[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal dev.madaari at gmail.com
Tue Mar 13 14:59:45 UTC 2018
Hi,
I have updated the patch, following were the changes:
*Removed trialling white spaces and added new line at the end of each file
*am335x_rng_enable() is now being called only once during initialization.
*changed  directory to /arm/beagle/dev/bbb_getentropy.c
*Renamed TRNG register structure as: am335x_trng_register
I have tested the patch after making above changes and it worked as before.
I need some suggestion regarding the solution to the problem raised during
parallel execution of getentropy(),
In that case, Two processes can actually fetch same random number. I was
thinking to implement some sort of
flag set/reset variable in shared memory, which can be used to implement a
lock for TRNG register access something
like a binary semaphore.
>From b10e55c7f5cc8ca95b0d9b6a8cc7b8e37330544b Mon Sep 17 00:00:00 2001
Date: Tue, 13 Mar 2018 15:50:43 +0530
Subject: [PATCH] Added getentropy support to Beagle BSP
 bsps/arm/include/libcpu/am335x.h                 |  33 +++++++
 c/src/lib/libbsp/arm/beagle/Makefile.am          |   4 +-
 c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c | 117
 3 files changed, 153 insertions(+), 1 deletion(-)
 create mode 100644 c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
diff --git a/bsps/arm/include/libcpu/am335x.h
b/bsps/arm/include/libcpu/am335x.h
index 367e97c..6170ef3 100644
--- a/bsps/arm/include/libcpu/am335x.h
+++ b/bsps/arm/include/libcpu/am335x.h
@@ -14,11 +14,17 @@
  * Modified by Ben Gras <beng at shrike-systems.com> to add lots
  * of beagleboard/beaglebone definitions, delete lpc32xx specific
  * ones, and merge with some other header files.
+ * Modified by Udit agarwal <dev.madaari at gmail.com> to add random
+ * number generating module definitions and TRNG register structure.
 #if !defined(_AM335X_H_)
 #define _AM335X_H_
+/* For TRNG register definition */
+#include <stdint.h>
 /* Interrupt controller memory map */
 #define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
@@ -701,4 +707,31 @@
 #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
(0x00000020u)
 #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
+/* TRNG Register */
+/* RNG base address */
+#define RNG_BASE 0x48310000
+/* RNG clock control */
+#define CM_PER_RNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
+/* rng module clock status bits */
+#define AM335X_CLK_RNG_BIT_MASK (0x30000)
+/* Offset from RNG base for output ready flag */
+#define RNG_STATUS_RDY (1u <<  0)
+/* Offset from RNG base for FRO related error */
+#define RNG_STATUS_ERR (1u <<  1)
+/* Offset from RNG base for clock status */
+#define RNG_STATUS_CLK (1u << 31)
+/* enable module */
+#define AM335X_RNG_ENABLE (1 << 10)
+/* TRNG register structure */
+typedef struct {
+  uint64_t output;     /* 00 */
+  uint32_t status;     /* 08 */
+  uint32_t irq_en;     /* 0c */
+  uint32_t status_clr; /* 10 */
+  uint32_t control;    /* 14 */
+  uint32_t config;     /* 18 */
+} am335x_trng_register;
 #endif
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8251660..c483dc4 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -40,7 +40,6 @@ libbsp_a_LIBADD =
 # Shared
 libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
 libbsp_a_SOURCES += ../../shared/src/bsp-fdt.c
 libbsp_a_SOURCES += ../../shared/bspclean.c
 libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
@@ -88,6 +87,9 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
 #pwm
 libbsp_a_SOURCES += pwm/pwm.c
+#getentropy
+libbsp_a_SOURCES += dev/bbb_getentropy.c
 #RTC
 libbsp_a_SOURCES += rtc.c
 libbsp_a_SOURCES += ../../shared/tod.c
diff --git a/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
new file mode 100644
index 0000000..b2aea71
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
@@ -0,0 +1,117 @@
+* @file
+* @ingroup arm_beagle
+* @brief Getentropy implementation on BeagleBone Black BSP
+* Copyright (c) 2018 Udit agarwal <dev.madaari at gmail.com>
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+*    notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+*    notice, this list of conditions and the following disclaimer in the
+*    documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+* ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+* SUCH DAMAGE.
