a/bsps/arm/beagle/headers.am <http://headers.am>
> >     b/bsps/arm/beagle/headers.am <http://headers.am>
> >     > index 6692d0b..ac4ff7c 100644
> >     > --- a/bsps/arm/beagle/headers.am <http://headers.am>
> >     > +++ b/bsps/arm/beagle/headers.am <http://headers.am>
> >     > @@ -12,3 +12,4 @@ include_bsp_HEADERS +=
> >     > ../../../../../../bsps/arm/beagle/include/bsp/bbb-pwm.h
> >     > ../../../../../../bsps/arm/beagle/include/bsp/beagleboneblack.h
> >     ../../../../../../bsps/arm/beagle/include/bsp/i2c.h
> >     ../../../../../../bsps/arm/beagle/include/bsp/irq.h
> >     > +include_bsp_HEADERS +=
> >     > ../../../../../../bsps/arm/beagle/include/bsp/bbb_getentropy.h
> >     > diff --git a/bsps/arm/beagle/include/bsp/bbb_getentropy.h
> >     > b/bsps/arm/beagle/include/bsp/bbb_getentropy.h
> >     > index 0000000..5e46f89
> >     > --- /dev/null
> >     > +++ b/bsps/arm/beagle/include/bsp/bbb_getentropy.h
> >     > @@ -0,0 +1,57 @@
> >     > + * @file
> >     > + * @ingroup arm_beagle
> >     > + * @brief TRNG Definations
> >     > + * Copyright (c) 2018 Udit kumar agarwal <dev.madaari at
> >     gmail.com <http://gmail.com>>
> >     > + * The license and distribution terms for this file may be
> >     > + * found in the file LICENSE in this distribution or at
> >     > + * http://www.rtems.org/license/LICENSE
> >     <http://www.rtems.org/license/LICENSE>.
> >     > +#ifndef _TRNG_
> >     > +#define _TRNG_
> >     Please look at similar files in RTEMS for how to add comments.
> >     We do not use this style /* --------------------
> >     And we don't put this kind of comment about the file sections.
> >     > + *         Headers
> >     > + *         Register structure
> >     > +struct rng {
> >     for an exported header, the struct namespace needs to be user
> >     friendly. See similar files at this layer for how to name things.
> >     Probably, this can be defined in the am335x.h header?
> >     > +typedef volatile struct rng *rng_ref_t;
> >     I'm not such a big fan of using the typedef to hide things like
> >     volatile or pointer notation. I don't see a need for this usually.
> >     > +/*         Exported functions
> >     > +/* configure and enable RNG module  */
> >     > +static void am335x_rng_enable(rng_ref_t);
> >     > +/* enable module clock for random number generator */
> >     > +static void am335x_rng_clock_enable(void);
> >     > +/* outputs random data */
> >     > +static uint64_t trng_getranddata(rng_ref_t);
> >     static keyword implies these are not exported.
> >     > +/* Copy random data of a specified size to the pointer supplied */
> >     > +int getentropy(void *ptr, size_t);
> >     I guess getentropy() is already exported by a different header file
> >     (unistd.h) in libc? This doesn't belong here.
> >     I suspect this header file is not actually necessary.
> >     Don't use multiple blank lines in a row. Only one empty line is ever
> >     needed by RTEMS style.
> >     > +#endif /* #ifndef _TRNG_ */
> >     > index 367e97c..8b58f1a 100644
> >     > @@ -14,6 +14,9 @@
> >     >   * Modified by Ben Gras <beng at shrike-systems.com <mailto:
> >     > + * Modified by Udit agarwal <dev.madaari at gmail.com <mailto:
> >     > + * number generating module definations
> >     typo: definitions
> >     add a period (full stop).
> >     > @@ -701,4 +704,17 @@
> L4_GCLK
> >     > (0x00000020u)
> >     > +#define CM_PER_RNG_CLKCTRL    AM335X_CM_PER_ADDR | 9<<4
> >     I'd put parentheses around this to avoid any problems with macro
> >     expansions and order of operations.
> >     > +/* Offset from RNG base for FRO related error*/
> >     >  #endif
> >     >  #pwm
> >     > +#getentropy
> >     >  #RTC
> >     >  # Clock
> >     > index 0000000..cab2102
> >     > --- /dev/null
> >     > @@ -0,0 +1,80 @@
> >     > +* @file
> >     <http://gmail.com>>
> >     > +/* maximun and minimun refill cycle sets the number of samples to
> >     be taken
> >     typo: minimum
> >     > +static void am335x_rng_enable(rng_ref_t rng){
> >     put { on a new line.
> >     > +    rng->config = 0
> >     > +    | 34 << 16  /* max refill 34 * 256 cycles */
> >     indent broken lines, but
> >     > +    | 33 <<  0; /* min refill 33 * 64 cycles */
> >     You can fit this on one line, remove the comments and put them above
> >     the line, e.g.
> >     rng->config = 34<<16 | 33;
> >     I would prefer not to have these hard-coded values though it is
> >     fragile. what means 34, 16, and 33?
> >     #define AM335X_RNG_MIN_REFILL (33)
> >     #define AM335X_RNG_CONFIG_REFILL (AM335X_RNG_MAX_REFILL |
> >     AM335X_RNG_MIN_REFILL)
> >     rng.config = rng.control = 0;
> >     rng.config |= AM335X_RNG_CONFIG_REFILL_TIME;
> >     > +    rng->control = 0
> >     > +    | 33 << 16  /* startup 33 * 256 cycles */
> >     > +    |  1 << 10; /* enable module */
> >     rng.control |= AM335X_RNG_CONTROL_STARTUP;
> >     rng.control |= AM335X_RNG_CONTROL_ENABLE;
> >     for example is more readable. look around for other examples.
> >     > +    while( *(volatile uint32_t *) CM_PER_RNG_CLKCTRL & 0x30000 )
> >     > +static uint64_t trng_getranddata(rng_ref_t rng){
> >     > +    return output;
> >     > +    rng_ref_t const rng = (rng_ref_t) RNG_BASE;
> >     > +    while (n > 0) {
> >     > +    uint64_t random;
> >     indent blocks of code.
> >     > +    size_t copy;
> bit in
> >     > status register */
> >     > +    if( ((rng->status & RNG_STATUS_ERR)>>1) == 0){
> random
> >     > value*/
> >     > +        if ( n < copy ) {
> >     > +        copy = n;
> >     ditto.
> >     > +        n -= copy;
> >     > +        ptr += copy;
> >     pointer arithmetic on void pointer is not legal. You can portably use
> >     > +    return 0;
> >     > 1.9.1
> >     > Regards,
> >     > Udit Agarwal
> >     > On Tue, Mar 6, 2018 at 12:50 AM, Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>>
> >     > wrote:
> >     >> Am 05.03.2018 um 14:51 schrieb Udit agarwal:
> >     >> > Hi,
> >     >> > I tried implementing getentropy on BBB, below is the patch.
> >     Please have
> >     >> > a look.
> >     >> > I followed these(1
> >     >> > <https://e2e.ti.com/support/arm/sitara_arm/f/791/t/355064
> >     <https://e2e.ti.com/support/arm/sitara_arm/f/791/t/355064>> & 2
> >     <http://ftp.netbsd.org/pub/NetBSD/NetBSD-current/src/sys/
> arch/arm/omap/am335x_trng.c
> arch/arm/omap/am335x_trng.c>>)
> >     >> > links for code reference. and this
> >     <https://docs.google.com/spreadsheets/d/
> 1VpghMlLtrWQIrcvCsRg3ueRZkX0eGSQkFnzjfsqrd8A/view#gid=0
> 1VpghMlLtrWQIrcvCsRg3ueRZkX0eGSQkFnzjfsqrd8A/view#gid=0>>
> >     >> > for register reference. Moreover, what further configuration in
> >     RTEMS is
> >     >> > needed to execute and test this code along with getentropy()
> sample
> >     >> > testcode?
> >     >> Hello Udit,
> >     >> regarding the patch: Please use 'git format-patch' for generating
> >     your
> >     >> patches and send them unchanged to the mailing list (for example
> with
> >     >> 'git send-email'. If you follow this workflow, it's easier to
> >     apply and
> >     >> test the patches. The preferred workflow for RTEMS is described
> here:
> >     >> https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch
> >     <https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch>
> >     >> Regarding documentation: It seems that there is really only few
> >     >> documentation regarding the crypto part available. The FreeBSD
> >     driver is
> >     >> most likely your best source.
> >     >> I added further comments down in your code.
> >     >> Best regards
> >     >> Christian
> >     >> > +  * Copyright (c) 2018 embedded brains GmbH.  All rights
> reserved.
> >     >> > +  *  embedded brains GmbH
> >     >> > +  *  Dornierstr. 4
> >     >> > +  *  82178 Puchheim
> >     >> > +  *  Germany
> >     >> > +  *  <rtems at embedded-brains.de
> >     <mailto:rtems at embedded-brains.de> <mailto:rtems at embedded-brains.de
> >     <mailto:rtems at embedded-brains.de>>>
> >     >> Also it's nice if you add an embedded brains header, I don't
> >     think that
> >     >> I've seen you when I have been at work today. So please add your
> own
> >     >> name to the copyright line instead. With that you can even point
> >     to that
> >     >> file and tell everyone that it's from you.
> >     >> An address isn't really necessary except if you want it for some
> >     reason
> >     >> (like PR in case of a company).