+#include <libcpu/am335x.h>
+#include <unistd.h>
+#include <string.h>
+#include <rtems/sysinit.h>
+/* max refill 34 * 256 cycles */
+#define AM335X_RNG_MAX_REFILL (34 << 16)
+/* min refill 33 * 64 cycles */
+#define AM335X_RNG_MIN_REFILL (33 << 0)
+/* startup 33 * 256 cycles */
+#define AM335X_RNG_STARTUP_CYCLES (33 << 16)
+/* maximun and minimum refill cycle sets the number of samples to be taken
+   from FRO to generate random number */
+static void am335x_rng_enable(volatile am335x_trng_register *rng)
+    rng->control = rng->config = 0;
+    rng->config |= AM335X_RNG_MIN_REFILL | AM335X_RNG_MAX_REFILL ;
+    rng->control |= AM335X_RNG_STARTUP_CYCLES | AM335X_RNG_ENABLE ;
+static void am335x_rng_clock_enable(void)
+    volatile am335x_trng_register  *rng = (am335x_trng_register*) RNG_BASE;
+    *(volatile uint8_t *) CM_PER_RNG_CLKCTRL = 2;
+    while(
+      *(volatile uint32_t *) CM_PER_RNG_CLKCTRL &
+      AM335X_CLK_RNG_BIT_MASK
+        /* wait */
+    am335x_rng_enable(rng);
+static uint64_t trng_getranddata(volatile am335x_trng_register *rng)
+    uint64_t output = rng->output;
+    return output;
+int getentropy(void *ptr, size_t n)
+    while (n > 0)
+        uint64_t random;
+        size_t copy;
+        /* wait untill RNG becomes ready with next set of random data */
+        while( ( rng->status & RNG_STATUS_RDY ) == 0 )
+            /* wait */
+        random = trng_getranddata(rng);
+        /* Checking for error by masking all bits other then error bit in
+           status register */
+        if( ((rng->status & RNG_STATUS_ERR)>>1) == 1)
+            /* clear the status flag after reading to generate new random
+               value */
+            rng->status_clr = RNG_STATUS_RDY;
+            copy = sizeof(random);
+            if ( n < copy )
+                copy = n;
+            memcpy(ptr, &random, copy);
+            n -= copy;
+            ptr = (char*)ptr + copy;
+    return 0;
+RTEMS_SYSINIT_ITEM(
+    am335x_rng_clock_enable,
+    RTEMS_SYSINIT_DEVICE_DRIVERS,
+    RTEMS_SYSINIT_ORDER_LAST
1.9.1
Regards,
Udit
On Tue, Mar 13, 2018 at 12:01 PM, Sebastian Huber <
> On 12/03/18 20:02, Udit agarwal wrote:
>> So, It looks like here's the final patch, do let me know if its ready to
>> be pushed. Also, it would be really helpful if someone else also tests this
>> patch before pushing(Although i have done that once).
>> Thanks,
>> Udit agarwal
>> From 454a8ff3e0ea3393818859874705a54b098c6081 Mon Sep 17 00:00:00 2001
>> From: Udit agarwal <dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>
>> Date: Tue, 13 Mar 2018 00:20:28 +0530
>> Subject: [PATCH] Added Getentropy() support to beagle BSP
>>  bsps/arm/include/libcpu/am335x.h                   |  37 ++++++-
>>  .../libbsp/arm/beagle/getentropy/bbb_getentropy.c  | 116
>>  3 files changed, 155 insertions(+), 2 deletions(-)
>>  create mode 100644 c/src/lib/libbsp/arm/beagle/ge
>> index 367e97c..cedd637 100644
>> @@ -14,11 +14,17 @@
>>   * Modified by Ben Gras <beng at shrike-systems.com <mailto:
>> beng at shrike-systems.com>> to add lots
>> + * Modified by Udit agarwal <dev.madaari at gmail.com <mailto:
>> dev.madaari at gmail.com>> to add random
>>  #define _AM335X_H_
>> @@ -701,4 +707,33 @@
>> (0x00000020u)
>> -#endif
>> +struct bbb_trng_register
>> +typedef struct bbb_trng_register bbb_trng_register;
> The bbb (Beagle Bone Black) is a particular board and the AM335X is a SoC
> family. This should be something like this
> typedef struct {
> } am335x_trng;
>> +#endif
>> \ No newline at end of file
> Git thinks that files should have a newline at the end of the file.
>> index 8251660..5d5ade3 100644
>>  # Shared
>>  #pwm
>> +#getentropy
>> +libbsp_a_SOURCES += getentropy/bbb_getentropy.c
> With the new BSP source structure
> https://devel.rtems.org/ticket/3285
> this new file could be also placed at
> bsps/arm/beagle/dev/getentropy.c
>> +    volatile bbb_trng_register  *rng = (bbb_trng_register*) RNG_BASE;
>> +    while (n > 0)
>> +        uint64_t random;
>> +        size_t copy;
>> +            /* wait */
> What happens if you call this function in parallel on different processors?
>> +               value */
>> +            if ( n < copy )
>> +                copy = n;
>> +            n -= copy;
>> +    return 0;
>> 1.9.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180313/06afa346/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180313/06afa346/attachment-0002.bin>