> >     >> > + #include <libcpu/am335x.h>
> >     >> > + #include <unistd.h>
> >     >> > + #include <string.h>
> >     >> > + #include <rtems/sysinit.h>
> >     >> > + #define RNG_BASE    0x48310000
> >     >> > + #define CM_PER_RNG_CLKCTRL    0x44e00090
> >     >> > + #define RNG_STATUS_RDY    (1u <<  0)  // output ready for
> reading
> >     >> > + #define RNG_STATUS_ERR    (1u <<  1)  // FRO shutdown alarm
> >     >> > + #define RNG_STATUS_CLK    (1u << 31)  // module functional
> clock
> >     >> > active (no irq)
> >     >> Please add address definitions and the bit masks to the
> >     >> bsps/arm/include/libcpu/am335x.h instead of defining them here
> >     locally.
> >     >> Note that for the CM_PER_RNG_CLKCTRL, there is already a
> >     >> AM335X_CM_PER_ADDR that should be used as a base.
> >     >> > + typedef volatile struct rng *rng_ref_t;
> >     >> > + struct rng {
> >     >> > + /*00*/    uint64_t output;    //r-
> >     >> > + /*08*/    uint32_t status;    //r-
> >     >> > + /*0c*/    uint32_t irq_en;    //rw
> >     >> > + /*10*/    uint32_t status_clr;    //-c
> >     >> > + /*14*/    uint32_t control;    //rw
> >     >> > + /*18*/    uint32_t config;    //rw
> >     >> Same is true here: It's a structure describing the registers. So
> it
> >     >> should be in the header instead.
> >     >> It seems that you copied that from the forum post. Please always
> >     check
> >     >> the license when you copy code. We have to avoid that we get any
> code
> >     >> into RTEMS that isn't compatible with RTEMS license.
> >     >> In this case the code should be obvious enough that - if you just
> >     >> rewrite it in RTEMS style, there shouldn't be a problem. But just
> >     >> remember that licensing is always a difficult topic.
> >     >> > + static void TRNG_Enable(rng_ref_t rng){
> >     >> > +     rng->config = 0
> >     >> > +     | 34 << 16  // max refill 34 * 256 cycles
> >     >> > +     | 33 <<  0;  // min refill 33 * 64 cycles
> >     >> > +     rng->control = 0
> >     >> > +     | 33 << 16  // startup 33 * 256 cycles
> >     >> > +     |  1 << 10;  // enable module
> >     >> Please use C-Style comments /* */ in all pure C code (most of
> RTEMS).
> >     >> > + static void beagle_trng_clock_enable(void)
> >     >> > +     // enable module clock
> >     0x30000 ) {}
> >     >> > + static uint64_t TRNG_GetRandData(){
> >     >> 'rng' isn't defined here.
> >     >> > +     return output;
> >     >> > + int getentropy(void *ptr, size_t n)
> >     >> > +     TRNG_Enable(rng);
> >     >> > +     while (n > 0) {
> >     >> > +         uint64_t random;
> >     >> > +         size_t copy;
> >     >> > +         while( ( rng->status & RNG_STATUS_RDY ) == 0 ); //wait
> >     >> You should check specifically for the TRNG_STATUS_READY flag here
> >     like
> >     >> done in FreeBSD. I'm not sure what the other flags are but it's
> quite
> >     >> possible that there is also some error flag or similar. In that
> >     case it
> >     >> would not be a good idea to use the random number.
> >     >> > +         random = TRNG_GetRandData(rng);
> >     >> Note that you don't have to copy the function names from the atsam
> >     >> exactly. In the atsam BSP, the library has provided these names.
> >     >> Otherwise it's quite unusual to start functions with upper case
> >     in RTEMS.
> >     >> > +          * Read TRNG status one more time to avoid race
> >     condition.
> >     >> > +          * Otherwise we can read (and clear) an old ready
> >     status but
> >     >> > get
> >     >> > +          * a new value. The ready status for this value
> >     wouldn't be
> >     >> > +          * reset.
> >     >> That comment seems like it doesn't fit here any longer. You
> >     acknowledge
> >     >> the status instead in your next line. Just remove the comment.
> >     >> > +         if (n < copy ) {
> >     >> > +             copy = n;
> >     >> > +         n -= copy;
> >     >> > +         ptr += copy;
> >     >> > +     return 0;
> >     >> > + RTEMS_SYSINIT_ITEM(
> >     >> > +   beagle_trng_clock_enable,
> >     >> > Regards,
> >     >> > Udit agarwal
> >     >> > _______________________________________________
> >     >> > devel mailing list
> >     >> > devel at rtems.org <mailto:devel at rtems.org>
> >     >> > http://lists.rtems.org/mailman/listinfo/devel
> >     <http://lists.rtems.org/mailman/listinfo/devel>
> >     > devel mailing list
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180311/3ec89a15/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180311/3ec89a15/attachment-0002.bin>
